| Not Ranked : 0 score for comfort, i would reduce the rim by 1inch to get more tire sidewall instead of looking to find a touring tire with less grip on 18inch Keep in mind you got a car with good power, if you can't pass it to the ground, it will be clueless to have that much power and those big brake if it is always the tire that limit you.....
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
| Looking for tire suggestions please | Si[xXx]er | 2010 MS3 - Wheels & Tires | 11 | 09-15-2015 07:38 PM |
| Tire Suggestions | Continuous | 2010 MS3 - Wheels & Tires | 28 | 08-05-2014 10:43 AM |
| 245/40-18 tire on RX-8 rims with stock suspension...yes I "Searched" ! | gamma500 | MazdaSpeed 3/6 - Wheels & Tires | 3 | 04-09-2011 07:01 AM |
| tire suggestions | kraz3y | MazdaSpeed 3/6 - Wheels & Tires | 13 | 08-23-2008 11:03 PM |
