![]() | | #601 | ![]() |
![]() Join Date: Jul 2014 Location: millersville, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score
I love the 255's, feel like i am on rails but i wanted the 40 series sidewall for looks plus less chance in my opinion for slop in sidewall. | |
![]() | | #602 | ![]() |
![]() Join Date: Sep 2012 Location: London Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 338
| Not Ranked : 0 score On flat roads it was fine, but cracked roads were really sketchy. I've got 275/35 NT01's that are going on shortly.
__________________ 07 Speed 3 Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01 Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4 |
![]() | | #603 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score What you are refering to is probably bump steer. That comes from lowering the car without correcting for steering rack angle in relation to the knuckles. You can fix that by installing washers between the steering rack and the subframe or purchasing the bump steer fix kit from whiteline. Torque steer happens when you accelerate and the front wheels want to wander in a direction other than straight. This gets worse the lower the offset you have.
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | brandon3212 (04-12-2017) |
![]() | | #604 | ![]() |
This is something I've been meaning to do for a while now but keep on forgetting. It also has a fair amount of torque steer, no getting around that though.
__________________ 07 Speed 3 Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01 Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4 Last edited by brandon3212; 04-12-2017 at 01:51 PM. | |
![]() | | #605 | ![]() |
![]() Join Date: Jul 2016 Location: Utah
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Alrighty heres the good photos of my setup love showing it off so...sorry for another post;D |
![]() | | #606 | ![]() |
![]() Join Date: Mar 2014 Location: Sedalia,MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
![]() | | #607 | ![]() |
![]() | | #608 | ![]() |
Gotcha! It looks really good the way it sits on the springs. But like another .5" and would be even better. I Have H&R springs on my speed and I plan on running the same size rpf1's so your photos helped a lot! Sent from my iPhone using Tapatalk | |
![]() | | #609 | ![]() |
![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() Thanks: 7
| Not Ranked : 0 score ![]() Sent from my iPhone using Tapatalk |
![]() | | #610 | ![]() |
![]() Join Date: Dec 2016
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score ![]() Totally stock, Drag wheels from Discount Tire and Pirelli P Zero 18's. At my age, getting into a lowered car would not be pretty at all, so I am leaving my suspension at stock MS3 GenPu height. When the Pirelli's wear out, I will go with a wider tire for more contact. What helped handling most from my perspective is the CS Stage 2 RMM and the CS rear anti-sway bar on the stiffest setting. It flattened out the suspension in curves at speed and eliminated much understeer. I can see myself going to Koni yellow's when I get the urge to do something to the car and my preaching money has built up enough to buy them (I am retired, and my wife and I agreed that the money I make as Guest Pastor on Sunday mornings at different Lutheran Churches could be my Mazdaspeed money. I not only married "up" but I married a saint who doesn't get the car thing but knows how much fun I have playing around with the Speed. Sent from my iPad using Tapatalk |
| The Following User Says NO Thank You to PadreDave For This Un-useful Post: | tegxsi (05-06-2017) |
![]() | | #611 | ![]() |
| Not Ranked : 0 score Can I join the club? Just got my rpf1's on! IMG_9950 by Dennis Makovskiy, on Flickr IMG_9939 by Dennis Makovskiy, on Flickr IMG_9931 by Dennis Makovskiy, on Flickr IMG_9935 by Dennis Makovskiy, on Flickr |
| The Following User Says Thank You to Dennisms3 For This Useful Post: | thrisnospork (08-29-2017) |
![]() | | #612 | ![]() |
![]() Join Date: Jan 2013 Location: NoVa
Rep Power: 0 ![]() Thanks: 18
__________________ 08 MS3 Sport: 96,xxx CP-E Stage 2 RMM. JBR PMM. JBR TMM. JBR SRI. JBR Short Shifter. JBR Shifter Bushings. JBR Short Shift Plate. JBR Reverse Lock-Out Gate Guide. JBR RSB. Sure ASG 621g Knob. Sonic Tuning Coilovers. SPC Rear Camber Arms. CS Mid Chassis Brace. CS Skid Plate. Enkei RPF1 17x9 +45. DDM 6000k HID. OEM MS3 GT LED Tail Lights. 2Nine Rear Diffuser. Custom AD Cardboard Front Diffuser. 98 Honda Civic LX: 256,xxx | |
![]() | | #613 | ![]() |
| Not Ranked : 0 score More Genjuan love! 235/45/17 hankook v12's, hopefully soon will be getting Michelin pilot super sports in 245/40/17
![]() | | #614 | ![]() |
![]() | | #615 | ![]() |
![]() Join Date: Sep 2017 Location: North County San Diego
| Not Ranked : 0 score Anybody else running 17x9+35 or 18x9+35 on a gen 2? If so would you still be able to run at least a 245/40 tire. I see a lot more people running the +45 offset. A lot with spacers if i am right wouldn't the +35 offset fix the issue of needing a spacer to clear the front coilover/give you peace of mind. |
![]() | | #616 | ![]() |
![]() Join Date: Aug 2008 Location: Birmingham, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
Yes but the wheel tire sticks outside the body line unless you roll and pull the fenders. Sent from my iPhone using Tapatalk ![]() Sent from my iPhone using Tapatalk
__________________ 2013 CWP Mazdaspeed 3 Last edited by SKiZZ; 05-13-2018 at 09:49 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #617 | ![]() |
![]() Join Date: Aug 2017 Location: North Carolina
| Not Ranked : 0 score Bump 17x9 +45 245/45/17 Stock suspension.. for now
__________________ 07 GT MS3 - TBD 06 SSL Evo 9 - 10.1 @ 149.9mph @Bmurray_evo9 |
![]() | | #618 | ![]() |
![]() Join Date: Jul 2012 Location: East TN
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I kind of hate to necro a thread, but it was very helpful to me and I wanted to thank everyone. 2010 completely stock, now sitting on 17x9 +45 RPF1 SBC and 255/40s. No spacer, but it is pretty tight (maybe an 1/8") to the strut. A major paving company left a hard ledge in the highway during resurfacing and bent three of my factory wheels. Had the tire store write up a quote using OEM wheels from the Mazda dealer and got this whole set including tires plus some leftover from their insurance company. No plans on modding the car at all, but I have always liked RPF1s. Thanks again! |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f432/club-rpf1-161428/ | ||||
| JBR FMIC Piping Installed - Page 3 - DFW Mazdas | This thread | Refback | 02-26-2015 04:39 PM | |
| More RPF1's | Doberman | Wheels & Tires - RED | 20 | 03-28-2014 10:52 AM |
| RPF1 vs C3 | jtt | 2010 MS3 - Wheels & Tires | 67 | 01-29-2013 05:34 PM |
| Video: Mustang Club of Poland inspires Mustang Club of Parana to make video | Haltech | Automotive News | 0 | 04-17-2012 06:00 PM |
| Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club | Haltech | Hot Deals Section | 0 | 04-16-2008 09:40 AM |
