> 2010 MS3 - Wheels & Tires
  • 1 Post By Fstrnyou
  • 1 Post By JakeMS3
 Old 01-14-2019, 02:41 PM   #1
2010mps's Avatar
Posts: 2   (View Stats)
2010mps is an unknown quantity at this point
Default 7.5 +45
Hey guys, jw if a 7.5 +45 wheel would sit flush or close to flush on my gen pu, I want 8-8.5 but these enkeis area steal. Tia!
2010mps is offline   Reply With Quote
 Old 01-15-2019, 01:30 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Jeff23spl likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-18-2019, 11:44 AM   #3
kosti365's Avatar
Posts: 15   (View Stats)
kosti365 is an unknown quantity at this point
Serious answer... GenPu stock wheels are 18x7.5 +52. So depending on the tire you put on they might poke a negligible .2" closer to your fender - nowhere near flush.
I would say don't bother and hold out for a wider and lighter wheel but I don't know anything else about the car. Do some more research on the forum, lots of good info out here.
2013 MS3 Liquid Silver Metallic with Tech
Power: CS HPFP Internals, JBR SRI\TIP, UR Race Pipe, CPE TMIC, TB TIG\Coolant Bypass, Cobb AP, Denso ITV22's, E33 Freektune
Handling: CorkSport RSB, CPE RMM, Bilstein B12 Prokit, Konig Rennform 18x8 w\Indy Firehawks, Stoptech Front Slotted Rotors\Pads\SS Lines, Damond SSP, JBR Shifter Bushings, CS TMM insert
Misc: Damond OCC & EGR Delete, CS BPV, Borla Axle Back, BaysonR Front Lip, LED everything
kosti365 is offline   Reply With Quote
 Old 01-18-2019, 05:27 PM   #4
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Search through the multiple pages and thousands of pictures in the aftermarket wheels thread. That’s going to be the easiest route for you if you are not knowledgeable on wheel sizes and offsets. But to help you out if you are looking for a flush look your best bet is going to be an 8.5” width wheel with an offset of +45 down to +35. Wider than 8.5” and lower offset than 35 is getting into the “aggressive fitment” realm.
ThizSpeed3 likes this.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
ThizSpeed3 (01-23-2019)
 Old 01-23-2019, 06:09 AM   #5
ThizSpeed3's Avatar
Posts: 253   (View Stats)
ThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond reputeThizSpeed3 has a reputation beyond repute
I've done the research but i am still conflicted could you chime in please?
18 X8 5-114.30 +46 offset
or
18 X8.5 5-114.30 +40 offset
i want to be flush but not rub scrap , going to be lowered.
ThizSpeed3 is offline   Reply With Quote
 Old 01-23-2019, 06:11 AM   #6
Fstrnyou's Avatar
Your limits will change with a roll/pull.
I know the fitment thread is long, but you should read it anyways...from start to finish.
Other rides:
History:
Page generated in 0.27374 seconds with 23 queries
