> 2010 MS3 - Wheels & Tires
 Old 04-25-2013, 01:09 AM   #1
razor3232's Avatar
Posts: 147   (View Stats)
razor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond reputerazor3232 has a reputation beyond repute
Default Weird Issue
So I took the winter wheels off & put my stockers back on the car today. Everything goes back on like any simple wheel swap should. I rotated the tires like any other sensible person & put the car back on the ground...Heres where things get odd....
While driving the car the steering/handling feels incredibly unstable. I feel like i have to fight the steering wheel to get it to turn. The slightest of steering wheel movements produces a drastic jerk in the car with the steering wheel snapping back to center.
All tires are properly inflated. The two rear tires have more wear & slight cupping on the insides from last seasons autocrossing. The best I can figure is that maybe I have a wheel or two that didnt seat properly when I put the summer stockers back on the car....
Can anyone offer any other suggestions...(Ill be taking the wheels off and re-seating them in the morning)
Thanks
2011 Liquid Silver
*Cobb SRI* *Cobb TIH* *Cobb AP* *JBR 88 durometer dogbone RMM* *JBR Rear Sway Bar* *JBR Short Shift* *JBR 5mm Wheel Spacers*
razor3232 is offline   Reply With Quote
 Old 04-25-2013, 02:22 AM   #2
BlackBettyMS6's Avatar
Posts: 120   (View Stats)
BlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant futureBlackBettyMS6 has a brilliant future
Whens the last time you had your alignment checked? When you accelerate does it pull to one side?
2006 MS6 GT - Black Betty "The damn thing gone wild"
SURE Aeros + TIP | Cobb AP | Autotech HPFP Internals | SU TMIC |Juggernaught | Torq R6 | ITV 22 | 18x8 Avarus AV8 + Pirelli 210 Sottozero | CS Front & Rear Sway Bars | CS Front Strut
BlackBettyMS6 is offline   Reply With Quote
 Old 04-25-2013, 03:12 AM   #3
razor3232's Avatar
No pulling to one side during acceleration. Also never had the alignment checked or an alignment issue....Wouldnt think alignment when things were fine with winter setup on the car & then an hour later things arent fine w/ the summer setup on the car.
2011 Liquid Silver
 Old 04-25-2013, 03:32 AM   #4
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
did you rotate the tires correctly?
or just randomly move them to a different side lol
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-25-2013, 04:51 AM   #5
razor3232's Avatar
that has popped into my head actually. the front tires to the rear was a no brainer but the rears to the front could be mixed up. unfortunately during cleaning i scrubbed off where they were supposed to go....
is it possible that the wheels are out of balance?
2011 Liquid Silver
 Old 04-25-2013, 06:49 AM   #6
PapaSmurf's Avatar
fronts go directly to the back.. so front left to back left and front right to back right.
The backs swap.. so back right would go front left, back left would go front right.
860whp/677wtq
2.7 V6 Ecoboost
 Old 04-25-2013, 07:42 AM   #7
razor3232's Avatar
check & check!
i went out this morning & re-swapped the two front tires and then re-torqued all 4 wheels. Then took the car out for a drive & to double check air pressures in tires....Whether it was the swap or the re-torquing I dont know but the car is handling like it should now!!
Once I got home I re-torques again just for good measure.
Thanks for the ideas......
2011 Liquid Silver
The Following User Says Thank You to razor3232 For This Useful Post:
PapaSmurf (04-25-2013)
Weird Clutch Engagement Issue Mfinlay04 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 04-02-2013 11:29 PM
Weird coolant issue pinkcheese MazdaSpeed 3 - Engine, Transmission & Driveline 21 01-20-2013 11:06 PM
ms6 weird heat issue maddocx240 Mazdaspeed3/6 General Discussion 22 01-18-2012 02:38 PM
Weird Issue 2gr84u MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-08-2011 02:09 PM
Page generated in 0.27537 seconds with 22 queries
