> 2010 MS3 - How-To's
Like Tree10Likes
  • 1 Post By SparkySparks
  • 1 Post By motherfnmonsta
  • 1 Post By kylecanthurdle
  • 1 Post By Lostmytune
  • 1 Post By Db09ms3
  • 1 Post By Jeff23spl
 Old 10-08-2013, 02:52 PM   #1
RallySportDirect's Avatar
Posts: 1,452   (View Stats)
RallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the world
Default How-to: Install CP-E Triton Dual Cat-Back
Yurtle's New CatBack
If you would like more product information, you can click any of the images below, or click HERE.
Description:
Looking for a little more out of your 2010+ MazdaSPEED3 exhaust?
Introducing the cp-e™ Triton™ 3" cat back exhaust for the 2nd Generation MazdaSPEED3's.
Featuring a full 3" Stainless Steel mid pipe, two cp-e™ designed resonators, and dual 4" polished exhaust tips; this cat back exhaust will not only improve the breathing of your 2nd gen MazdaSPEED3, it will also give you that aggressive exhaust note you've been looking for!
The cp-e™ Triton cat back exhaust for the 2nd gen MazdaSPEED3 has a very controlled exhaust note. No drone at cruising speeds, yet pronounced and aggressive at wide open throttle.
For those of you who have replaced the extremely restrictive factory downpipe, this 3" cat back will remove the last bottleneck in the exhaust stream; increasing the engines breathing capacity and smoothing out the turbo spool.
All cp-e™ exhausts are made from Super Polished Stainless Steel. The 18g heavy duty stainless piping is mandrel bent and cut on their in-house CNC Bender and CNC Mills. The systems feature custom cast Stainless Flanges, reliable hangers, custom made Stainless Mufflers and polished stainless tips. Everything is TIG welded by hand to get beautiful color and durability in the welds. Designed fully in a CAD environment to guarantee a factory-like fit every-time with great performance gains.
Details
Part #: CPE MMS32DCBEM2
Brand: cpe
Return Policy: Standard Return Policy
Mfgr. Warranty: Limited LIfetime Warranty
Installation Hardware Included: Yes
Piping Coating: No
Piping Flex Joint: No
Piping ID: 3in
Piping Material: 304 Stainless Steel
Piping Taper: No
Tip Material: Stainless Steel
Tip QTY: 2
Tip Size: 4in
As always great packaging and presentation by CP-E.
You can either do this installation on a lift or with jack stands. Luckily we have a lift here at work which always makes working on cars easier so I opted to take advantage of it for this install.
To remove the factory catback you'll basically only need a 12mm and 14mm socket and ratcheting wrench.
Start off by removing the mid chassis brace by removing the 8 12mm bolts. The brace has some hooks on it so you'll have to slide it back before it will drop down and off the car.
Use your 14mm to remove the nuts from both axleback and midpipe.
Next you'll disconnect the exhaust hangers and drop the factory system out of the way.
Here is the car with the factory catback uninstalled.
Mount up the pretty CP-E axle-back section.
To install the midpipe, when connecting it to a factory downpipe or factory style you'll need to remove the stock studs and connect using the supplied bolts and washers and reuse the factory springs.
To connect the axle-back and midpipe you'll need to install the 3rd pipe in the kit that are slip fit connections with clamps.
After you've connected all the pipes reinstall the chassis brace while ensuring you don't overtorque these bolts.
Install the tips as the last part. There is a fair amount of adjustment on the tips so that you can either install them flush with the bumper, out further or have them sit tucked under the bumper, really whatever you feel you like best.
Here is the finished product.
Don't forget to watch the video we made of the exhaust.
Thanks,
Tanner
For more information click here:
RallySportDirect is offline   Reply With Quote
The Following 5 Users Say Thank You to RallySportDirect For This Useful Post:
cshunter (11-22-2013), dale_gribble (10-08-2013), Gixxer2k4 (11-19-2013), mxlplx71 (10-13-2013), skeeter149 (10-08-2013)
How-to: Install TurboSmart Dual Port BOV RallySportDirect 2010 MS3 - How-To's 0 10-08-2013 02:49 PM
Dual meth tank install how-to Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 02-11-2013 05:55 PM
MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System www.cp-e.com Custom Performance Engineering (cp-e.com) 4 05-09-2012 06:01 AM
MazdaSPEED3 Gen2 Triton™ 3" SS Cat Back Exhaust System Grumpyjap Custom Performance Engineering (cp-e.com) 17 03-19-2012 05:20 PM
Page generated in 0.63179 seconds with 37 queries
