> 2010 MS3 - Wheels & Tires
 Old 08-23-2017, 12:27 AM   #1
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
Default Tire/Fender Rubbing Question
Hello,
I'm trying to decide whether a 235/40/18 has more fender clearance or a 245/35/18 has a less likely chance of rubbing.
I've decided on a set of wheels that are 18x9.5 +38. Now to fit this on a 2012; I'm wanting to go with the 245/35 series but if a 235/40 series is going to rub less then ill deal with the stretch.
The tire calculator points to the 245/35 being smaller in every area except width. Would the smaller height give me a better advantage of fitting these wheels?
I ran 18x9 +35 with 245/35/18's in the past with no issues so I'm leaning towards the 245/35's.
A second example that I've ran on this car are Evo x wheels 18x8.5 +38 with 245/40's. These had more rubbing issues than my 18x9 +35 with 245/35's. But I've never tried any wheels with 235/40 so that's my long lost question.
Which works best? Rear fenders are rolled and bumper tabs are shaved off. I'm lowered on Sonic tuning coilovers but its more of a spring drop height. Front camber is -1.4 and rear is -2.3.
Thanks
2012 Black Mica Speed 3
300whp-341wtq tuned by John @ Tork Motorsports (2/4/14)
Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC
Mazdaspeed3KHP is offline   Reply With Quote
 Old 08-30-2017, 01:31 AM   #2
70 views and not a single insight huh. I thought this was the number one Mazdaspeed tech site?
Please though don't be shy.
 Old 08-30-2017, 10:02 AM   #3
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Originally Posted by Mazdaspeed3KHP View Post
Hello,
Thanks
235/40 will not rub, I was going to order that exact size but ended up finding a better deal on smaller tires. Even lowered I don't think it'll be an issue.
245/45 would not fit on my stock car (rubbing)
So just go for 235/40
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-30-2017, 12:23 PM   #4
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Well maybe if you did your research you wouldn't be asking this question for the 1,000th time its been asked on this lame forum buddy. LOTS of tire fitment threads have been posted.
 Old 08-30-2017, 12:45 PM   #5
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Dude check out the wheel fitment thread you will find your answers there.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
Tire Rubbing - Spacer Fix? kurieren MazdaSpeed 3/6 - Suspension & Brakes 3 10-03-2015 07:00 PM
Fender Well Rubbing?? Smadginader CX-7 > Wheels, Tires, Brakes & Suspension 0 08-02-2012 10:18 AM
Tire wear-Alignment or rubbing? sideslide4life MazdaSpeed 3/6 - Wheels & Tires 38 06-12-2012 07:05 PM
tire rubbing maddocx240 Mazdaspeed3/6 General Discussion 21 12-06-2011 11:48 AM
Coilover rubbing against tire. SketchyMark 2010 MS3 - Suspension & Brakes 29 11-09-2011 05:56 PM
Page generated in 0.25950 seconds with 23 queries
