> 2010 MS3 - Wheels & Tires
 Old 06-27-2015, 09:09 PM   #1
Si[xXx]er's Avatar
Posts: 43   (View Stats)
Si[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant futureSi[xXx]er has a brilliant future
Default Looking for tire suggestions please
Well the time has come and I need new tires for my car. I have read a ton of praise for the Michelin Pilot Super Sports and they sound like they are pretty much the best of all worlds (grip, noise, ride and life expectancy) but they aren't cheap and I was wondering if there were any other tires like these I should be considering? Also, would a 235/40/18 fit on the stock Gen 2 wheels? Any benefit besides looks or is that just a waste of money?
Background, my car is stock, eventually it may see some modifications but nothing crazy, I enjoy some spirited driving occasionally but I don't see tracking the car any time soon. I would like tires that are relatively quiet and ride well (for a performance tire) as the roads in the fine city of Winnipeg are comparable to most third world countries. The car does not see snow, and if it ever does it will get dedicated winter/snow/ice tires, as they are pretty much a necessity here in Canada.
Any help is much appreciated!
When you have lost everything, what do you have left to fear?
Si[xXx]er is offline   Reply With Quote
 Old 06-27-2015, 09:14 PM   #2
someguy's Avatar
Posts: 914   (View Stats)
Get PSS's anyway ... worth every penny.
The Following 4 Users Say Thank You to someguy For This Useful Post:
aromig (06-27-2015), cyclist20 (07-06-2015), SarcasticOne (06-28-2015), Si[xXx]er (07-05-2015)
 Old 06-28-2015, 03:38 AM   #3
Quigs's Avatar
Posts: 1,152   (View Stats)
Tires are not something to cheap out on.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
The Following User Says Thank You to Quigs For This Useful Post:
 Old 07-03-2015, 03:52 AM   #4
Robi's Avatar
Posts: 11   (View Stats)
Robi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to allRobi is a name known to all
Highly recommend bridgestone potenza pole position s04. Excellent tire all around. Especially in the rain.
Robi is offline   Reply With Quote
The Following User Says Thank You to Robi For This Useful Post:
 Old 07-03-2015, 06:33 AM   #5
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
I got pss. Rain performance is the real deal
Sent from my SAMSUNG-SM-N910A using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
The Following User Says Thank You to tmillner For This Useful Post:
 Old 07-03-2015, 06:45 AM   #6
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Pilots are great (pss) in every aspect.
If you want a cheap decent tire look at nexen series. I believe I paid $600 for entire car in 225 40 18. They may have a 235 I did not check. They gave me consitent 2.0 60s on a lightly modded speed 3. They are not that wonderful in the rain however heads up. Felt like drag radials in the rain. PSS stick pretty well in wet conditions.
The line up:
 Old 07-03-2015, 06:01 PM   #7
Hokie D's Avatar
Posts: 157   (View Stats)
Hokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the worldHokie D is the leader of the world
Groaned at 4 Times in 1 Post
PSS like these guys say. Great wet and dry performance. Also, when they get near replacing they are still very good unlike other brands that get worse over time.
2010 Celestial Blue Mazdaspeed3 - Cobb SRI, Cobb Air Box, Cobb TIP, Autotech Internals, OBX Test Pipe, ETS TMIC, Stratified OTS 93+E85 Flash Tune, Corksport Hood Scoop, Resonator Delete, JBR Short Shift Plate - Suspension: Eibach Pro Springs, Stock Struts/Shocks, JBR Rear Sway Bar
https://youtu.be/qp4Ew15bjZE
2014 Race Red Shelby GT500 - 100% Stock
https://youtu.be/zcy-6YfO7SQ
SOLD: 1993 Reef Blue Ford Mustang 5.0L Notch - Lotsa Mods
https://youtu.be/jLdRGHEkv2A
Hokie D is offline   Reply With Quote
The Following User Says Thank You to Hokie D For This Useful Post:
 Old 07-03-2015, 09:22 PM   #8
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
This is probably heresy on this forum, but I highly recommend the Firestone Firehawk Wide Oval Indy 500's (talk about a mouthful of a name). They're only $90/tire, and will give you 90% of the performance of Michelin PSS for less than half the price. They also last me around 30k miles.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
The Following 2 Users Say Thank You to biggman026 For This Useful Post:
cyclist20 (07-06-2015), Si[xXx]er (07-05-2015)
 Old 07-05-2015, 11:14 PM   #9
Si[xXx]er's Avatar
Thanks for the feedback guys, I ended up ordering the Pilot Super Sports, not cheap but I thought if I'm going to spend the money I may as well get a quality product and they seemed like the safest bet.
 Old 07-06-2015, 07:53 PM   #10
Hokie D's Avatar
Cool. You'll be impressed with their traction in wet and dry.
 Old 07-07-2015, 02:49 PM   #11
yasun's Avatar
Posts: 182   (View Stats)
yasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond reputeyasun has a reputation beyond repute
Good choice.
2011 Black MS3 w/Tech
Cobb AP | cp-e Stage 2 RMM | CorkSport Coilovers | CorkSport Camber Plates
Michelin Pilot Super Sport 245/35-18 on Enkei PF01 18x8.5+48 (summer)
Pirelli Winter Sottozero Serie II N1 235/40-18 on Enkei Tuning TS9 18x8.5+45(winter)
yasun is offline   Reply With Quote
 Old 09-15-2015, 07:38 PM   #12
mazdaspeed333's Avatar
Posts: 81   (View Stats)
mazdaspeed333 is infamous around these partsmazdaspeed333 is infamous around these partsmazdaspeed333 is infamous around these parts
Groaned at 89 Times in 48 Posts
I just got Hankook ventus v12's. only complaints i have seen is the sidewall being to soft
Autotech internals,cobb rmm, Cobb AP, Cobb SRI, TIH,catless racepipe,str8 piped catback, 6K HID'S, FREEKTUNED.
mazdaspeed333 is offline   Reply With Quote
Tire Suggestions Continuous 2010 MS3 - Wheels & Tires 28 08-05-2014 10:43 AM
Replacement Tire suggestions Rakhan Mazdaspeed3/6 General Discussion 51 05-25-2013 09:58 PM
Nail in tire... suggestions? (San Diego) Twofer Gen2 MS3 General Discussion 15 04-15-2013 04:23 AM
tire suggestions kraz3y MazdaSpeed 3/6 - Wheels & Tires 13 08-23-2008 11:03 PM
Titan Tire ships world's first 63-inch tire Haltech Automotive News 3 07-31-2008 02:45 PM
Page generated in 0.31086 seconds with 29 queries
