![]() Join Date: Mar 2012 Location: Greensboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,087
(Thread Starter) | Not Ranked : 0 score 17x9 +45 - 255/45/17 Hankook v12 - eibach springs - 5mm spacer in front ![]() ![]() ![]() Sent from my iPhone using Tapatalk
__________________ 2008 True Red Juan | Fully Bolted > Stocked out > Traded Partnered with DeftMotion deftmotion.com 2013 Mica Black Pu Performance CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune Suspension Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines Ricer Shit Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP |
| The Following 10 Users Say Thank You to omgvance For This Useful Post: | 865ms3 (12-27-2013), atvfreek (12-26-2013), FenixTX717 (01-29-2015), impossible (06-15-2014), J'sSpeed3 (12-29-2013), MS3G35 (04-02-2014), rfinkle2 (12-26-2013), Shayne-ms3 (12-28-2013), tbcota25 (05-13-2014), XjCrazy09 (06-06-2014) |
![]() Join Date: Nov 2012 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
| Not Ranked : 0 score Will be joining this club soon, right after my blizzaks and steelies come off.
__________________ Mods: The usual Power: E85 ko4 Suspension: Corksport Springs |
| The Following User Says Thank You to shpeedtree For This Useful Post: | omgvance (12-22-2013) |
![]() Join Date: Mar 2011 Location: Gillette, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 782
Groans: 64
Groaned at 18 Times in 6 Posts
| Not Ranked : 0 score 17x9 black rpf1 +45 rolled rears, 5mm spacer up front, swift springs and CS camber arms in the back with 245/45/17 Dunlop zIIs
__________________ COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS |
| The Following User Says Thank You to 2k4_8 For This Useful Post: | omgvance (12-22-2013) |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
| Not Ranked : 0 score 17x9 +35 with 10mm spacer up front, 255/40/17 federal 595, tein super street coilovers, with CS camber plates
__________________ when was the last time your speed reeled in this many bitches? ![]() ![]() |
| The Following 7 Users Say Thank You to Manny For This Useful Post: | Downmented (02-04-2014), FenixTX717 (01-29-2015), killer-ms3 (12-27-2013), Micha (12-25-2013), omgvance (12-26-2013), redneck4Christ (02-26-2015), SLOWHATCH (12-28-2013) |
![]() Join Date: Feb 2012 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
__________________ FreekTuned |
| The Following 2 Users Say Thank You to msantana101 For This Useful Post: | omgvance (12-26-2013), shpeedtree (12-26-2013) |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score Guess ill add to this. 17x9 +45 with 235/45/17 conti dws.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
| The Following 3 Users Say Thank You to ckMS3 For This Useful Post: |
![]() Join Date: Jan 2011 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score Genpu forum but I like whoring out my setup. 18x9.5 +38mm (5mm spacer up front to clear my BBK), 245/35/18 Federal RS-R's which run more like 265 then anything...
__________________ BNR S3 | Stratified Tune | Cobb AP | CS 3" TBE & TMIC | JBR PMM/RMM | JBR RSB | JBR 3" Intake | KW V3 | Rotora BBK | 18x9.5 RPF1 |
| The Following 20 Users Say Thank You to ash4390 For This Useful Post: | 802MS3 (12-27-2013), ArmanRus (12-27-2013), atvfreek (12-26-2013), ckMS3 (12-26-2013), CWP_MS3 (07-11-2014), impossible (01-10-2014), J'sSpeed3 (12-29-2013), Lex (12-27-2013), msantana101 (12-26-2013), omgvance (12-26-2013), Ozziemitch (11-12-2014), rgz (02-03-2014), sadak (01-28-2014), Shayne-ms3 (12-28-2013), sidekick (05-17-2014), SLOWHATCH (12-28-2013), speed3 britz (12-26-2013), SpeedNess (03-18-2014), WA_MS6 (08-09-2014), white'swhiteMPS (12-26-2013) |
![]() Join Date: Nov 2013 Location: ALBANY, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 551
Groaned at 6 Times in 3 Posts
Are you running springs or Coilovers ? Sent while snappin' necks and cashin' checks
__________________ *JBR RMM88 *JBR PMM *AUTOTECH HPFP *CP-E CATTED DP *SWIFT SPRINGS *WhiteZilla GRILL STOCKING OUT | |
![]() Join Date: Nov 2011 Location: Naples, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score I really need to get some better shots. 17 x 9 et45 Goodyear AS2's in 245/40/17 Lowered on Swift springs and Koni Yellows. No spacers required, but damn is it tight.
__________________ - 2012 MS3 - CS- SRI & TIP - Autotechs - AP v3 - Denso Iridiums - CP-E S2 RMM/TMIC/Catted-DP - 17x9 +45 RPF-1 - 245/40-17 Michelin PSS - Koni Yellows - Whiteline RSB - - 2011 CX-7 - Soccer mom machine. |
| The Following 5 Users Say Thank You to xpystchrisx For This Useful Post: | ckMS3 (12-26-2013), Darthspeed3 (03-29-2014), omgvance (12-26-2013), sadak (01-28-2014), Schmitty5 (04-15-2014) |
![]() Join Date: Oct 2012 Location: NSW Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score 17x9 +45 5mm spacer up front. 245/45/17 extreme sport contact. Lowered on dgr coillvers. ![]() ![]() ![]() More rpf1 love with my mate :-) ![]() Sent from my Nexus 5 using Tapatalk |
| The Following 6 Users Say Thank You to Gibbo For This Useful Post: | CWP_MS3 (02-19-2015), J'sSpeed3 (12-29-2013), omgvance (12-26-2013), SarcasticOne (12-28-2013), sidekick (05-17-2014), xpystchrisx (12-27-2013) |
According to his sig, kW v3 Sent from my iPhone using Tapatalk
__________________ FreekTuned | |
| The Following 3 Users Say Thank You to msantana101 For This Useful Post: |
Riding a little monster-truck ish... but function > form
__________________ BNR S3 | Stratified Tune | Cobb AP | CS 3" TBE & TMIC | JBR PMM/RMM | JBR RSB | JBR 3" Intake | KW V3 | Rotora BBK | 18x9.5 RPF1 | |
| The Following User Says Thank You to ash4390 For This Useful Post: | impossible (06-15-2014) |
| Not Ranked : 0 score 17x9 +45 10MM spacers up front. Sonic tuning coil overs JBR camber arms 245/45/17 ![]() ![]() ![]() Sent from your girlfriends tapabedroom
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| The Following 9 Users Say Thank You to PapaSmurf For This Useful Post: | chaser27 (01-23-2014), CWP_MS3 (07-11-2014), Downmented (02-04-2014), FenixTX717 (01-29-2015), J'sSpeed3 (12-29-2013), omgvance (12-26-2013), sadak (01-28-2014), Thrizzl3 (01-01-2014), xpystchrisx (12-27-2013) |
(Thread Starter) | Not Ranked : 0 score This makes me want to do a crazy color haha How hard are those to keep clean?
Brake dust usually just smudges so i have to scrub with a magic eraser to get it off. Good thing it is only driven on these wheels about once a week when its running.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
(Thread Starter) | Not Ranked : 0 score dipped or pc'd?
| Not Ranked : 0 score powder coated. Neon yellow with a casper clear. Which is a matte clear.
| The Following User Says Thank You to PapaSmurf For This Useful Post: | omgvance (12-26-2013) |
![]() Join Date: Feb 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
| Not Ranked : 0 score Gold 17x9 +45 10mm spacers on the front Tein Basic Coilovers Eibach Rear Camber Arms 255/40/17
__________________ 2007 Black Mica MS3 - CP-e Nano SRI, CP-e TIH, CP-e HPFP, CP-e catted DP, CP-e RMM 75A, Saikou Michi oil catch can, TRZ TMM, JBR RSB, JBR PMM 80A, Mspeed Stuff, Cobb AP, Cobb XLE BPV, Cobb FMIC V2, Gold 17x9 Enkei RPF1, Hankook RS-3 255/40/17, DBA 4000 slotted rotors, Motul RBF600 brake fluid, Rotella T6 Engine oil, Prosport Boost/Oil temp/Pressure gauges, Other Assorted Rice... |
| The Following 8 Users Say Thank You to Thrizzl3 For This Useful Post: | Addikted To Boost (07-08-2014), Boost_creep (12-27-2013), FenixTX717 (01-29-2015), impossible (01-10-2014), J'sSpeed3 (12-29-2013), omgvance (12-26-2013), PapaSmurf (12-26-2013), Shayne-ms3 (12-28-2013) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I would really love to get some of these wheels in Mag blue for my silver speed... Sent from my iPhone using Tapatalk
| The Following User Says Thank You to msantana101 For This Useful Post: | omgvance (12-26-2013) |
![]() | | #20 | ![]() |
__________________ 2008 True Red Juan | Fully Bolted > Stocked out > Traded Partnered with DeftMotion deftmotion.com 2013 Mica Black Pu Performance CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune Suspension Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines Ricer Shit Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP | |
| The Following User Says Thank You to omgvance For This Useful Post: | msantana101 (12-26-2013) |
![]() | | #21 | ![]() |
![]() Join Date: Oct 2011 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 728
| Not Ranked : 0 score Enkei RPF1 17x9 +45 Hankook Ventus V12 245/45/17 JBR 5mm wheel spacers in the front Stock suspension |
![]() | | #22 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score RPF1's FTW 17x9.5 +38 |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score For those of you running the 17x9 +45 setup, is a spacer up front necessary with a spring/strut setup? Gen 1 btw.
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Yeah I run it so i know there is clearance between the wheel and strut. it's a really tight fit if you know what I mean lol
| The Following User Says Thank You to Thrizzl3 For This Useful Post: | Boost_creep (12-27-2013) |
![]() | | #25 | ![]() |
I don't think you have to, but I do for piece of mind. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to omgvance For This Useful Post: | Boost_creep (12-27-2013) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Yea, I guess it also depends on the tire you're running. I was just curious if the wheel actually clears the strut body. Thanks guys!
![]() | | #27 | ![]() |
![]() Join Date: May 2013 Location: Santa Cruz, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score 17x8 and 9, +35. Sold for a set of CCWs
__________________ '93 RX-7: 100% CARB approved. Just some wheels and stuff. ![]() '03.5 Mazdaspeed Protege: Custom clunk and turkey call. '12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat... |
![]() | | #28 | ![]() |
| The Following 21 Users Say Thank You to rfinkle2 For This Useful Post: | bo0okert (01-23-2014), chaser27 (01-23-2014), ckMS3 (12-27-2013), david001wj (02-06-2014), ge3kspd (05-07-2014), impossible (07-27-2014), J'sSpeed3 (12-29-2013), killer-ms3 (03-18-2014), lilred (12-27-2013), Mauro_Penguin (12-27-2013), MizzyMS3 (12-27-2013), msantana101 (12-27-2013), MZRSPEED (12-27-2013), Natey (12-27-2013), omgvance (12-27-2013), PapaSmurf (12-27-2013), rgz (02-03-2014), sadak (01-28-2014), Shayne-ms3 (12-28-2013), speed3 britz (12-27-2013), Thrizzl3 (12-27-2013) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score seems everyone is in love with the silver rpf's lol
| The Following User Says Thank You to Thrizzl3 For This Useful Post: | rfinkle2 (12-27-2013) |
![]() | | #30 | ![]() |
| The Following 13 Users Say Thank You to rfinkle2 For This Useful Post: | ckMS3 (12-27-2013), ge3kspd (05-07-2014), killer-ms3 (03-18-2014), lilred (12-27-2013), Mauro_Penguin (12-27-2013), Mazdazilla6 (12-28-2013), MZRSPEED (12-27-2013), Natey (12-27-2013), omgvance (12-27-2013), rymanmazda (12-27-2013), Shayne-ms3 (12-28-2013), sidekick (05-17-2014), Thrizzl3 (12-27-2013) |
![]() | | #31 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score Lol Rob, you get bored with the gram lights?
__________________ '08 CWP MS3 w/ T3 3071r |
| The Following User Says Thank You to 802MS3 For This Useful Post: | rfinkle2 (12-27-2013) |
![]() | | #32 | ![]() |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | jrotaryb (12-27-2013), Mauro_Penguin (12-27-2013) |
![]() | | #33 | ![]() |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score @rfinkle2; what wheel specs (width, offset) are you running on that sexy beast?
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
![]() | | #34 | ![]() |
Sent from my Nexus 5 using Tapatalk | |
| The Following 2 Users Say Thank You to Gibbo For This Useful Post: | Boost_creep (12-27-2013), Mauro_Penguin (12-28-2013) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score With my tires the koni and swift combo doesn't require a spacer.
| The Following User Says Thank You to xpystchrisx For This Useful Post: | Boost_creep (12-27-2013) |
![]() | | #36 | ![]() |
![]() Join Date: May 2012 Location: New Philadelphia, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,087
| Not Ranked : 0 score I'm surprised there isn't any ms6 photos yet
__________________ 2006 WWP Mazdaspeed 6 KILLAH BUILT 700+ AWHP TUNED BY NISHAN |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Lol nah I like my obnoxious neon green ones Wish granted Rest are attached so I don't blow up the page. 17x8 +45 (I love my curvy spokes), BFG G-Force KDW T/A KDW 2 225/45/17 Fits pretty good, just need my rear fenders rolled (they slowly eat away the sidewall on bumps if I have a lot of weight in the back of the car but that's mainly because of crappy springs), and requires a pretty large drop to look good. At stock height the car looks like an absolute joke. As for the color that's the factory color from Enkei.
| The Following 7 Users Say Thank You to Mazdazilla6 For This Useful Post: | bo0okert (01-23-2014), HawkeyeGeoff (02-18-2015), J'sSpeed3 (12-29-2013), Jh8909 (12-30-2013), jreiden1 (12-28-2013), Mauro_Penguin (12-28-2013), Thrizzl3 (12-28-2013) |
![]() | | #38 | ![]() |
![]() Join Date: Sep 2011 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 148
| Not Ranked : 0 score 18x9.5 38mm (5mm spacers up front) 245/35/18 hankook v12 |
| The Following 6 Users Say Thank You to Shayne-ms3 For This Useful Post: | FenixTX717 (01-29-2015), IMASA (12-28-2013), msantana101 (12-30-2013), sidekick (05-17-2014), SLOWHATCH (03-17-2014), Thrizzl3 (12-28-2013) |
![]() | | #39 | ![]() |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Mauro_Penguin (12-28-2013), Natey (12-29-2013) |
![]() | | #40 | ![]() |
| The Following User Says Thank You to BLKSTIG For This Useful Post: | Natey (12-29-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f432/club-rpf1-161428/ | ||||
| JBR FMIC Piping Installed - Page 3 - DFW Mazdas | This thread | Refback | 02-26-2015 04:39 PM | |
| More RPF1's | Doberman | Wheels & Tires - RED | 20 | 03-28-2014 10:52 AM |
| RPF1 vs C3 | jtt | 2010 MS3 - Wheels & Tires | 67 | 01-29-2013 05:34 PM |
| Video: Mustang Club of Poland inspires Mustang Club of Parana to make video | Haltech | Automotive News | 0 | 04-17-2012 06:00 PM |
| Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club | Haltech | Hot Deals Section | 0 | 04-16-2008 09:40 AM |
