> 2010 MS3 - Wheels & Tires
Like Tree124Likes
 Old 03-18-2014, 11:46 AM   #81
twenty5psi's Avatar
Posts: 213   (View Stats)
Originally Posted by white'swhiteMPS View Post
roll in the rear?
Nope seems fine, I have some sway bar noise that I need to take care of but I don't have any rubbing issues. Had it aligned as soon as I got it back on the ground, the 255/40/17 basically gives you a stock diameter wheel and tire and the Swifts are a fairly mild drop as you know.
2013 MS3 VRM w/Tech
 Old 03-18-2014, 11:56 AM   #82
white'swhiteMPS's Avatar
Posts: 639   (View Stats)
white'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the worldwhite'swhiteMPS is the leader of the world
Originally Posted by twenty5psi View Post
Nope seems fine, I have some sway bar noise that I need to take car of but don't have any rubbing issues. Had it aligned as soon as I got it back on the ground, the 255/40/17 basically gives you a stock diameter wheel and tire and the Swifts are a fairly mild drop as you know.
@MazdaBoy2.3;
2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo)
Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45
Freektuned- E85 4/8gal mix
white'swhiteMPS is offline   Reply With Quote
 Old 03-18-2014, 12:25 PM   #83
T2J
T2J's Avatar
Posts: 348   (View Stats)
T2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the worldT2J is the leader of the world
Groaned at 3 Times in 1 Post
255-40-17 Conti DW
Nice. I'm still trying to figure out if i want to go with 245 or 255's
09 CWP MS3
GT3071R
TUNED BY NISHAN
T2J is offline   Reply With Quote
 Old 03-23-2014, 10:34 PM   #84
Modality14's Avatar
Posts: 140   (View Stats)
Modality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond reputeModality14 has a reputation beyond repute
Originally Posted by pmartz16 View Post
A 5mm spacer make you have a +30 offset
Also I may be picking up a set of black 17x9 +45 rpf1's and I was wondering what you guys think about powder coating them? I have pc'ing a cast or aluminum wheel is dangerous. I know @PapaSmurf; pc'd his but I don't want to compromise the structural integrity of an awesome strong reliable wheel. But I love the bright color of my current track setup.
Wrong..it's +40 with 5mm spacers = +35 offset..
Current: 2007 s2000 ap2
RIP 2008 genwon
turboxs fmic / turboxs catless dp&rp / hks catback / HTP 3.5" intake / ATP GTX3071r ewg / tial QR bpv / cpe hpfp / cp-e 75 duro motor mounts / cp-e safeseals / stoptech slotted & vented rotors & stoptech pads / BC Coilovers / RPF1s 18x8.5 +40 / BoostJunkyz stock location turbo manifold / killah built bitch bwah
Modality14 is offline   Reply With Quote
 Old 03-24-2014, 12:40 PM   #85
pmartz16's Avatar
Posts: 1,140   (View Stats)
Ahh sorry I read your post wrong we said the same thing
2014 Mz3 MG
 Old 04-01-2014, 08:41 PM   #86
shpeedtree's Avatar
Posts: 52   (View Stats)
shpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud of
Put mine on finally.
Mods: The usual
Power: E85 ko4
Suspension: Corksport Springs
shpeedtree is offline   Reply With Quote
The Following User Says Thank You to shpeedtree For This Useful Post:
Mauro_Penguin (04-01-2014)
 Old 04-01-2014, 10:14 PM   #87
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
4x4 mode. Swifts arrive on Friday.
Tapatalkin'
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
The Following User Says Thank You to anodizedeeznutz For This Useful Post:
Mauro_Penguin (04-02-2014)
 Old 04-03-2014, 07:17 PM   #88
ThatGuy's Avatar
Posts: 153   (View Stats)
ThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond reputeThatGuy has a reputation beyond repute
Happy to join the club! No pumkin faces here. 17x9
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
ThatGuy is offline   Reply With Quote
The Following 3 Users Say Thank You to ThatGuy For This Useful Post:
FenixTX717 (01-29-2015), jamesr242 (04-27-2014), RusianKid (10-11-2014)
 Old 04-04-2014, 02:15 PM   #89
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
700HP CLUB
11.479@124mph
#DIX
The Following 7 Users Say Thank You to Downmented For This Useful Post:
1987 (04-05-2014), 7mileshome (04-05-2014), J'sSpeed3 (04-30-2014), Mauro_Penguin (04-05-2014), Mazdazilla6 (05-03-2014), PapaSmurf (04-06-2014), sidekick (05-17-2014)
 Old 04-05-2014, 03:41 PM   #90
On Swifts. Much better.
Tapatalkin'
 Old 04-05-2014, 03:42 PM   #91
ThatGuy's Avatar
Originally Posted by EvanSpeed3 View Post
Attachment 154382
Tapatalkin'
What size are those 17x8?
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
 Old 04-05-2014, 03:56 PM   #92
mrtheandrew's Avatar
Posts: 468   (View Stats)
17x8 +45 with 235/45 extremecontact DW. no roll or pull. only rubbing is on the fender/bumper flange when fully loaded. a little dremeling will solve that.
not the best pics, but these are the only ones i have available right now.
2007 True Red MS3
Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3
The Following 2 Users Say Thank You to mrtheandrew For This Useful Post:
FenixTX717 (01-29-2015), J'sSpeed3 (04-30-2014)
 Old 04-05-2014, 03:59 PM   #93
ThatGuy's Avatar
The faces on 17x8 vs 17x9 are crazy different look. 9's sink in 8's stick out
My 17x9 with 245/45 had no issue up front but I'm using 5mm spacer maybe that helps.
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
The Following User Says Thank You to ThatGuy For This Useful Post:
 Old 04-05-2014, 04:01 PM   #94
17x8.5 +40 offset
Tapatalkin'
 Old 04-05-2014, 04:06 PM   #95
i personally think the 17x9" looks overall better than the 17x8" for sure. i went with the 8" because i liked the way they fit the vehicle better and line up with the fender rather than stick out. they are also a shade lighter (not by anything you'd probably notice) and i didn't want to deal with the fender work to squeeze a 9" in there without the rubbing issues. i would love to have an 8" rim with the face of the 9".
2007 True Red MS3
 Old 04-05-2014, 04:09 PM   #96
ThatGuy's Avatar
I tracked mine last weekend with no rubbing issues at all no fender roll nothing. They don't stick out there flush besides front a tad with 5mm. I'm on H&R spring. If they don't rub at the track they'll never rub unless I go lower.
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
freakspeed (05-07-2014)
 Old 04-05-2014, 04:16 PM   #97
maybe the pu is different? i'd have some bad rubbing issues in the rear if my tire was 1/2" further out, if i'm doing my math right. i definitely like the way your setup looks, though.
2007 True Red MS3
 Old 04-06-2014, 05:24 PM   #98
anyone else running 255/40/17 on a gen 2 without a roll?
 Old 04-06-2014, 05:26 PM   #99
ThatGuy's Avatar
255/40 will be about same height depending on brand as 245/45. I might try 255 next time but 245 are plenty of meat.
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
 Old 04-06-2014, 05:32 PM   #100
is that what youre on? 245/45? any roll?
 Old 04-06-2014, 05:33 PM   #101
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
oldie but goodie
Mauro_Penguin likes this.
860whp/677wtq
2.7 V6 Ecoboost
impossible (07-27-2014), Mauro_Penguin (04-08-2014)
 Old 04-06-2014, 05:55 PM   #102
ThatGuy's Avatar
No roll. Could use one it's in case but I tracked it and didn't rub so I can't see it ever rubbing on street
-'13 Pearl White
-CS Turbo inlet/SRI
-CS RMM
-COBB AP
-Autotech Internals
-H&R Springs
-JRB RSB
The Following 2 Users Say Thank You to ThatGuy For This Useful Post:
freakspeed (05-07-2014), white'swhiteMPS (04-06-2014)
 Old 04-08-2014, 12:23 PM   #103
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Originally Posted by ash4390 View Post
Genpu forum but I like whoring out my setup.
18x9.5 +38mm (5mm spacer up front to clear my BBK), 245/35/18 Federal RS-R's which run more like 265 then anything...
Originally Posted by Shayne-ms3 View Post
18x9.5 38mm (5mm spacers up front) 245/35/18 hankook v12
I can't decide between 17x9.5 or 18x9.5 wrapped in 245/35s I want that meaty look but the 18s just don't quite sit low enough granted I have a less wheel gap then them. IDk???!!! what to do!
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
The Following 2 Users Say Thank You to 7th Initial For This Useful Post:
Status Update (04-08-2014), white'swhiteMPS (04-15-2014)
 Old 04-15-2014, 08:44 AM   #104
shpeedtree's Avatar
Mods: The usual
Power: E85 ko4
 Old 04-15-2014, 09:55 AM   #105
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
here's mine
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 04-18-2014, 12:24 PM   #106
about to place my order,
going with rpf1 17x9 +45
question is, do I go with 245/45's or 245/40's? lowered on swift springs
The Following User Says Thank You to white'swhiteMPS For This Useful Post:
Mrzoomzoom (10-19-2014)
 Old 04-18-2014, 12:29 PM   #107
omgvance's Avatar
Posts: 1,221   (View Stats)
omgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the worldomgvance is the leader of the world
245/45 for sure
2008 True Red Juan | Fully Bolted > Stocked out > Traded
Partnered with DeftMotion
deftmotion.com
2013 Mica Black Pu
Performance
CS SRI | CS TIP | Autotechs | Cobb AP V3 | NGK IX | C/R/M Delete | 3 Bar | JBR 3 Port | FMIC | FreekTune
Suspension
Eibach Springs | Exo X Wheels | Michelin PSS | DBA T2 | Hawk HP+ | Goodrich Lines
Ricer Shit
Bayson R Front Lip | Bayson R Side Skirt Extensions | Kensun 6k HID | 35% Tint | Pro sport Boost Gauge | Techno Tuning SN | JBR Boost Tubes | Sure Anchors | SSP
omgvance is offline   Reply With Quote
 Old 04-18-2014, 01:12 PM   #108
Frnchplayr15's Avatar
Posts: 215   (View Stats)
Frnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the worldFrnchplayr15 is the leader of the world
Groaned at 6 Times in 4 Posts
I know I posted pics before but gotta join this club 17x9 +45 255/40 8mm spacers in the front rolled in the rear and awaiting Camber Arms.
2013 Mazdaspeed 3 Tech pack
M2 Performance Catless Long Downpipe // UR CBE // All bulb's are V-LED's // RA Mudflaps // STI 06-07 Chargespeed Lip // Rear LED Reflectors // Autotech Internals // COBB Accessport v3 // JBR OCC Stage 2 // JBR SSP Kit // JBR SSB // JBR Stage 2 Intake // JBR TIP // CP-E RMM // SPC Camber Arms // Forge BPV v2 // Hella Supertones // BC Coilovers // CS RSB // NGK IX Iridium 1SC Plugs // RPF1's 17x9 +45 // BFG Super Sport Comp 2 255/40/17
2010 Mazda 3 iSport- SOLD
Frnchplayr15 is offline   Reply With Quote
The Following 6 Users Say Thank You to Frnchplayr15 For This Useful Post:
AshFromCan (07-25-2014), bstover17 (04-18-2014), FenixTX717 (01-29-2015), I am a banana (05-25-2014), mrtheandrew (04-18-2014), T2J (04-24-2014)
 Old 04-18-2014, 07:22 PM   #109
Wheres did everyone buy their RPF1's from?
 Old 04-18-2014, 07:26 PM   #110
I had the best deal from a store in Cali I'll have to go back and find the name
 Old 04-18-2014, 09:35 PM   #111
Gibbo's Avatar
Posts: 156   (View Stats)
Gibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the worldGibbo is the leader of the world
I had 245/40/17 were fine. Better acceleration too :p
Gibbo is offline   Reply With Quote
 Old 04-24-2014, 04:19 PM   #112
Thanks to Kyle Cross aka @burn813; for taking this killer pic of my car with rpf1's. Below, some rpf1's about to go on @DookieMuncher; s car this weekend. LOL
XjCrazy09 and paulongpin like this.
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
1987 (07-04-2014), burn813 (04-24-2014), CrawlingMS3 (09-28-2014), Frnchplayr15 (05-06-2014), itzjustme407 (04-25-2014), J'sSpeed3 (04-30-2014), Koke382 (04-24-2014), rymanmazda (04-24-2014), Status Update (04-24-2014), Voltron (04-25-2014)
 Old 04-24-2014, 04:48 PM   #113
Koke382's Avatar
Posts: 4,361   (View Stats)
That looks sexy rob. I need to do something with my wheels asap lol
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
rfinkle2 (04-24-2014)
 Old 05-06-2014, 07:34 AM   #114
freakspeed's Avatar
Posts: 4   (View Stats)
freakspeed has a little shameless behaviour in the past
From what I've read, it seems some guys have had to roll their fenders and some others haven't on that genpu 17x9 RFP1 setup...
I'm going for 17x9 RFP1s wrapped in 255/40 Nitto NT05's. Lowered on Swifts Spec R with JBR camber arms in the rear. I do not plan on rolling rear fenders at first, will see how it fits and post pictures when it's all done. Going for the gold/VRM combo. Can't wait to have these on!
freakspeed is offline   Reply With Quote
 Old 05-06-2014, 04:24 PM   #115
covelife1016's Avatar
Posts: 151   (View Stats)
covelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond reputecovelife1016 has a reputation beyond repute
Are you running adjustable camber arms? If so what kind of camber are you running in the rear?
2010 MS3 non tech
// CS TMIC// CS battery box// JBR short shifter// JBR 88a rmm// JBR boost tubes// JBR solid shifter bushings// JBR coolant bypass and throttle body tig// Kozmic Motorsports primary and secondary egr delete// NGK one step colder plugs// AT fuel pump internals// HTP 3" intake// GFB bov// COBB accessport V2 // GroundControl springs// Koni yellows//
TUNED BY STRATIFIED
covelife1016 is offline   Reply With Quote
 Old 05-06-2014, 05:02 PM   #116
starscream's Avatar
Posts: 630   (View Stats)
Groans: 44
Just gonna leave this here...(RPF1 in 255/40/17 NT05s...in a gold/VRM combo)...
rfinkle2 and freakspeed like this.
The Following 4 Users Say Thank You to starscream For This Useful Post:
CWP_MS3 (07-11-2014), freakspeed (05-07-2014), Frnchplayr15 (05-06-2014), rfinkle2 (05-06-2014)
 Old 05-06-2014, 05:07 PM   #117
FYI when I installed my setup even with 5mm spacers in the front I still didnt clear my coilovers so I changed it to 8mm spacers to clear. It also depends on tires since some are wider than others. My rears I had to roll since I was constantly rubbing. The guy said he didnt want to roll and pull my fenders since pulling causes dimpling. But with some camber arms and you'll be set.
The Following User Says Thank You to Frnchplayr15 For This Useful Post:
 Old 05-06-2014, 05:26 PM   #118
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Where did you get center caps for yours?
timmcc02 is offline   Reply With Quote
 Old 05-07-2014, 12:34 AM   #119
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
Round 2.
msantana101 likes this.
2012 Black Mica Speed 3
300whp-341wtq tuned by John @ Tork Motorsports (2/4/14)
Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC
Mazdaspeed3KHP is offline   Reply With Quote
The Following User Says Thank You to Mazdaspeed3KHP For This Useful Post:
msantana101 (09-13-2014)
 Old 05-07-2014, 08:24 AM   #120
freakspeed's Avatar
@starscream;
Thanks man! Your car and pictures are sick! I absolutely love the gold/red combo, had it on my previous car with Varrstoen's, however it didn't compete with the VRM and Enkei gold together. Yours is just soooo beautiful and inspiring!
How do you like the NT05's so far?
2013 mazdaspeed 3 - Stage 2 E85 e-tuning in process
The Following User Says NO Thank You to freakspeed For This Un-useful Post:
Noodlesincup (05-25-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f432/club-rpf1-161428/
JBR FMIC Piping Installed - Page 3 - DFW Mazdas This thread Refback 02-26-2015 04:39 PM
More RPF1's Doberman Wheels & Tires - RED 20 03-28-2014 10:52 AM
RPF1 vs C3 jtt 2010 MS3 - Wheels & Tires 67 01-29-2013 05:34 PM
Video: Mustang Club of Poland inspires Mustang Club of Parana to make video Haltech Automotive News 0 04-17-2012 06:00 PM
Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club Haltech Hot Deals Section 0 04-16-2008 09:40 AM
Page generated in 0.58378 seconds with 43 queries
