![]() | | #481 | ![]() |
![]() Join Date: Jan 2013 Location: Winchester,va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
Groaned at 70 Times in 8 Posts
| Not Ranked : 0 score Am I at heavy danger if I drive this way for a couple months without upgrading internals. I have no way to log or and it will be 2-3 months before I can get some kind of data logger/HPFP Internals. Should I take the intake and RP off until I can get the HPFP internals? Will the Forge BPV effect this in any way and am I safe to leave it on now? Thanks guys for making the issue clear cut. I just need to be 110% sure I just bought the car last friday my wife would kill me if something went wrong this early. Thanks again.
__________________ 2010 Mazdaspeed 3 CS CBE//CS RP//CS SRI //CS turbo inlet//Forge BPV//Autotech Internals//Cobb AP//CP-E TMIC//BC Coilovers//Rich Tuned//NGK Iridiums// |
![]() | | #482 | ![]() |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score race pipe and bpv will do nothing but giving you more sound. As far as the intake and tih it is your call I went for about a few months with just a cold air intake and a ap and just monitored my fuel pressure, to be honest if funds is a issue you can always sign up for me bill me later and purchase the internals that way, I would rather pay something off for 6 months instead of having to save money to purchase a new engine.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
![]() | | #483 | ![]() |
![]() Join Date: Feb 2010 Location: Dallas
Rep Power: 1531 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,819
Groans: 145
are you sure? Sent from a GenPu
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE | |
| The Following 3 Users Say Thank You to Zdraveca For This Useful Post: |
![]() | | #484 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score If you don't have an AP, then you really don't know do you? You are probably fine, bit you don't know if you can't monitor. Tappin'
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | jcutler0622 (01-20-2013) |
![]() | | #485 | ![]() |
Groans: 106
| Not Ranked : 0 score when mounted to the stock downpipe I would not think you would really see that much gain as you would if where mounted to a catless downpipe to be honest if I am wrong then oops and I am sorry. But he should get internals before doing anything else especially with his vehicle being a 2010 and getting some age on it,no telling how much stress has been put on his stock internals
![]() | | #486 | ![]() |
Groans: 145
| The Following 2 Users Say Thank You to Zdraveca For This Useful Post: | Hush (01-20-2013), jcutler0622 (01-20-2013) |
![]() | | #487 | ![]() |
![]() Join Date: Jun 2012 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,322
Groans: 156
__________________ -2012 CWP MS3 - - COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50 - JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB - - Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob - - Self Tuning 91 octane of fail with 50/50 WMI of win - | ||
| The Following 3 Users Say Thank You to Hush For This Useful Post: |
![]() | | #488 | ![]() |
| Not Ranked : 0 score So I am going to take the intake off after reading this. Thanks guys. Should I be good with the catless racepipe ( which I know I will see gains from) I did on my previous ms3 gen1's x3. So untill I get AP and HPFP internals I would be safe running catless RP, CBE and forge bpv right? Or should I wait. The car has been babied. I know it is 2010. But with only 16k miles on it. All service records, owned by an old man. The car is clean. suggestions would be great! Thanks guys!
![]() | | #489 | ![]() |
Groans: 106
| Not Ranked : 0 score ya that is for downpipe bro, the guy above mentioned a race pipe which is the mid pipe or some people call a test pipe, that replaces the second catalytic converter, but either way he needs to get something monitor his shit or upgrade the internals, dont want to turn this into a pissing contest or anything so do not take offense to anything I am saying.
| The Following 2 Users Say Thank You to motherfnmonsta For This Useful Post: | Hush (01-20-2013), jcutler0622 (01-20-2013) |
![]() | | #490 | ![]() |
| Not Ranked : 0 score Thanks Hush!! Noted.
| The Following User Says Thank You to jcutler0622 For This Useful Post: | Hush (01-20-2013) |
![]() | | #491 | ![]() |
Groans: 145
The guy should make himself a favor and take both intake and testpipe unti he gets something to monitor with or internals
| The Following User Says Thank You to Zdraveca For This Useful Post: | Hush (01-20-2013) |
![]() | | #492 | ![]() |
![]() Join Date: Aug 2011 Location: Poughkeepsie, NY.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,050
Groans: 235
| Not Ranked : 0 score Testpipe/Racepipe is what makes the power gains while on stock turbo. @jcutler0622; have an old android device? buy a bluetooth obdII adapter on ebay for $20 and torque with mazdaspeed pids for $15. Easy & cheap way to monitor.
__________________ ![]() /91 miata with basic suspension bits /Turbo ep3 BWAAAAA PSH /speed 3- bye /possessed speed 6- dead ((((((/lol nator. |
| The Following User Says Thank You to alphasaur For This Useful Post: | Hush (01-20-2013) |
![]() | | #493 | ![]() |
Thanks again everyone for all help!
__________________ 2010 Mazdaspeed 3 CS CBE//CS RP//CS SRI //CS turbo inlet//Forge BPV//Autotech Internals//Cobb AP//CP-E TMIC//BC Coilovers//Rich Tuned//NGK Iridiums// | |
![]() | | #494 | ![]() |
Groans: 235
| Not Ranked : 0 score I believe torque is only available for android devices. You can purchase a cheap android device (like a motorola droid) for about $30-$40. The torque application is $5 I believe, and the plugin to read mazdaspeed3 specific parameters is $15. The adaptor is about $20. You're looking at about $80 total. I'd still recommend an ap over this solution, but it does okay in a pinch.
![]() | | #495 | ![]() |
Groans: 145
| Not Ranked : 0 score or he can get this and be done with it UltraGauge Automotive Information Center and OBDII Scan Tool
| The Following 2 Users Say Thank You to Zdraveca For This Useful Post: | alphasaur (01-20-2013), jcutler0622 (01-21-2013) |
![]() | | #496 | ![]() |
| Not Ranked : 0 score Had a sweet talk with the wife. Ordering the HPFP internals today. Rolling with the Autotech. Thanks for all the valuable info. Last question. Running just the RP,SRI w/ turbo inlet and CBE w/ the upgraded internals. Should I be good, no reliability issues to worry about? Trying to keep car as close to stock with just a little power. I am not trying to go big at all. AP would be my next upgrade I guess. Breaks my heart I can't do coilovers and rims next.
![]() | | #497 | ![]() |
![]() Join Date: Dec 2012 Location: Goose Creek SC.
Rep Power: 0 ![]() Thanks: 2
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Ok in the 6 weeks that ive been apart of this forum I consider myself a short time reader, first time poster, I reciently installed a Cobb AP Checked the two parameters for FP that it monitors( I believe act. press and dis. press) before I installed auto tech HPFP internals, AP was showing at idle about 450ish on both and 1660ish on both accelerating. with new HPFP internals, 550ish at idle on both, and 1660 dis. press, 1760 act.press accelerating. Now for the question, ive read < 1600psi = bad day so A. why did i start with < that (at Idle) and 2. why do I still see 550# after install? I did Install Myself In a CLEANNNN dinning room area, (car was in CLEAN shop as well) IM a Nub, I know this, if the answer is on here and I havent seen it please just give me a Keyword to search for. thanks all |
![]() | | #498 | ![]() |
Groans: 156
![]() | | #499 | ![]() |
![]() Join Date: Mar 2012 Location: Westampton, NJ
Rep Power: 1412 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,551
Groans: 61
| Not Ranked : 0 score I guess it's a really difficult concept. If you're going to mod the car, get internals. Yeesh, you need a degree in Mechanical Engineering to comprehend that. AP/Internals should be the first thing anyone should buy for this car. Regardless. You will get more gains from an AP than you will from just an intake/tip...there's no justification in doing it the other way around. One of the most important things you need to do with the car is monitor certain parameters (Act. Fuel Pressure, KR, etc.). Sorry, end rant, I'm not a gear head, but, cmon.
__________________ Precision: PTE 5858 Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete Tial: 44mm EWG HTP: 3.5" Intake + 51r Battery Tray CPE: Stage 2 RMM//Manifold JBR: SSP//Shifter Bushings//Knob//TMM//OCC UR: CBE HKS: SSQV4 CS: Springs NGK 1-Step Colder POWERED BY PURPLE DRANK I'm from Jersey...the Drama State. |
| The Following User Says Thank You to PUGENE For This Useful Post: | alphasaur (01-21-2013) |
![]() | | #500 | ![]() |
Groans: 235
__________________ ![]() /91 miata with basic suspension bits /Turbo ep3 BWAAAAA PSH /speed 3- bye /possessed speed 6- dead ((((((/lol nator. | |
![]() | | #501 | ![]() |
![]() Join Date: Jan 2012 Location: Georgetown, Ky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 689
| Not Ranked : 0 score I've got an SRI on my car, and a Hypertech tuner (couldn't pass up the deal I got on it). I've also got an Ultra Gauge that I can monitor fuel pressure with. At WOT, I'm getting over 1700 psi on the stock pump, and I peak at 18.71lbs of boost, then smooth out to around 16-16.5lbs. So far so good for me. I called Hypertech, and they told me that with their tune, I should be good to go as far as a TMIC without upgrading the internals. Only when I do the downpipe will I need internals. We'll soon find out.
__________________ 2010 Mazda Speed3 Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP, Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires FREEKTUNED! 2003 Chevy S-10 2014 Toyota Camry 2011 Dodge Challenger R/T 1997 Geo Prizm |
![]() | | #502 | ![]() |
Groans: 156
| Not Ranked : 0 score I also use an UltraGauge during the week. Does not replace an AP WOT log, as the hpfp can dip in a split second, and only for a couple of seconds, and that will be the time you are not looking at it. It may not be a total failure, but it is a sign, a sign that something bad might be coming. I was limping along for 6 months without internals, so I have been there. But I did have an AP, so I could at least see that my hpfp was dipping low after just an SRI and TIP.
![]() | | #503 | ![]() |
| Not Ranked : 0 score I haven't seen a dip, but I don't drive my car hard all the time, as I'm sure you don't either. I'm getting a spare pump soon (only 6000 miles on it), and when I do, I'm gonna rebuild it with some internals, then put it on the car after my warranty expires (along with a downpipe). Unless I see something before then that would warrant me putting it on sooner.
![]() | | #504 | ![]() |
I have been monitoring my KR and During WOT runs I look down and (sometimes) I get up to 1.5 degree reading. When I accelerate at approx 50% throttle, i get (again sometimes) 0.6 degree reading around 3k in 2nd gear. both instances are sparatic and clear quickly. Is this bad and what should I do? I currently have the auto tech internals and running the OFF THE SHELF stage 1 93 octane v231 cobb AP tune. | |
![]() | | #505 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Sri/tip n test pipe I was fine, 1700+ Threw on a stage 1, 4 logs I hit 1 cell of 1599, bought internals and hit up @Lex; 2nd best thing I've done. 1st was donate mod Sent from my dizzLe using RaWr powers!
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) Last edited by ms3rick; 01-21-2013 at 07:32 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #506 | ![]() |
Groans: 156
Sporadic KR is pretty normal during regular driving, particularly if motor is cold, again it is at WOT that KR needs to be watched for anything over 1.
![]() | | #507 | ![]() |
Groans: 235
| Not Ranked : 0 score what's up with you pu owners wanting to spend hundreds on mods but not wanting to spend $300 on a piece that can prevent you from venting a 3-6k motor?
![]() | | #508 | ![]() |
| Not Ranked : 0 score I'm planning on doing mine at the same time I do my downpipe. I don't have money to spend on a new engine.
| The Following User Says Thank You to greatdane68 For This Useful Post: | alphasaur (01-22-2013) |
![]() | | #509 | ![]() |
| Banned ![]() Join Date: Dec 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
Groaned at 6 Times in 1 Post
| Not Ranked : 0 score For anyone who is on the fence or nervous about rebuilding their CDFP, don't be! Its a simple, quick install. It was actually harder to put my intake on then it was to rebuild my CDFP. |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
| Fake Walbro Fuel Pumps | melly mel | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 5 | 09-01-2009 01:21 PM |
| 2 fuel pumps and a throttle body | straydoginc | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 05-26-2009 10:18 AM |
| AP users w/upgraded fuel pumps... | Speedn3 | Cobb Access Port/Maps | 30 | 12-08-2008 07:14 PM |
