> 2010 MS3 - Wheels & Tires
  • 1 Post By Smelson
 Old 08-21-2014, 08:35 AM   #1
StevenW's Avatar
Posts: 268   (View Stats)
StevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the world
Groaned at 8 Times in 7 Posts
Default 17x9 +35
Anyone else running these specs on your pu? I need some tires and found a steal for wheels and tires but they're in 17x9+35. From what I can gather, the wheel will be 1mm closer to the strut, and 36mm further out towards the fender and will probably rub if I run a 235 tire.
I'm trying to figure out my options, so has anyone else run this same wheel spec and tire size? What did it take to get them to fit and not constantly rub?
StevenW is offline   Reply With Quote
17x9 RPF01 w/ 255/40/17 starscream MazdaSpeed 3/6 - Wheels & Tires 40 04-29-2013 08:21 PM
17x9 +45 with 255/40 TWOptSL0W MazdaSpeed 3/6 - Wheels & Tires 19 07-16-2012 02:43 AM
17x9+38 255/40R17 bmannn 2010 MS3 - Wheels & Tires 28 03-03-2012 08:47 AM
Page generated in 0.36737 seconds with 26 queries
