> 2010 MS3 - How-To's
Like Tree18Likes
 Old 01-16-2012, 02:18 PM   #1
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
Neutral  :  +3 score
Default How to: Install a switch for SWAS enable/disable
My intentions were to simply disconnect SWAS so I could have corner fun and whatnot. I was saddened to discover that in my Genpu /w tech pkg not only would the squiggly traction conrol light stay lit, but also the steering wheel with an exclamation point and my AFS light would flash.That is just way too much bling going on to keep disconnected all the time.
My buddy Sully does stereo and remote starter installs for a living and says that he should be able to disable SWAS by simply cutting the power wire feed in the plug. So that's basically what we have done. He identified the power wire feed and crimped in a switch so that I can switch SWAS, AFS, TC, etc off and on from under the steering column vs. pulling the steering column apart and unplugging it anytime I wanted to slide around a little.
There's the background...here's the walkthrough. Please do this at your own risk. God knows I did. I know little about these cars so if I have done something I shouldn't have let me know!!! LOL
1. Starting under the steering column there are three screws (Phillips head) that need to be removed. You can see them here in these pictures:
2. At this point I tilted the wheel all the way up and out towards me. I then pulled apart the top and bottom at both the turn signal assembly and windshield washer assembly. I tried to illustrate this here:
3. Once pried apart the top can stay where it is but you will want to work the bottom down so that you can access the SWAS plug. I removed the white plug directly under the yellow one because it makes it easier to access the SWAS plug. I have illustrated both being removed here:
4. At this point you just need to identify the light blue wire pictured below.
4a. Once you have the wire, cut back some of the conduit so the wires are exposed.
4b. Cut the light blue wire pictured below leaving room to crimp in the switch wires.
4c. Strip a little bit off the ends of the light blue wire before crimping.
4d. Crimp in the new switch to either side of the light blue wire.
5. Once the switch is crimped in we drilled a hole through the underside of the steering column cover and mounted the switch there. You can't hardly see it unless you seek it out and its readily available for turning SWAS off or on at will.
6. At this point it is only a matter of tucking everything away nicely and doing the step in reverse to button everything back up. Final product looks like this:
Here is my dash with the switch turned on (Everything normal):
And here is my dash with the switch turned off (SWAS, TC, AFS disabled):
Not sure where he got the switch. If anyone wants any other information, is interested in having him do it, or has any concerns please let me know. He operates Sully's Car Tunes in Carver, MA and im sure he would be happy to install for anyone
JTMS3, jared., SLOWHATCH and 2 others like this.
2014 Mazda 6 Grand Touring. Bone stock...
Old car: 2011 Speed 3 /w Tech Pkg. Cobb AP, CPE DP & CBE, JBR Whale Penis Intake, SSP, Motor Mount Trio, and Heavy Shift Knob /w silver vein!, Autotech internals, KSport Konrol Pro Coilovers, Corksport Interior LED's, LED Foglights and LED Rear Bumper Lights. Freek Tuned 50/50 e85
Mase is offline   Reply With Quote
The Following 51 Users Say Thank You to Mase For This Useful Post:
802MS3 (09-04-2013), altaprecision (10-31-2013), anavrinIV (01-16-2012), ape_ck (09-14-2013), AZSPEED3 (01-27-2012), Brennan (08-30-2013), ChimmyChong (01-17-2012), ChokeMeiLikeIt (03-09-2012), Crarrs (03-09-2012), dereeek (01-26-2012), Elusivellama (08-03-2018), fishin53 (01-27-2012), Flameninja00 (12-28-2016), Flow (07-08-2012), galens47 (04-08-2013), Greywolves1024 (04-13-2016), Grim_BL3FW (04-10-2012), Haltech (07-08-2012), ibcrusn (10-13-2013), JacksonMS30 (01-28-2012), jared. (07-13-2013), jimmy (01-29-2012), JTMS3 (01-16-2012), Juyoung (09-08-2013), K.Mah (09-17-2012), kmac (01-17-2012), kornybun (04-14-2014), kritz (01-16-2012), kylec_2003 (03-30-2013), mazdafreak (07-28-2014), melbaro (03-10-2012), Menace1 (02-10-2013), Miltron (04-24-2013), moomooz12 (04-12-2013), Nliiitend1 (01-16-2012), nybe0010 (12-02-2013), PapaSmurf (01-27-2012), Paul (04-06-2012), Pointless (04-05-2014), RusianKid (10-04-2014), ruthless013 (08-25-2012), ScarMS3 (01-16-2012), Sid3wayS (01-16-2012), skeurton (08-05-2013), SLOWHATCH (01-16-2012), smoogs12 (06-06-2012), SpdDemon89 (06-09-2012), SpeedRebirth (04-10-2014), The Nut (02-16-2017), Twofer (04-17-2013), Zdraveca (06-07-2012)
 Old 01-16-2012, 05:40 PM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
@karl-hungus @rfinkle2, would this also be the same for gen 1 and if so can we link this over to the gen 1 How-To section?
 Old 01-16-2012, 05:55 PM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
those kinds of switches can be bought at radio shack, just for anyone interested in this. They're super cheap and any on/off toggle will work. Thanks for the write up though, I maybe have to do this one.
Blue Pu.
Mase (01-16-2012)
 Old 01-16-2012, 05:56 PM   #4
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Great how to, however a bit more info on wiring in the switch itself would be nice.
So basically split the wire and run one side of the blue wire to the switch and other side to ground?
The Following User Says Thank You to SLOWHATCH For This Useful Post:
Mase (01-16-2012)
 Old 01-16-2012, 06:00 PM   #5
Mase's Avatar
Groans: 143
Originally Posted by SLOWHATCH View Post
Great how to, however a bit more info on wiring in the switch itself would be nice. I'm sure I can figure it out, but others maybe not so much.
I thought this as well but couldn't really come up with any more steps. It was pretty basic what he did. Basically cut the wire and crimped the switch in between. Didn't even matter which side of the switch went to which wire because the switch just connects or disconnects the two wires. I would have taken pictures of the actual switch wiring but this how-to was written after the fact. Maybe the next person that gives it a go can document this actual process?
Split the wire and run one side of the blue wire to one side of the switch and the other side of the blue wire to the other side of the switch.
Last edited by Mase; 01-16-2012 at 06:00 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Mase For This Useful Post:
 Old 01-16-2012, 06:02 PM   #6
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I like. But why is your coolant light on?
TEAM LUXURY
 Old 01-16-2012, 06:05 PM   #7
SLOWHATCH's Avatar
Groans: 274
Maybe I'll go pick up a switch and give this a whirl. I currently have my SWAS disconnected and like it that way, however it would be nice to be able to have traction control as needed.
 Old 01-16-2012, 06:05 PM   #8
I believe that the swas plug is different on the gen1.
Thanks Mase!
AZSPEED3 (01-27-2012), Mase (01-16-2012)
 Old 01-16-2012, 06:07 PM   #9
SLOWHATCH's Avatar
Groans: 274
Same reason his rpms are at almost 2k in first gauge pic.
Cold start on 2011 + have the nifty little blue light to tell you when its safe to start driving.
Captain KR and Tadweezy like this.
The Following 4 Users Say Thank You to SLOWHATCH For This Useful Post:
AZSPEED3 (01-27-2012), Mase (01-16-2012), rfinkle2 (01-17-2012), Sid3wayS (01-16-2012)
 Old 01-16-2012, 06:11 PM   #10
Sid3wayS's Avatar
Groans: 97
Yeah I noticed it was a cold start from the RPMs but ddnt know about the blue light. Damn you later gen2s got all the bells and whistles.
killer-ms3 and tanspeed3 like this.
TEAM LUXURY
The Following 7 Users Say Thank You to Sid3wayS For This Useful Post:
Boost Addict (01-27-2012), Brennan (08-30-2013), fishin53 (01-27-2012), himurax13 (02-27-2014), killer-ms3 (08-27-2013), Oliverms3 (03-09-2012), rfinkle2 (01-17-2012)
 Old 01-16-2012, 06:11 PM   #11
Mase's Avatar
Groans: 143
This. Was just starting it to demo the lights
 Old 01-16-2012, 06:12 PM   #12
anavrinIV's Avatar
Groans: 63
switches are dead simple. get a basic on/off switch and it will have 2 connection points. cut the wire, crimp a length of wire onto each cut end, and connect the other ends of those wires to the 2 connection points. done. I can draw a pic if you need it, but the wiring would only take about 30 seconds.
Me2speed3 likes this.
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
Mase (01-16-2012), nybe0010 (12-02-2013), SLOWHATCH (01-27-2012)
 Old 01-16-2012, 06:34 PM   #13
SLOWHATCH's Avatar
Groans: 274
Meh, for some reason I thought most switches had 3 pins.
So would I need to run a ground wire? This is the part I was confused about. And thanks, I was able to wire a meth kit but this has me baffled lol.
 Old 01-16-2012, 06:35 PM   #14
Mase's Avatar
Groans: 143
Heh no ground wire needed. The switch just makes or breaks the power connection on that one wire. This in effect powers or disables the swas module.
 Old 01-16-2012, 06:50 PM   #15
anavrinIV's Avatar
Groans: 63
ground wires are only ever required on things that actually use electricity. switches are called devices, which don't use electricity but are part of an electrical system.
I've done electrician work/construction, studied it in school, and I've done a little bit of work with electronics too...switches are very simple and I've thought about a number of things I'd like to do with this car.
Blue Pu.
 Old 01-16-2012, 06:59 PM   #16
xb2ms3's Avatar
Posts: 636   (View Stats)
xb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the world
can you turn it on and off while driving or do you have to turn it off before you start the car?
2011 Black Mica MS3
NJSPEED3 Ported IM + other shit
NJ NATOR NY
316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12
xb2ms3 is offline   Reply With Quote
 Old 01-17-2012, 03:11 AM   #17
Mase's Avatar
Groans: 143
Honestly I think you could turn it on or off while driving but I don't think I will be doing so. Just seems to risky to me.....
 Old 01-17-2012, 03:39 AM   #18
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Good write up.
The Following User Says Thank You to ASHMS3 For This Useful Post:
Mase (01-17-2012)
 Old 01-17-2012, 04:25 AM   #19
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
Awesome write up. I hate having all of the lights on constantly. I might give this a go.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
The Following User Says Thank You to mghtymouse380 For This Useful Post:
Mase (01-17-2012)
 Old 01-17-2012, 06:39 AM   #20
Mase's Avatar
Groans: 143
It seems scary but in all honesty its quite simple. I certainly felt more comfortable having my buddy doing it but I have no doubts I could have done it myself
 Old 01-17-2012, 06:46 AM   #21
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
No it is not the same ...... There is already a write up around here somewhere
2008 MS3 gt
470hp/463tq on GT35r at 29psi
Mase (01-17-2012)
 Old 01-17-2012, 07:13 AM   #22
Groans: 58
It cant be that hard. All he did was cut one wire and add a switch in. Thanks for the pics it will help out alot when i get around to doing this.
2013 CWP (DD)
 Old 01-17-2012, 07:15 AM   #23
Mase's Avatar
Groans: 143
While it may not be the same for the Gen 1's the concept should be the same. Probably just need to identify the appropriate wire on Gen 1's in order to do this.
 Old 01-17-2012, 07:46 AM   #24
lulz @Raider
burn813's Avatar
Agreed..... I know there is a write up for it cause I followed it for my genone
2008 MS3 gt
Mase (01-17-2012)
 Old 01-17-2012, 07:54 AM   #25
lulz @Raider
burn813's Avatar
On the genone the wire bundle lives on the other side of the steering column
2008 MS3 gt
Mase (01-17-2012)
 Old 01-26-2012, 10:52 PM   #26
JTMS3's Avatar
Posts: 2,306   (View Stats)
@Mase are you able to turn swas back on while the car is on? I haven't drove with it yet but just did this tonight. I noticed upon startup I was able to turn it off successfully but the only way to turn it back on was to turn the car off, then flip the switch and start back up.
Awesome how-to!
The Following 2 Users Say Thank You to JTMS3 For This Useful Post:
himurax13 (02-27-2014), SLOWHATCH (01-27-2012)
 Old 01-27-2012, 08:50 AM   #27
I'm just going to make a suggestion here:
- I've done electrical work on cars and electronics for many years now and there's nothing worse than electrical gremlins (any VW fans here?)
I find those crimp connections to be terrible for longevity and connectivity. This is a bit of a critical system that you don't want to have it go into a limp mode of sorts at the wrong time. So I suggest using solder and proper heatshrink and then using zap straps to brace wiring as much as possible against vibration.
Yes, I know most shops will slap an alarm in your ride using crimps but the very professional ones will use solder and heatshrink and do a proper job.
JTMS3 and Me2speed3 like this.
The Following 12 Users Say Thank You to Lex For This Useful Post:
AZSPEED3 (01-27-2012), dbrier (05-16-2012), fishin53 (01-27-2012), Gringo East (04-17-2012), JTMS3 (01-27-2012), Mizzle (03-10-2013), MS3CB (08-13-2013), Oliverms3 (03-09-2012), rfinkle2 (01-27-2012), Roddiy (06-23-2013), SLOWHATCH (01-27-2012), Twofer (04-17-2013)
 Old 01-27-2012, 09:03 AM   #28
JTMS3's Avatar
Agreed which is why I said fuck it and soldered & heatshrunk the wires on. At first I was worried about the dealer finding the switch but I was more concerned about a limp mode situation.
And yes my Jetta 2.0T was a fucking nightmare!
The Following User Says Thank You to JTMS3 For This Useful Post:
rfinkle2 (03-09-2012)
 Old 01-27-2012, 03:11 PM   #29
JTMS3's Avatar
ok update... volume & station change toggles as well as the "mode" button do not work on the steering wheel but everything else does. All wires are secure, soldered & heatshrunk and the switch works as described by OP (well except for turning off the car to turn SWAS on).
Not a big deal but anyone have any ideas why this would be?
 Old 01-27-2012, 04:25 PM   #30
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
Nice write up OP, should be good for both the gen1 and gen2. Just different wires between the two.
 Old 01-28-2012, 02:13 PM   #31
topset's Avatar
Posts: 54   (View Stats)
topset is a name known to alltopset is a name known to alltopset is a name known to alltopset is a name known to alltopset is a name known to alltopset is a name known to all
nice write up. im going to seek out an oem mazda switch and add it to the cluster that the AFS ans TCS switches sit in.
topset is offline   Reply With Quote
 Old 03-08-2012, 11:30 PM   #32
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
I am just guessing and I know what the SWAS does.. but does SWAS stand for Steering Wheel Angle Sensor?
Bosox is offline   Reply With Quote
 Old 03-09-2012, 08:52 AM   #33
lulz @Raider
burn813's Avatar
Yes
2008 MS3 gt
Mase (03-09-2012)
 Old 04-06-2012, 07:48 PM   #34
Paul's Avatar
Posts: 822   (View Stats)
Paul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the world
Groaned at 20 Times in 5 Posts
This is awsome! Thank you OP.
You can toggle this while car is running? - No negative side effects of cutting power to SWAS while car is on in other words.
2011 MS3 || Tech Pkg || Shark fin ||
|| HTP 3.5 Intake || || BNR4 || CS TMIC || CS CBE ||
|| CS Boost & BpV Tubes || DENSO IVT22 || FORGE BPV v2 ||
|| AT Internals || COBB APV3 || CNT DP || Koni Yellows || H&R Springs ||
|| JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings ||
|| JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || JBR EGR Block/Delete - OCC - Small Battery box ||
\\|// AJ 91 & E85/91 Mix Tunes by A.J \\|//
|| Window Tints, Lamine-x Headlights/Fogs, Tinted Tails, JDM Rain Guards ||
Paul is offline   Reply With Quote
 Old 04-06-2012, 10:18 PM   #35
lulz @Raider
burn813's Avatar
I haven't seen any as of yet
2008 MS3 gt
 Old 04-10-2012, 05:52 PM   #36
Grim_BL3FW's Avatar
Posts: 103   (View Stats)
Grim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond reputeGrim_BL3FW has a reputation beyond repute
The power to those buttons may be tied into that power wire after the point where the switch is mounted. Just a guess.
JBR OCC / JBR 88 CM RMM / CS SRI & TIP
My build Thread
http://www.mazdaspeedforum.org/forum/forum/f542/grim_bl3fws-build-108013/
Grim_BL3FW is offline   Reply With Quote
 Old 04-10-2012, 06:12 PM   #37
lulz @Raider
burn813's Avatar
I am not sure about the genpu but the genone has no issue like this if you splice the yellow wire on the bundle
2008 MS3 gt
 Old 04-15-2012, 03:44 PM   #38
dpolseno41's Avatar
Posts: 1,819   (View Stats)
So in the gen1, you can run a switch between the yellow wire? I've been trying to figure out exactly what wire it would be.
 Old 04-15-2012, 04:03 PM   #39
lulz @Raider
burn813's Avatar
that is the one that I used and I am pretty sure there is a post on it somewhere around here on how to do it.
2008 MS3 gt
 Old 04-25-2012, 02:00 PM   #40
Gringo East's Avatar
Posts: 198   (View Stats)
Gringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the world
Nice write up! Subbed.
Gringo East is offline   Reply With Quote
The Following User Says Thank You to Gringo East For This Useful Post:
Mase (04-26-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-install-switch-swas-enable-disable-102406/
Club323F ? View topic - Bj DSC This thread Refback 09-21-2015 01:37 PM
Reedy's Engine Rebuild Bonanza! - Page 25 This thread Pingback 09-15-2015 10:03 PM
swas switch ? Mazda MPS Owners Club This thread Refback 03-18-2015 12:43 PM
SWAS switch This thread Refback 05-27-2014 01:20 PM
Mazdaspeed 3 2nd gen !!!!!!!! This thread Refback 11-21-2013 05:41 AM
Elektronik und ECU - [3 BK] DSC, Tracktionskontrolle komplett ausschalten This thread Refback 06-27-2013 02:39 AM
Elektronik und ECU - [3 BL] ESP deaktivieren This thread Refback 02-25-2013 07:23 AM
[3 BK] esp komplett off - Elektronik und ECU - mazda-mps.de This thread Refback 11-02-2012 06:20 AM
[3 BL] ESP deaktivieren - Elektronik und ECU - mazda-mps.de This thread Refback 10-21-2012 08:50 PM
Mazda MPS Owners Club • View topic - Holding back This thread Refback 07-07-2012 04:24 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 05-18-2012 01:04 AM
Random MS3 Chat Thread - Page 79 This thread Refback 05-07-2012 01:34 PM
Time To Go Forged - Page 18 This thread Refback 03-30-2012 08:52 PM
SWAS - DISCONNECT ON A GEN2 Monotonous ONE 2010 MS3 - How-To's 160 10-07-2018 09:17 PM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS - How to disable Dano MazdaSpeed 3/6 - ECU Computer Tuning 208 06-09-2016 08:21 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.62613 seconds with 39 queries
