> 2010 MS3 - Wheels & Tires
 Old 05-13-2018, 10:36 AM   #1
spedster's Avatar
Posts: 54   (View Stats)
spedster will become famous soon enoughspedster will become famous soon enough
Default DWS 06 tire size for gen2 DD
Im in the northeast and need some new all season tires for my 2010 MS3. I've decided on DWS 06 based on all the good things people on here have said about them.
My current tires are 225/40 which I believe are stock. Is there any reason to consider a different size for my new tires? My car is basically stock.
spedster is offline   Reply With Quote
 Old 05-13-2018, 02:38 PM   #2
Tifosi42's Avatar
Posts: 179   (View Stats)
Nope
BNR S3 - FREEKTUNED on E33
The Following User Says Thank You to Tifosi42 For This Useful Post:
spedster (05-14-2018)
 Old 05-15-2018, 08:23 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
have these tires. In this (correct) size. They're fine.
Blue Pu.
spedster (05-15-2018)
 Old 05-15-2018, 03:04 PM   #4
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Good tires/size, though I wonder if you'd be better served with a set of dedicated winter tires and another set for summer weather...that is what I do and love the traction I get on studless snows vs the previous all seasons
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
What tire size? Rkrise216 MazdaSpeed 3/6 - Wheels & Tires 2 03-17-2013 04:48 PM
Help with tire size! Krylos225 MazdaSpeed 3/6 - Suspension & Brakes 2 10-09-2012 05:58 PM
Need quick advise on tire size and rim size setup sensui MazdaSpeed 3/6 - Wheels & Tires 1 03-18-2011 12:10 PM
What tire size should I go for? chriscarron MazdaSpeed 3/6 - Wheels & Tires 17 01-24-2011 06:15 PM
Tire size?? MKTMS3 2010 MS3 - Wheels & Tires 7 01-11-2011 05:40 PM
Page generated in 0.23918 seconds with 23 queries
