> 2010 MS3 - Wheels & Tires
 Old 11-16-2009, 08:04 PM   #1
MS3 Abuser
9900rpm's Avatar
Posts: 784   (View Stats)
9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world
Default Slicks / Drag Radials
I've seen FD RX7 wheels on the 1st gen MS3's before, and I know those wheels are 16x8. Looking to get a pair of those for drag radials. Does anyone here know if any 15" wheels fit the 2nd gen MS3, for slicks? The MS3 brakes are of decent size.
I don't remember if I've ever seen 16" slicks.
Offset for 1st gen and 2nd gen MS3 is the same, right?
9900rpm is offline   Reply With Quote
 Old 11-16-2009, 09:15 PM   #2
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
15's will not fit unless you down grade to the mz3 brakes!! Mikey Thompson makes a 16" street slick. You should just buy dot drag raidials. I have had bfg raidials I think 235/45/17 and the I currently have the nitto 555r raidials on some 16x8s 245/50/16 I like the nittos more they got me a 1.8 60 foot the bfgs got me 2.0 maybe I was making less powah
Rota wheel whore #1
MOdS list
shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~
painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo
for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up!
PM me with offers
silversurfer3 is offline   Reply With Quote
 Old 11-16-2009, 09:25 PM   #3
MS3 Abuser
9900rpm's Avatar
245/50/16 drag radials don't rub the fenders or anything, and they fit on 16x8's? I might look into that. Would you know what offset 16x8 wheels I would need? I know RX7 wheels fit nicely, but unsure of what that offset is.
Not a fan of Nitto 555R's. Used to run those on other cars. I like the BFG G Force drag radials.
 Old 11-16-2009, 10:52 PM   #4
You want a 45-48 offset I have 40 offset rubbed only at full lock with a 2" drop
Rota wheel whore #1
MOdS list
PM me with offers
 Old 11-17-2009, 05:14 PM   #5
layubr's Avatar
Posts: 22   (View Stats)
layubr is a jewel in the roughlayubr is a jewel in the roughlayubr is a jewel in the rough
?Are there any cheaper solutions for wheels?
?would this wheel clear? they a $61 a piece at jegs.com?
JEGS High Performance - 260-3977812P
i understand a a 5x114.3 is the same bolt pattern as a 5 x 4-1/2'
I know we share the same bolt pattern as the mustang. Are there any 16x8 mustang wheels. Mustang wheels are dime a dozen and i dont care what they look like because i would only use them at the track.
FYI( im running stock ride hieght)
im looking for a cheaper wheel solution
?if a wheel does not clear are wheel spacers a bad idea with slicks?
layubr is offline   Reply With Quote
 Old 11-18-2009, 04:19 PM   #6
MS3 Abuser
9900rpm's Avatar
Spacers with stock lugs and studs is no good. Some may disagree with me, but I've seen, and have done so myself, snapped studs (old turbo Integra GSR running 13" drag wheels and fat slicks). Not sure about the Mustang wheels; is the offset the same?
Know of any other 16x8", 5x114.3, 45-48 offset wheels?
 Old 11-18-2009, 05:40 PM   #7
layubr's Avatar
Offset? i dont care much for the offset as long as they fit without rubbing while pointed straight. Im ok with some rubbing while turning.
i should have said that my intent was to bracket race so i don't care about the look im just looking at the price.
I found out mustang wheels are the same bolt pattern so these wheels will fit the hub. not sure about if the with rub.
 Old 11-27-2009, 02:30 PM   #8
nvrdone's Avatar
Posts: 1   (View Stats)
nvrdone is an unknown quantity at this point
offset on fd wheels is +50 i believe, might be +52
nvrdone is offline   Reply With Quote
 Old 11-27-2009, 03:42 PM   #9
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
I would look into Nitto NT05's and a light weight set of forged 17's. Should be good enough for a 1.8 - 1.9 60ft plus you can use them daily.
I was pulling 2.0 -2.1's with Yokohama Parda Spec 2's - stock wheels.
ms3077 is offline   Reply With Quote
Vegetarian radials? Defatted soy eyed as tire filler substitute Haltech Automotive News 0 01-06-2009 12:20 PM
Slicks Jesse MS3GT MazdaSpeed 3/6 - Wheels & Tires 67 09-28-2008 09:37 AM
Drag Radials MidwestSpeed3 MazdaSpeed 3/6 - Wheels & Tires 3 06-24-2008 01:57 PM
Page generated in 0.30314 seconds with 24 queries
