> 2010 MS3 - Wheels & Tires
Like Tree5Likes
 Old 07-10-2011, 06:23 PM   #1
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Default Enkei RPF1 17" vs 18" for speed3
I have a 2011 speed3. I am debating wheel choices. I have always like the rpf1 for the weight and I like the style. Currently my car sits on the stock 18" mazda rims. If I decide to go with the rpf1 is there any benefit to switching to a 17x8" rim (15.5lbs) or should I stick with a 18x8" rim (17.8lbs)? The main difference is weight between the two...but I am unsure if it will negatively effect my handling downsizing to 17". Also would a 35mm offset or 45mm be ideal? I plan on running no larger than a 225 or 235 tire. Any input and advice is appreciated.
Regards,
Michael
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 07-10-2011, 06:28 PM   #2
2011speed's Avatar
Posts: 1,497   (View Stats)
stick with 18's. 17 inch rpf1 belong on an 8th gen civic.
FreeKtuned
fitty fitty
The Following 2 Users Say Thank You to 2011speed For This Useful Post:
Roddiy (03-06-2012), tragik (07-11-2011)
The Following User Says NO Thank You to 2011speed For This Un-useful Post:
Dre (07-10-2011)
 Old 07-10-2011, 06:33 PM   #3
mrmonk7663's Avatar
10-4. The stock rims weigh in at 21lbs or 23lbs? Also any reccomendations on a tire for an 18x8....225 x ? or 235 x ? Finally offset...35mm or 45mm
 Old 07-10-2011, 06:37 PM   #4
2011speed's Avatar
since ur stock ride height, id do 235. however im not sure about the offset since i do not know what kind of look ur going for.
FreeKtuned
fitty fitty
 Old 07-10-2011, 06:50 PM   #5
mrmonk7663's Avatar
Currently I am stock height. In the future the H&R springs are a possibility, but that would be the only spring I would consider. I think it drops it 1.2 and 1.3 or vis versa. As far as the look goes....I am trying to stay away from having to roll fenders...so whatever achieves that is what i'm looking for.
Thanks.
 Old 07-10-2011, 06:55 PM   #6
2011speed's Avatar
personally i would rock 18x8 with 45 offset. i've seen it on a gen 2 before and looks damn good.
(i belive couple members on here have that setup as well so search)
FreeKtuned
fitty fitty
 Old 07-10-2011, 07:01 PM   #7
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
For a street car, yes stick with 18's. But if you wanna track it the weight savings and larger selection of race tires makes the 17's a good idea.
BLK_MS3 is offline   Reply With Quote
 Old 07-10-2011, 07:03 PM   #8
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
only benefit 18's yield are looks (subjective). Go with 17's if you want improved performance, cheaper tires, and generally better grip due to wider tires w/ smaller wheel size.
The Following 6 Users Say Thank You to dizzydtrain For This Useful Post:
helmetface (04-25-2012), J'sSpeed3 (04-29-2014), myt_tuf1 (07-10-2011), Pseud0logik (06-05-2012), rigor (04-01-2012), sadak (10-29-2013)
 Old 07-10-2011, 07:06 PM   #9
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
stock wheels weigh 25.x lbs.. if you go 17's go 17x9 and throw some meaty tires on there.. use this to figure out what offset and size wheel you need to run if you do go 17s..
Tire and Wheel Calculator
i personally think 17 rpf1's with some meaty tires would look mean as fuck on a black, lowered gen2
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
 Old 07-10-2011, 07:39 PM   #10
Groans: 64
Here you go:
http://www.mazdaspeedforum.org/forum/foru...-speed3-82062/
Matte Black Enkei rpf1 17x9 +45
The Following 2 Users Say Thank You to dizzydtrain For This Useful Post:
JS + MS3 (07-11-2011), myt_tuf1 (07-10-2011)
 Old 07-10-2011, 08:01 PM   #11
mrmonk7663's Avatar
Damn, thanks for all the responses guys. The gears are turning now going 17s is looking more appeasing. The weight savings would be amazing...damn near 40lbs.
The Following User Says Thank You to mrmonk7663 For This Useful Post:
 Old 07-10-2011, 08:11 PM   #12
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
This sums up the 17" rpf1's and tires I have (full specs in sig):
-I've got a lot more traction.
-These tires are rated to last longer than the stockers.
-I'm saving ~$200 buying 17" tires over 18" tires.
-I'm not carrying a dead ~40lb baby around with me everywhere I go anymore.
-I think it performs and looks a lot better than it used to.
-The ride is also a lot more comfortable due to the taller tire.
That's justified in my eyes.
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
 Old 07-10-2011, 08:37 PM   #13
mrmonk7663's Avatar
Ok, looking at the offset calculator...
A stock wheel is 18x7 with a 52.5mm offset
A 17x9 with a 45mm offset moves the wheel 18mm closer to the strut and extends it 32mm out farther than stock. OP wanted to use spacers for extra clearance.
A 17x8 on the other hand with a 45mm offset only moves the wheel 6mm closer to the strut, yet still extends it 20mm (3/4")
Based on this, the 17x8 should fill up most of the fender gap AND NOT require any spacers. If my calculations are incorrect please let me know, but for now 17x8 seems like a solid choice at 15.6lbs per wheel and NO spacers necessary.
 Old 07-10-2011, 09:00 PM   #14
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
go with 17x8.5. I run 18x8.5 on a genwon with 235s... you can easily fit an 8.5 on a genpoo.
super_pablo_ is offline   Reply With Quote
 Old 07-11-2011, 01:26 AM   #15
myt_tuf1's Avatar
You can easily fit a 17x9... That's what I have, flush as can be, no spacers required, no rub, and no roll on H&R's (but my Koni's are set at their stiffest, I'm not sure if it would rub if they weren't).
 Old 07-11-2011, 04:50 AM   #16
Dre
Dre's Avatar
Groans: 48
40lbs of unsprung weight is the equivalent of roughly (**BE ADVISED! RICER MATH ONGOING IN THIS POST**) 320lbs of sprung weight for our cars i believe.. I cant find it now, but i've asked before and the number (for our cars) was around 1lb of unsprung = 8lbs of sprung..
-TTT
The Following User Says Thank You to Dre For This Useful Post:
Jeremy M (03-11-2012)
 Old 07-11-2011, 05:44 AM   #17
mrmonk7663's Avatar
The only reason I am not wanting 17x9 is because I don't want to take the chance of rubbing (stock struts/springs) and also because I never see myself needing more than a 245 tire on this car. It will be my daily driver. I will mod it with bolt ons, but nothing extreme. A 245 on a 17x8 should suffice....and for the first set of tires I anticipate a good 225 or 235 tire anyway. myt tuf1...your wheels look great though, I love them!!!
Changing the rims to the proposed rpf1s and removing the spare tire/jack assembly and installing a new intake, exhaust, and tuner should yield a whole new car that has a respectable acceleration compared to stock :-) Now I just need to find some decently priced 2 piece rotors to finish the unsprung weight removal!!!
myt_tuf1 (07-11-2011)
 Old 07-11-2011, 10:03 AM   #18
tragik's Avatar
Posts: 2,882   (View Stats)
tragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the worldtragik is the leader of the world
Groans: 165
Groaned at 38 Times in 32 Posts
dieciocho.
tragik is offline   Reply With Quote
 Old 07-11-2011, 10:13 AM   #19
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
OMG this is making me want to order a set of rpf1 17x9 right now. gotta resist......
anyway, OP go with 17x9 along with some meaty tires!
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 07-11-2011, 10:18 AM   #20
Crarrs's Avatar
Posts: 1,662   (View Stats)
A stock wheel is 18x7 with a 52.5mm offset.
Stock Gen2 wheel is 18x7.5. Offset is correct. Redo your calculations with that number.
2004 MSM TiGrey
 Old 07-11-2011, 11:01 AM   #21
mrmonk7663's Avatar
Thanks for correcting me on the stock size. I'll recalculate a bit later and post here.
Michael
 Old 07-11-2011, 05:03 PM   #22
mrmonk7663's Avatar
Ok I recalculated.
Stock-18x7.5 52.5mm offset
Enkei RPF1 17x8.5 40mm offset-1mm closer to strut, 25mm farther out toward wheel well. This will fill up the wheel well almost as much as the 9" wheel but it will only reduce clearance by 1mm. Seems like the best comprimise. 8.5 it will be for me
 Old 07-11-2011, 05:10 PM   #23
Fermion's Avatar
Posts: 300   (View Stats)
Fermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the world
I have 17x9s on my gen 1. Love the cheaper price of tires, the weight, the way they make my suspension respond, and the look. IMO I like the way the 17x9s look better than any of the 18s. yeah my revs are higher and my speedo is off, but who cares.
2007 MS3 Red
HKS BPV, AEM CAI, COBB TIP, Eibach Pro Springs, Black RPF1's 17x9 +45, CNT Catless DP, Racing Beat TBE, JBR SSP & Bushings
Fermion is offline   Reply With Quote
The Following User Says Thank You to Fermion For This Useful Post:
 Old 07-11-2011, 05:16 PM   #24
mrmonk7663's Avatar
From Enkei...
Enkei RPF1 Wheel Features:
•MAT PROCESS: Shaping by the MAT process reduces wheel weight by 10%-15%. Every pound of unsprung weight savings has the effect of reducing overall vehicle weight by 20lbs.
This seems optimistic but still bad ass!!!
 Old 07-11-2011, 05:43 PM   #25
JS + MS3's Avatar
Man! Just ball up and get the 17x9! You won't need to modify your fenders according to others who have them on!
2010 Mazdaspeed3
 Old 07-11-2011, 06:04 PM   #26
Fermion's Avatar
On my gen 1 I had to roll the rear bc im on eibach pros. I'm not sure about gen 2s.
I have a wheel thread of them installed
2007 MS3 Red
Last edited by Fermion; 07-11-2011 at 06:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-12-2011, 04:26 AM   #27
Dre
Dre's Avatar
Groans: 48
i dont think your speedo is gonna be off by much depending on what size your tire wall is.. if you use the tire calculator i linked earlier you can get it to like 1-2 mph of stock.. on a genpu at least..
-TTT
 Old 03-06-2012, 02:48 PM   #28
RJD23's Avatar
Posts: 49   (View Stats)
RJD23 is a jewel in the roughRJD23 is a jewel in the roughRJD23 is a jewel in the rough
Enkei RPF1 17x8.5
i use to drive a sentra spec v and once i dropped it i hated the car i dont want to mess with my mazda and keep suspension stock
if i get the wheels named above and not get suspension what tire size should i get? will it rub?
as you can see by my questions this is my first time buying wheels
RJD23 is offline   Reply With Quote
 Old 04-01-2012, 11:38 AM   #29
cjanota's Avatar
Posts: 6   (View Stats)
cjanota will become famous soon enough
From Enkei...
That is incredibly optimistic. For straight line acceleration, the added effects of rotational inertial mean that reducing 1Lb of mass in the wheels is equivalent to a 1.5-2Lb reduction on the sprung weight depending on mass distribution of the wheel. The biggest benefit you see is in the ability of the wheel/tire to follow bumps on the road. This is much more important for cornering and high speed. Spring rates and damping rates need to be adjusted to take full advantage of significant changes in unsprung mass.
cjanota is offline   Reply With Quote
 Old 04-02-2012, 10:00 PM   #30
Juliandlr1004's Avatar
Posts: 226   (View Stats)
Juliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the worldJuliandlr1004 is the leader of the world
Groaned at 8 Times in 4 Posts
I AGREE! I CURRENTLY OWN AN 8TH GEN CIVIC THAT I HAVE UP FOR SALE TO GET A MAZDASPEED3 AND 17" RPF1 BELONG ON THAT CAR NOT THE SPEED, WHICH IS WHY THE SPEED COMES ORIGINALLY WITH 18S AND THE CIVIC WITH 17S
I WAS RUNNING MY CIVIC WITH 18" EVO X MR BBS WHEELS AND THEY WERE SICK!
THINKING ABOUT SAVING THOSE AND SLAMMING THEM ON THE SPEED ONCE I GET IT!
Juliandlr1004 is offline   Reply With Quote
The Following User Says NO Thank You to Juliandlr1004 For This Un-useful Post:
duappleganger (05-17-2012)
 Old 04-03-2012, 02:50 PM   #31
327whp's Avatar
Posts: 231   (View Stats)
327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute327whp has a reputation beyond repute
Groaned at 7 Times in 5 Posts
I would run the 18's with a 235 and a 45mm offset. I had a 48mm offset on mine and loved it. My wheels were 8.5 though.
2010 Red MazdaSpeed 3 (281whp) - Traded in
2008 Crystal Red C6 Corvette (402whp)
Still have stock MS3 wheels with Blizzaks
327whp is offline   Reply With Quote
 Old 04-06-2012, 10:52 PM   #32
Midnitehours's Avatar
Posts: 115   (View Stats)
Midnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the world
17's all the way! as long as you get the ride height right.
the 17x9 +45mm fit the gen2's perfectly thanks to the little indent on the stock strut.
If you decide to get struts/coilovers from a gen 1 you'll need spacers up front.
OEM+ FTW
Midnitehours is offline   Reply With Quote
The Following 2 Users Say Thank You to Midnitehours For This Useful Post:
bertrand_CX_7 (04-07-2012), turbo test (03-11-2013)
 Old 04-08-2012, 11:15 PM   #33
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
Does anyone have pics of a Genpu running 18" RPF1's? Every pic I have seen has been 17"...
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline   Reply With Quote
 Old 04-12-2012, 01:02 PM   #34
Scoobs's Avatar
Posts: 750   (View Stats)
What size tire are you using, 245? Looks great by the way.
Sold
New
Wife's car
 Old 04-13-2012, 07:13 PM   #35
235/40/17. they're shorter than the stock tire size so wheel gap was bigger than norm.
the r888's run rather meaty compared to dunflops. I have to roll the rear at my ride height.
Mazdaman160 likes this.
OEM+ FTW
The Following User Says Thank You to Midnitehours For This Useful Post:
Scoobs (04-14-2012)
 Old 04-22-2012, 01:22 PM   #36
token_asian_guy's Avatar
Posts: 9   (View Stats)
token_asian_guy will become famous soon enough
Ok I recalculated.
So basically 17's run to these specs would be fine with the stock suspension setup?
token_asian_guy is offline   Reply With Quote
The Following User Says Thank You to token_asian_guy For This Useful Post:
Scoobs (07-19-2012)
 Old 04-22-2012, 01:36 PM   #37
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Do you have a thread with pics of your set up. Would love to see it on the red.
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 04-22-2012, 05:01 PM   #38
mrmonk7663's Avatar
Yes it was fine on my stock suspension. With my swift springs it would rub going over big dips fast. I rolled the fenders and problem solved.
 Old 04-22-2012, 05:08 PM   #39
cabrone's Avatar
Posts: 529   (View Stats)
cabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the world
I'd go 17x9
Tapped
08.5 CWP MS3 GT
AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays
cabrone is offline   Reply With Quote
 Old 04-22-2012, 05:21 PM   #40
gonads and strife
Matt's Avatar
Posts: 274   (View Stats)
Matt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the worldMatt is the leader of the world
The latest issue of GrassRoots Motorsports covered 18s vs 17s. Their track times showed that 18s were actually faster (average and overall). They came to the conclusion that because the 18s have a shorter tire sidewall that the contact patch is larger, which equaled more even heat distribution in the tire and much better grip at the limits of the tires heat threshold.
They used an MS3 for the tests too.
bertrand_CX_7 and rfinkle2 like this.
Matt is offline   Reply With Quote
The Following 4 Users Say Thank You to Matt For This Useful Post:
1sicms3 (08-21-2013), bertrand_CX_7 (04-25-2012), kunfu (04-22-2012), rfinkle2 (11-19-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f432/enkei-rpf1-17-vs-18-speed3-85515/
[??] VW GOLF????????? - ?2? - ???? This thread Refback 02-20-2012 05:53 PM
Page generated in 0.55285 seconds with 41 queries
