![]() | | #41 | ![]() |
![]() Join Date: Mar 2012 Location: Greensboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,087
__________________ 2008 True Red Juan | Fully Bolted > Stocked out > Traded Partnered with DeftMotion deftmotion.com 2013 Mica Black Pu Performance CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune Suspension Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines Ricer Shit Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP |
| The Following 4 Users Say Thank You to omgvance For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
| Not Ranked : 0 score
__________________ when was the last time your speed reeled in this many bitches? ![]() ![]() |
| The Following 3 Users Say Thank You to Manny For This Useful Post: |
![]() | | #43 | ![]() |
![]() Join Date: Feb 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
| Not Ranked : 0 score ^^^yes more gold!!!! Sent from my iPad using Tapatalk
__________________ 2007 Black Mica MS3 - CP-e Nano SRI, CP-e TIH, CP-e HPFP, CP-e catted DP, CP-e RMM 75A, Saikou Michi oil catch can, TRZ TMM, JBR RSB, JBR PMM 80A, Mspeed Stuff, Cobb AP, Cobb XLE BPV, Cobb FMIC V2, Gold 17x9 Enkei RPF1, Hankook RS-3 255/40/17, DBA 4000 slotted rotors, Motul RBF600 brake fluid, Rotella T6 Engine oil, Prosport Boost/Oil temp/Pressure gauges, Other Assorted Rice... |
| The Following User Says Thank You to Thrizzl3 For This Useful Post: | omgvance (12-31-2013) |
![]() | | #44 | ![]() |
![]() Join Date: May 2013 Location: Bay Area, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| The Following 10 Users Say Thank You to aznvng For This Useful Post: | 1987 (02-05-2014), 802MS3 (01-16-2014), BloodySpeed3 (04-04-2014), castrocastro (02-06-2014), Mauro_Penguin (01-16-2014), omgvance (01-22-2014), PapaSmurf (01-16-2014), sadak (01-28-2014), Thrizzl3 (01-16-2014), YABBAMZR (01-16-2014) |
![]() | | #45 | ![]() |
![]() Join Date: Jun 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score 18s sure do look good. |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score Looks like you are lowered. Any issues with fitment or rubbing? What's the specs if you don't posting them?
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
![]() | | #47 | ![]() |
| Not Ranked : 0 score I'm running the stock dunlop 225/40, front is -1.5 and rear is at 0 currently. I will need to add about a degree of negative camber for the rear to match with the front since only the rear rubs over big bumps and dips. It also may help if I reset the preload. I'm also planning to get 245/35/18 tires next for more tread and it may allow me to go a little bit lower. |
![]() | | #48 | ![]() |
The car looks bitchin'!
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle | |
| The Following User Says Thank You to manila For This Useful Post: | aznvng (01-23-2014) |
![]() | | #49 | ![]() |
![]() Join Date: Jul 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
__________________ 2006 Speed6 Instagram @bdawgington FHRITP ![]() |
![]() | | #50 | ![]() |
![]() | | #51 | ![]() |
![]() Join Date: Nov 2013 Location: New York
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score anyone know if 5mm is enough for a 17x9 +45 setup with KWs / Mazdaspeed coils to clear? or is the 10mm needed.. deciding if i can get away with +45 otherwise ill just get a +35 setup |
![]() | | #52 | ![]() |
| Not Ranked : 0 score I did 10mm just to be on the safe side.
![]() | | #53 | ![]() |
![]() Join Date: Nov 2012 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
__________________ Mods: The usual Power: E85 ko4 Suspension: Corksport Springs |
![]() | | #54 | ![]() |
![]() Join Date: Apr 2012 Location: Pax River, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 613
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score The more I look at this thread, the more I want to pick up a set. For those of you with the 17x9 setup, where did you buy your wheels from?
__________________ 09 CWP MS3 GT3071R TUNED BY NISHAN |
![]() | | #55 | ![]() |
| Not Ranked : 0 score I was going to get mine off of tire rack but found them used locally, the 17x9 +45 size is pretty hard to come by. It took me 6 months to hunt down a set on craigslist.
![]() | | #56 | ![]() |
| Not Ranked : 0 score Yea I just checked on tire rack and they didn't even have the 17x9 option. There are some on ebay, but I'd rather stay away from buying there to avoid fake replicas
![]() | | #57 | ![]() |
| Not Ranked : 0 score If you use the option of searching by make/model then search for rx8's versus mazdaspeed 3.
| The Following 3 Users Say Thank You to shpeedtree For This Useful Post: |
![]() | | #58 | ![]() |
![]() Join Date: Apr 2010 Location: Oakton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 521
Groans: 39
| Not Ranked : 0 score I need to wash the salt off my car and post pics of mine lol. Slapped on some Sonic Tuning Coils and a MZ replica lip for the regular 3.... + 15mm spacers up front and 10mm in the rear.
__________________ 2010 Liquid Silver MS3 // BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray // // JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers // // 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's // |
![]() | | #59 | ![]() |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
| The Following 11 Users Say Thank You to Downmented For This Useful Post: | 1987 (02-07-2014), 802MS3 (03-17-2014), BloodySpeed3 (04-04-2014), J'sSpeed3 (04-30-2014), Mauro_Penguin (02-05-2014), Mazdaspeed3KHP (02-18-2014), Mazdazilla6 (02-05-2014), nrankin01 (04-04-2014), shpeedtree (02-04-2014), Status Update (02-05-2014), T2J (02-04-2014) |
![]() | | #60 | ![]() |
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score Call them up and get a quote from them! That's what I did on my Enkei Raijin's. If you look under tireracks set of wheels for the MS6 the Raijins don't come up but on Enkei's website it showed the right size. It's all about researching what you want.
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
| The Following User Says Thank You to rymanmazda For This Useful Post: | T2J (02-04-2014) |
![]() | | #61 | ![]() |
| Banned ![]() Join Date: Jan 2014
Groaned at 51 Times in 12 Posts
![]() | | #62 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score Do you have any pics?? looking to get the same set up
__________________ 2010 MS3 stock K04 COBB SRI, TIP,AP self tuned 21psi taper to 19, 20° @redline NGK 1 step colder plugs, AT internals and Cp-e catted downpipe, Magnaflow CBE, AEM WMI 50/50 mix, Shitty Shell 91 oct 1.5 gal in tank meth. |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2011 Location: Gillette, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 782
Groans: 64
Groaned at 18 Times in 6 Posts
| Not Ranked : 0 score One per post because iphail
__________________ COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS |
![]() | | #64 | ![]() |
Groans: 64
![]() | | #65 | ![]() |
![]() Join Date: Nov 2010 Location: SoCal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 3 Posts
| Not Ranked : 0 score Got mine coming next week, will post pics. I hope everything fits alright with stock suspension |
![]() | | #66 | ![]() |
| Not Ranked : 0 score Here is my contribution! |
![]() | | #67 | ![]() |
![]() Join Date: Feb 2013 Location: Green Bay, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 945
__________________ 2013 CWP Mazdaspeed3 - SOLD 2014 Mitsubishi Evo X - time for some fun. |
| The Following 2 Users Say Thank You to anodizedeeznutz For This Useful Post: | Mauro_Penguin (02-17-2014), msantana101 (02-18-2014) |
![]() | | #68 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score Mmmmmm too much silver.
__________________ 2012 Black Mica Speed 3 300whp-341wtq tuned by John @ Tork Motorsports (2/4/14) Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC |
| The Following 4 Users Say Thank You to Mazdaspeed3KHP For This Useful Post: |
![]() | | #69 | ![]() |
![]() Join Date: Dec 2012 Location: Milwaukee Wisconsin
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
__________________ 2007 MS3 | Cobb AP | JBR 80 RMM | HTP 3" Intake | CNT Turboback | Forge V2 | NGK Plugs | KMD Internals | CPE TMIC | FreekTune | JBR RSB 2009 Ninja 650R | |
| The Following User Says Thank You to Opdahl For This Useful Post: | anodizedeeznutz (02-19-2014) |
![]() | | #70 | ![]() |
![]() Join Date: Feb 2014 Location: Santa Barbara, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
![]() | | #71 | ![]() |
__________________ 2013 Mazdaspeed 3 - stock as fuck |
| The Following User Says Thank You to aznvng For This Useful Post: | Jankster (02-25-2014) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score ^thanks! That looks awesome |
![]() | | #73 | ![]() |
![]() Join Date: May 2011 Location: Bowie, MD
| Not Ranked : 0 score 17x8.5 +35(+40 with 5mm spacer all around) 235/40/17 potenza RE11
__________________ Current: 2007 s2000 ap2 RIP 2008 genwon turboxs fmic / turboxs catless dp&rp / hks catback / HTP 3.5" intake / ATP GTX3071r ewg / tial QR bpv / cpe hpfp / cp-e 75 duro motor mounts / cp-e safeseals / stoptech slotted & vented rotors & stoptech pads / BC Coilovers / RPF1s 18x8.5 +40 / BoostJunkyz stock location turbo manifold / killah built bitch bwah |
| The Following User Says Thank You to Modality14 For This Useful Post: | Mauro_Penguin (02-26-2014) |
![]() | | #74 | ![]() |
![]() Join Date: Mar 2012 Location: Medina, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 604
| Not Ranked : 0 score A 5mm spacer make you have a +30 offset Also I may be picking up a set of black 17x9 +45 rpf1's and I was wondering what you guys think about powder coating them? I have pc'ing a cast or aluminum wheel is dangerous. I know @PapaSmurf; pc'd his but I don't want to compromise the structural integrity of an awesome strong reliable wheel. But I love the bright color of my current track setup.
__________________ 2008.5 Mazdaspeed 3 BM - Built BT Realgib3 Tuned 2014 Mz3 MG |
![]() | | #75 | ![]() |
![]() Join Date: Sep 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
__________________ SOLD 2008 MS3 17x8 Evo 9's, 235 v12 1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat 2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD | |
| The Following User Says Thank You to Tyhackman15 For This Useful Post: | pmartz16 (03-17-2014) |
![]() | | #76 | ![]() |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score 17x9 +45 5mm spacer up front. Swift springs and stock shocks, spc rear camber arms.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
| The Following User Says Thank You to twenty5psi For This Useful Post: | T2J (03-18-2014) |
![]() | | #77 | ![]() |
I really dont think its that big of a deal.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
![]() | | #78 | ![]() |
| Not Ranked : 0 score Lookin good! Tire specs?
| The Following User Says Thank You to T2J For This Useful Post: | twenty5psi (03-18-2014) |
![]() | | #79 | ![]() |
| Not Ranked : 0 score 255-40-17 Conti DW
![]() | | #80 | ![]() |
![]() Join Date: Jul 2012 Location: Rochester, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 487
__________________ 2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo) Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45 Freektuned- E85 4/8gal mix |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f432/club-rpf1-161428/ | ||||
| JBR FMIC Piping Installed - Page 3 - DFW Mazdas | This thread | Refback | 02-26-2015 04:39 PM | |
| More RPF1's | Doberman | Wheels & Tires - RED | 20 | 03-28-2014 10:52 AM |
| RPF1 vs C3 | jtt | 2010 MS3 - Wheels & Tires | 67 | 01-29-2013 05:34 PM |
| Video: Mustang Club of Poland inspires Mustang Club of Parana to make video | Haltech | Automotive News | 0 | 04-17-2012 06:00 PM |
| Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club | Haltech | Hot Deals Section | 0 | 04-16-2008 09:40 AM |
