> 2010 MS3 - How-To's
 Old 02-09-2016, 08:57 PM   #1
DavidFerreiraa's Avatar
Posts: 6   (View Stats)
DavidFerreiraa is an unknown quantity at this point
Default [help] how to install wideband gauge
This is my first post on here, this forum is full of interesting thread, i already found lots of threads that helped me a lot. But i still didn't find one that could help me step by step on how to install a wideband gauge. I bought one from prosports and i need help on how to install it, from beginning to the end.
Here is my gauge
Wideband Digital Air Fuel Ratio Gauge-Amber display
They have their own instructions but I couldn't figure it out on how to install the green and brow wire for the analog output.
I have a ms3 2010
Sorry if there is a similar thread already about this.
Thanks for the help
DavidFerreiraa is offline   Reply With Quote
 Old 06-14-2016, 04:18 PM   #2
uh60gunner209's Avatar
Posts: 106   (View Stats)
uh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud of
Groaned at 8 Times in 3 Posts
Did you ever figure it out?
uh60gunner209 is offline   Reply With Quote
 Old 06-14-2016, 04:22 PM   #3
Yeah, I figured it out by my self lol. Works great
 Old 06-14-2016, 05:39 PM   #4
Care to share what you did? I plan to install one in a few months
 Old 06-14-2016, 05:54 PM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Can I ask, since the Speed's have a wide band O2 from the factory, what's the goal of adding a second wide band O2?
340hp / 371tq
 Old 06-14-2016, 06:22 PM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I removed my oem narrowband, and replaced with an AEM failsafe with o2 sensor.
But if you already have an ap, really no need for just a basic wideband gauge.
SofaKingAwesome (06-14-2016)
 Old 06-16-2016, 06:34 AM   #7
I realized that after i installed it lol. I really dont use my gauge, i just use my ap. But i like the way it sits on my dash
 Old 06-16-2016, 06:54 AM   #8
I followed the instructions
http://prosportgauges.com/instructio...alwideband.pdf
I connected power wires to my fuse box using add-a-circuit. I used a voltmeter to find the fuses that i wanted to use cuz i wanted the gauge to turn on just when i turn the key. If u want i wll take a picture of my fuse box later. There is 2 wires that is just for the color of ur gauge, white (for white) and orange (for amber) i just connected the orange one for amber leds, if u want u can connect the other wire to ur headlights, so it will change colors at night. After u connected everything u r almost done, now u need to connect the sensor, which i had to pay $40 for a local shop to do it for me, I asked them to weld after the 2nd oem o2 sensor ( they ask u to install it 36 inches downstream so u dont kill the sensor too easy). After u do all of that just connect everything to the UEGO controller, turn the car on and let it calibrate, if it dont calibrate by it self, there is a little button on the uego that u can press for 3sec and it will calibrate for u.
You dont need to connect the analog output, unless u want to datalog it.
Wideband Gauge ev0nstispanka MazdaSpeed 3 - How-To's 22 10-09-2009 04:12 PM
wich wideband more acurate? Stock wideband or dyno tailpipe sniff wideband? gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 7 02-14-2009 10:37 PM
Page generated in 0.28523 seconds with 23 queries
