![]() | | #41 | ![]() |
![]() Join Date: Aug 2009 Location: Kearneysville, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
| Not Ranked : 0 score The all seasons I had were crappy in the snow, too, but manageable. The Falken winter tires I'm running now have served me really well with all the snow we've had this winter.
__________________ NoVA's first pu 2010 Mazdaspeed3 Sport | Black Mica w/ Tech Package __________________________________________________ _______________________________________________ | JBR SSP Stage 2 | JBR 88 duro RMM | Sure Aeros SRI | HTP TIP | DDM HID lows | Corksport LED fogs | | FIAMM low tone Freeway Blaster | Kumho Ecsta LE Sport (stock wheels) | Black 16x7 Flik FTDs (winter) | ______________________________| 215/55/R16 Falken Eurowinters (winter) |____________________________ |
![]() | | #42 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score I would never part with money for anything that said "All-season" in the description. I also wouldn't buy anything less than star specs in the Dunlop line.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2013 Location: Rural Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
| Not Ranked : 0 score I'm about to wrap-up my second winter on stock rims with Pirelli Winter Sottozero Serie II and I have no complaints. Last winter wasn't very snowy in the Chicago burbs, but this winter has been and, even though they showed last year's wear, they've been excellent in deep snow and on 'skating rink' icy roads. It's likely that this is the last winter that I'll get out of them, but I'm fairly sure that I'll be getting new Pirellis next November. |
![]() | | #44 | ![]() |
![]() Join Date: Jul 2013 Location: Lancaster, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
__________________ 2016 MX-5 Club 2012 MS3 -- RIP in peace | |
![]() | | #45 | ![]() |
| Not Ranked : 0 score I prefer to make my money last a little longer since I burn through summer tires in no time. Yeah, it's a sacrifice in performance, but the wife already gets annoyed at the fact that I buy even all-seasons just about every year.
![]() | | #46 | ![]() |
![]() Join Date: Sep 2018
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score I know this is an old thread, but the info was super helpful to me and my son as he just bought his MS3 last year. Had the same problem this week as others have had re ordering steel rims without TPMS. Found this info on another forum that I didn't see on this forum, it helped me, so just passing it on. The 2006 Ford Fusion was available without TPMS as an option. Same exact steel wheel specs as recommended for the MS3. 16x6.5 steel wheels with a +42 offset in a 5x114.3 bolt pattern with a 67.1 hub diameter. I know there is another workaround mentioned on another thread, but found this one to be super helpful too. You'll have to cut and paste into a search engine. This is where I got the tip on the Fusion wheels. oppositelock.kinja.com/dear-tire-rack-please-frig-off-1660278393 |
![]() | | #47 | ![]() |
| Not Ranked : 0 score be carefull with steel wheels, maybe oem ones may fit as oem mags of any 16inch mazda but aftermarket may not clear front brakes, especially new brakes..... and you can always replace tpms with a rubber valve or the opposite.
| New Winter Wheels/Tires | letzleta | 2010 MS3 - Wheels & Tires | 20 | 01-22-2011 09:27 PM |
| Air pressure for Winter tires | boosthead | MazdaSpeed 3/6 - Wheels & Tires | 1 | 01-18-2011 11:39 AM |
| Winter Rims/Tires Package or just Tires? | Amber3 | MazdaSpeed 3/6 - Wheels & Tires | 12 | 12-02-2009 12:20 AM |
| new tires for winter what do you think | Jarods7920 | MazdaSpeed 3/6 - Wheels & Tires | 31 | 11-21-2008 12:52 PM |
