| Banned ![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
Groaned at 408 Times in 235 Posts
(Thread Starter) | Not Ranked : 0 score Anybody take off their OEM 18" wheels and tires and weigh them yet? Would be curious to see how much the combo weighs. Thanks |
| The Following 2 Users Say NO Thank You to Driver72 For This Un-useful Post: |
![]() Join Date: Nov 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,218
Groans: 94
Groaned at 38 Times in 19 Posts
| Not Ranked : 0 score The wheels are probably around 24lbs like all other 18"x7.5" Mazda wheels.. tire weight could vary because OEM's get their own specs on tires.
__________________ "We already have the Speed6 replacement" "It's just called the CX-7 now" ![]() back at http://www.mcx7.com bitches, spam free |
Tirerack has the OEM tires listed at 24 lbs each. Hopefully somebody will pop a wheel/tire off soon and weigh them. Getting aftermarket wheels is always one of the first things I do when I get a new car. And if the tires a car comes with OEM aren't the best, I usually upgrade them too. In both cases, if possible, I also try to reduce unsprung weight too. | |
| The Following User Says NO Thank You to Driver72 For This Un-useful Post: |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score i have my set of four in my garage, i culd throw one on the scale later and post weight. they have the stock rubber on.
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 141
Groaned at 26 Times in 11 Posts
| Not Ranked : 0 score My guess is 199lbs for wheels and tires
__________________ Rota wheel whore #1 MOdS list shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~ painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up! PM me with offers |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score i wouldn't mind putting on the new 2010 rx-8 wheels that I just saw today at the dealer lot!! 19"...and gun metal...not too bad...look like the 2010 ms3 wheels? not sure there wasn't any on the lot
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score those RX-8 rims looks sick, i want to see how they look on a 1st gen MS3. |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
| Not Ranked : 0 score Yeah I saw those too, they look really nice. Anyone know what those weigh?
__________________ I used to drive a MazdaSPED 3. It was retarded fast. |
(Thread Starter) | Not Ranked : 0 score Hey I forgot about this thread of mine. For the love of God, someone jack up the back of your 2010 MS3 pop the wheel and tire off and put it on a scale. You'd be doing us all a nice service. |
![]() Join Date: Sep 2009 Location: Boston, MA
Rep Power: 0 ![]() Thanks: 8
| Not Ranked : 0 score I take delivery on Wednesday (9/21) and will post by Thursday or friday what the weight is. |
Did you weigh the stock wheels and tires of the 2010 MS3 yet? Somebody on this forum has got to have an interest in this and know what the rotational mass of the stock wheels/tires are. Let your brothers and sisters in on some knowledge and post the results. | |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score well I have a set of stock '10 speed 3 rims/tires just chillen in the garage, I can check out the weight... |
| Always Blasted ![]() Join Date: Jul 2009 Location: North NJ
Rep Power: 680 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
Groans: 34
Groaned at 274 Times in 34 Posts
| Not Ranked : 0 score the rx8 19's are the R3 spec wheels, done by BBS forged @ $1600 a peice when i asked the dealer about them. eeesh.
__________________ 07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5. |
| Not Ranked : 0 score each oem tire/rim is 48.6lbs so all 4 is 194.4lbs |
| The Following 4 Users Say Thank You to Creatve For This Useful Post: |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
![]() Join Date: Aug 2009 Location: Northern Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,390
Creatve - Thank you for weighing! Now when I eventually go wheel shopping I will have a baseline!
__________________ I drive a white car with a HUGE spoiler Cobb Accessport Stage 1 + Cobb SF Intake | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Awesome, after a month, I finally got somebody to do that, so thank you. I kind of figured it would be in the 48-50 lbs range. There is a good deal of rotational mass to be lost with aftermarket wheels/tires on the 2010 MS3 then. The stock tires weigh 24 lbs IIRC, so the wheels weigh about 24-25 lbs. Going with the tires I recommended many weeks ago (the new Continentals) an owner could lose 3 lbs per tire, and there are plenty of 18-19 inch wheels that weigh 18-20 lbs. So dropping 7-9 lbs PER corner would be pretty easy on the 2010. In my testing experience each pound of rotational mass lost is equal to about 2.5+ lbs of sprung weight. So if you drop 8 lbs per corner or 32 lbs total in wheel/tire weight, that would be like removing 80-90 lbs from the car. But it also affords a bit better steering response and braking too. |
| The Following 3 Users Say Thank You to Driver72 For This Useful Post: |
| The Following 3 Users Say NO Thank You to Driver72 For This Un-useful Post: |
![]() | | #20 | ![]() |
![]() Join Date: Sep 2008 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score Per edmunds: Mounted together, they weigh 49.5 pounds apiece. |
| what tires on rx8 wheels | ZoomByU | Wheels & Tires - BLACK | 7 | 08-01-2009 01:03 AM |
| Separate "Appearance" from "Wheels/Tires" | KaiserSoze | Website Help/Feedback | 1 | 04-21-2008 08:33 PM |
| stock speed wheels vs rx8 weight | ms3boost | MazdaSpeed 3/6 - Wheels & Tires | 2 | 04-01-2008 07:51 PM |
