> 2010 MS3 - How-To's
Like Tree23Likes
 Old 09-05-2011, 11:19 AM   #1
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Default SWAS - DISCONNECT ON A GEN2
Thanks to @Dano for his writeup. It inspired me to take some pics after doing mine so some of the Pus can know what time it is.
Dano thread for gen1: http://www.mazdaspeedforum.org/forum/foru...disable-90739/
This how-to is an extension of the one done by @harryclay so props to him. Heres his thread: SWAS on 2010
1st step: Disconnect negative battery terminal. Pump the brakes a few times to drain all remaining power from the system.
Heres the view on approach.
I only undid the 2 screws underneath the steering wheel and bent them far enough out of the way to get to shit. Use the tilt/telescope and bring the wheel out as far as it will go. This allows the two peices to come farther apart and give you more than enough room to work to get it done.
Heres the area you will be working around.
Undo the little thingy for that holds up the wires. This is to give you more room to work. I found it to be necessary and since it takes 3 seconds...wtf not?
There it is disconnected. Also notice i kept the white harness underneath the yellow harness disconnected to allow more room to work. This probably was unnecessary but fuck it.
This is Harryclay's picture. Shows what the connector looks like disconnected. It is almost impossible to take a good picture of it. But heres the best description i can give you to disconnect it:
1) Use the flathead to undo the latch that keeps it connected. You will come from the left side(engine side) and get it at just the right angle to unlatch it.
2) Use needle nose pliers to grip the connector with your right hand.
3) Simultaneously unlatch the connector with the left hand and wiggle it downward with the right hand.
it will pop out pretty easily.
Note the two yellow lights on the dash that will now be permanantly illuminated. TC/DSC can not be toggled on or off. It is permanantly off. Do this mod at your own discretion.
Tools used. 10mm wrench was to disconnect the negative battery terminal.
Then tuck it back under and button everything up.
Afterwards I went for a drive. Upon returning into my hood i turned the wheel and launched it. It spun...a lot...so there you go. No more traction control and no more SWAS nanny.
The Following 4 Users Say Thank You to Monotonous ONE For This Useful Post:
bcmountainspeed (09-05-2011), Dano (09-05-2011), G26 (09-06-2011), nybe0010 (12-05-2013)
 Old 09-05-2011, 11:41 AM   #2
bcmountainspeed's Avatar
Posts: 361   (View Stats)
bcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the worldbcmountainspeed is the leader of the world
I'm gonna go out and do this now. I disconnected it a while back but put it back, but I think I'll try running it for a little longer after reading Dano's post.
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Die, You are forgiven. If I Live, I will kill you." Such is the Rule of Honor
bcmountainspeed is offline   Reply With Quote
 Old 09-05-2011, 11:42 AM   #3
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Waitin on driving impressions.
 Old 09-05-2011, 12:42 PM   #4
Groans: 819
Something aint quite right
I would hold off until i figure out wtf is wrong.
As of right now my steering wheel buttons are not functioning. So im thinking shit is different on gen2.
Goin to work now ao i wont be able to figure shit out til tomorrow.
Car is driving fine tho.
G26 (09-05-2011)
 Old 09-05-2011, 01:52 PM   #5
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
That white plug is NOT THE SWAS. You disconnected the wrong plug dummy.
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
The Following 2 Users Say Thank You to ztnedman1 For This Useful Post:
Miltron (04-24-2013), MZR801 (08-29-2014)
 Old 09-05-2011, 02:18 PM   #6
ruthless013's Avatar
Posts: 603   (View Stats)
ruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the worldruthless013 is the leader of the world
in before random airbag deployment.
thanks for looking into it for gen2s. im sure theres an easy enough way to provide constant voltage to the sensor so it thinks the wheel is straight all the time, i just dont have the skillz to do it. yet.
2010 Black Mica Mazdaspeed3
2009 Black Cherry CX-9 AWD
1997 Classic Red Miata
ruthless013 is offline   Reply With Quote
The Following 3 Users Say Thank You to ruthless013 For This Useful Post:
Broxer (03-29-2012), kritz (09-05-2011), MS3CB (09-13-2013)
 Old 09-05-2011, 02:30 PM   #7
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Swear there was a thread on this somewhere.. guy disconnected the angLe sensor on his gen2, and lost his power steering also..
yup heres the thread:
SWAS on 2010
 Old 09-05-2011, 02:49 PM   #8
Groans: 819
SO WTF DID I DO TO MY CAR BRO
Lol...looks like it was just the harness for steering wheel shit. Cruise/volume/etc.
Hopefully i plug it in and its all good. Lol.
Genpu fail for life bro
 Old 09-05-2011, 02:52 PM   #9
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Originally Posted by Spoofmastafly View Post
Swear there was a thread on this somewhere.. guy disconnected the angel sensor on his gen2, and lost his power steering also..
SWAS on 2010
We have an Angel sensor? Thats bad ass man, it is like a Grimm Reaper sensor?
403whp/451ft/lb Dry Shot
The Following 2 Users Say Thank You to Bucker For This Useful Post:
Broxer (03-29-2012), Teethkikr (09-05-2011)
 Old 09-05-2011, 02:55 PM   #10
MazdaASM's Avatar
Posts: 491   (View Stats)
MazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the worldMazdaASM is the leader of the world
Groaned at 9 Times in 7 Posts
Neutral  :  -1 score
your poo is trying to commit suicide
MazdaASM is offline   Reply With Quote
 Old 09-05-2011, 03:35 PM   #11
Hey! Thats enough outta you!
The Following User Says Thank You to Spoofmastafly For This Useful Post:
Bucker (09-05-2011)
 Old 09-05-2011, 04:14 PM   #12
ztnedman1's Avatar
SWAS on 2010
At very slow speeds (idle in first gear) if you turn one way then the other the power steering will cut off for a second. If you push in clutch or gas, it kicks back in. This is the ONLY time this occurs, and IMO is not bad (steering just gets heavy but still easy to control).
2004 Corvette Z06
The Following 4 Users Say Thank You to ztnedman1 For This Useful Post:
ArcticSpeed3 (09-05-2011), harryclay (03-20-2015), rfinkle2 (11-11-2011), tclegg (08-03-2013)
 Old 09-05-2011, 05:00 PM   #13
Groans: 819
Fuck my life
I was way off. Kinda. Atleast i didnt catch an airbag to the face. Yet.
I guess i know how to get the fucker now.
Bucker (09-05-2011)
 Old 09-05-2011, 05:51 PM   #14
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
LOL@airbag to the face.
What a lovable bunch we are!!
 Old 09-05-2011, 06:26 PM   #15
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
This is a very simple how to:
1) look around and find two screws on the bottom of the steering wheel column (remove them and never put them back in so you can help some fool in like 2 seconds on msf)
2) pick a wire and pull it out (don't start with the big scary green harness)
3) check how car behaves and if your turn signals or controls don't act normally, choose again
4) when you get two warning lights and your traction control button no longer functions (it is just off now, at least for me) you are done
but, if you want to do it right the first time, pull the wire in the pic below... use the bottom set of wires in that wire bundle for a guide
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
Brennan (08-30-2013), herzloglover (05-18-2016), tclegg (08-03-2013), WetzMS3 (08-14-2013)
 Old 09-05-2011, 08:12 PM   #16
Bucker's Avatar
Groans: 451
The one with an orange clip. Check. Thanks!
 Old 09-05-2011, 08:21 PM   #17
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
If you own a genpu, just go ahead and pull the white one
 Old 09-06-2011, 12:06 PM   #18
Groans: 819
bump for shit being fixed and being all good
 Old 09-11-2011, 11:01 AM   #19
2011speed's Avatar
Posts: 1,497   (View Stats)
So there's no way to disable the lights in the dash for this mod, cuz personally that would piss me off.
I wonder if this will allow my 2011 to brake boost
FreeKtuned
fitty fitty
 Old 09-11-2011, 11:09 AM   #20
Groans: 819
I dunno about those lights but i dont give a fuck as long as its not a CEL
And its worth a shot to see if you can brake boost. Although I would bet they are separate systems.
But give it a shot and report back
 Old 09-11-2011, 11:15 AM   #21
Groans: 134
I tOtally thought that the lights would piss me off, but after a couple of days I no longer noticed them.
Lol at all of the tools! I brought a Phillips head w me to work and pulled over half way to an account and just started pulling shit out w my hands until I got it right.
Last edited by Ckmazdaspeed3; 09-11-2011 at 11:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-11-2011, 11:31 AM   #22
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Neutral  :  -1 score
i still dont understand why you need to brake boost?
in b4
because racecar
The Following User Says Thank You to forcedinduktion For This Useful Post:
TheStig1989 (10-12-2011)
 Old 09-11-2011, 12:43 PM   #23
2011speed's Avatar
in b4
because racecar
Lmao
Because sushi roll
FreeKtuned
fitty fitty
The Following 3 Users Say Thank You to 2011speed For This Useful Post:
Ckmazdaspeed3 (09-11-2011), himurax13 (07-29-2013), TheStig1989 (10-12-2011)
 Old 09-11-2011, 02:52 PM   #24
khopwood77's Avatar
Posts: 245   (View Stats)
khopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the world
There might be a better way to fix this coming soon...
I have been testing a fix from Cobb this weekend trying to eliminate the SWAS rich condition through tuning instead of unplugging the sensor. Prior to the fix I was randomly seeing WOT AFRs in the 9s for the entire run and now its gone. I do not know what they changed I'll try to find out more. From what I gathered it's a table exposed in the latest version of ATR but not visible to the end user. I'm hoping this makes it into the next beta release as it seems to have cured my problems.
Next up is testing the display and logging of boost > 22PSI on a 3 bar MAP for Gen2s.
Bucker, rfinkle2 and neofandango like this.
2010 Black Mica MS3 (Daily Driver) - self-tuned with the help of Lex www.mazdaspeedforum.org/forum/forum/f426/k06-log-86437/
K04 Hybrid, Nitto NT01s, JMF Manifold, 4 Port Meth, 100% E85, 3 Bar MAP, HTP 3.5, Cobb DP, ETS TMIC, KMD Internals, PTP RV, OCC, Forge BPV, CP-E Mounts, JBR Thermal Intake & Throttle Body Gaskets, JBR Shifter Plate & Bushings
2006 Mustang GT - www.vortechsuperchargers.com/global_item.php?gik=348
Built Motor, 675 RWHP 560 lb/ft T-Trim 21PSI Non-Intercooled
1993 Mustang LX - www.youtube.com/watch?v=WiCCvodp6CU
Budget 349 Stroker
khopwood77 is offline   Reply With Quote
The Following 9 Users Say Thank You to khopwood77 For This Useful Post:
bewsted (09-11-2011), Broxer (10-03-2011), Bucker (09-11-2011), Ckmazdaspeed3 (09-11-2011), josurr (11-15-2011), Monotonous ONE (09-11-2011), rfinkle2 (09-12-2011), SLOWHATCH (10-21-2011), wolly6973 (09-12-2011)
 Old 09-11-2011, 03:00 PM   #25
Titanknight's Avatar
Posts: 69   (View Stats)
Titanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond reputeTitanknight has a reputation beyond repute
^^^I like this option much better. keep us updated.^^^
Titanknight is offline   Reply With Quote
 Old 09-11-2011, 03:11 PM   #26
bewsted's Avatar
Posts: 2,456   (View Stats)
WTB this testing LOL
EWG K04...GETSUM!
 Old 09-11-2011, 03:17 PM   #27
bewsted's Avatar
Needs to be an option like turning off cels....
EWG K04...GETSUM!
 Old 09-11-2011, 04:55 PM   #28
khopwood77's Avatar
I'm not 100% positive but I think it's more like the commanded max enrichment table giving you the ability to set AFR during certain conditions. I'll keep digging and let you guys know.
Budget 349 Stroker
The Following User Says Thank You to khopwood77 For This Useful Post:
 Old 09-11-2011, 05:06 PM   #29
Groans: 134
I'll be turnig up boost on Wednesday the second my new clutch is in. My 2871 has 3 bar and I'll be pretty annoyed if i still can't go past the current limits
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 09-11-2011, 05:17 PM   #30
Bucker's Avatar
Groans: 451
I NEED THE BOOST DISPLAY/ LOG!!!
You can not log over ~22.6 PSI using the AP. I know. I have a 3 BAR MAP, but it didn't change that.
Last edited by Bucker; 09-11-2011 at 05:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-11-2011, 05:21 PM   #31
Groans: 134
God damn it! That is fucking annoying! I hope they fix this soon! You can on gendone right?
 Old 09-11-2011, 05:34 PM   #32
Bucker's Avatar
Groans: 451
I'm a Gen 2
 Old 09-11-2011, 05:38 PM   #33
Groans: 134
No, I know, I was just trying to get confirmation that gendone has this capability
 Old 09-11-2011, 08:02 PM   #34
Bucker's Avatar
Groans: 451
Reading fail on my part... I honestly don't have your answer.
 Old 09-11-2011, 08:14 PM   #35
bewsted's Avatar
So i cant tell you lil niglets one thing for sure....
This ANGLE sensor will effect your AFR's more than you know..
My shit is SPOT on now...Just think of it like this....How hard does your car pull....The harder it pulls the more the angle sensor acknowledges angle and the more bull shit the ecu does to pull full or whatever the fuck it does.
EWG K04...GETSUM!
The Following 6 Users Say Thank You to bewsted For This Useful Post:
Broxer (10-03-2011), Bucker (09-11-2011), Ckmazdaspeed3 (09-11-2011), redblur (12-28-2011), rfinkle2 (09-12-2011), wolly6973 (09-12-2011)
 Old 09-12-2011, 04:29 PM   #36
khopwood77's Avatar
Hey guys try this out and see if it helps with your rich condition. The guys at Cobb let me know what they changed in ATR. I thought the tables were not exposed in ATR but they are available. Below is what they sent me when I was asking about what they did to correct my issue.
In the latest release of ATR (Shifting Control Tables):
Set Ignition Timing Limit (Min) (Throttle Closed) and (Throttle Open) to -3.0 (Stutter Fix)
Set all Load Based and Load/RPM Based Fuel Compensations to 1.0 (Post Shift Fueling Fix)
I have been running my car all weekend without a single rich condition. Attached is what prompted me to contact them. The "WOT 9s" file would occur randomly once every 10-15 WOT runs.
I will update you guys in a few days on the Boost > 22. Waiting on the Alpha fix...
rfinkle2 and eppopipe like this.
Budget 349 Stroker
The Following 6 Users Say Thank You to khopwood77 For This Useful Post:
Broxer (10-03-2011), Bucker (09-13-2011), Ckmazdaspeed3 (09-12-2011), eppopipe (09-14-2011), rfinkle2 (09-13-2011), wolly6973 (09-12-2011)
 Old 09-12-2011, 04:39 PM   #37
bewsted's Avatar
Damn son....ko4 hybrid = what? LOL
EWG K04...GETSUM!
 Old 09-12-2011, 05:18 PM   #38
Bucker's Avatar
Groans: 451
K06 wheel.
 Old 09-12-2011, 05:27 PM   #39
bewsted's Avatar
port comp housing thats it?
EWG K04...GETSUM!
 Old 09-12-2011, 06:05 PM   #40
Bucker's Avatar
Groans: 451
Pretty sure that and a new wastegate actuator. It looks like it flows, though.
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
The disconnect of connected cars Haltech Automotive News 0 05-03-2010 07:20 AM
Toyota's U.S.-Japan disconnect Haltech Automotive News 0 03-01-2010 10:10 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.60330 seconds with 36 queries
