![]() | | #41 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score
May be we should create a sticky thread for the parameters, their meaning and what should be they OK values to point out to newbes like me what are import and on what to focus when starting messing arround with their car.This is the last question about login. Knock retard with DH: Which PID parameters read it and what should be the OK value? Thanks to every one.
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. | |
![]() | | #42 | ![]() |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score The DH doesnt read KR on the gen2.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
Edit: Please add Christian's quite thorough break down of mods vs fuel pressure and tuning. 2010 MS3 AccessPORT Alpha Testing
__________________ Last edited by Amazon; 01-19-2011 at 07:05 AM. | ||
![]() | | #44 | ![]() |
![]() Join Date: Aug 2010 Location: Honolulu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 424
Groans: 54
Groaned at 42 Times in 32 Posts
| Not Ranked : 0 score While it is an issue - I would rather it have go apeshit and want to dump fuel then the other way around and let things get to lean. As stated, i've yet to see the AFR's change when this is happening. So I beleive it is at least keeping things safe, but we are loosing power becuase of it. .. But i'd rather loose power then cause engine damage. |
![]() | | #45 | ![]() |
Groans: 214
| Not Ranked : 0 score When it starts dumping fuel, it over loads the fuel system causing the pressure to drop which is much more dangerous. Understand?
__________________ |
![]() | | #46 | ![]() |
| Not Ranked : 0 score if i had to do it over again, the first thing i would do is hpfp (either internals or the cp-e) and next, the AP. IMO, spending the $300.00 on the internals and $600.00 on the AP will give you much better performance, while maintaining safety, than any other combination of bolt ons. |
![]() | | #47 | ![]() |
Groans: 54
| Not Ranked : 0 score Dangerous probably for the pump. Again, i've seen no indication on my logs that this would be dangerous for the engine. The AFR's stay exactly where they are supposed to be. If the AFR's aren't changing I fail to see how this would be dangerous for the engine itself. Probably ain't good for the fueling system though. |
![]() | | #48 | ![]() |
Groans: 214
| Not Ranked : 0 score If your pump fails while going wot due to the ecu over stressing it, you could run very lean and blow if the ecu does not cut the power soon enough. Then again, who here wants to be dropping money on replacing their stock pump? Doubt it's a cheap item at the dealership.
![]() | | #49 | ![]() |
Groans: 54
I'm just pointing out that it isn't doing any damage unless the pump outright fails and stops providing fuel. Even then, i'd think the ECM would be able to prevent catostrophic failure though. | |
![]() | | #50 | ![]() |
Groans: 214
| Not Ranked : 0 score I don't know if you're trying to make yourself feel better about worrying about the issue and just placing your faith in the ecu to prevent failure. The ecu will most likely prevent total failure of the engine, but it won't prevent your fuel pump from living a short life. As more and more gen2's get modded more extensively and tuned, we will probably start seeing more pump failures. Point is, monitor you fuel pressure. A Dashdaq or similar should be your first or 2nd mod on the gen2. As I already pointed out, I saw pressure drop with only two airflow mods. And seriously, why risk it?
![]() | | #51 | ![]() |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
Mchart, instead of throwing caution to the wind with your 22k car, wouldn't you rather spend the 300-600 on a fuel pump to make sure your car a) runs safely and b) can make actual use of the mods you add? I've ridden with/raced Amazon, his car bogs like a mofo with a tp and cai for power mods, that's it. Now for the first time he can finally monitor it with his AP and it is dangerously low in some instances. Not worth the risk imho, and they are real risks. Apparently you can monitor mchart, most guys can't. Bottom line, like Nataphen said, make sure you can monitor and see what your exact set up is doing.
__________________ I used to drive a MazdaSPED 3. It was retarded fast. | |
| The Following User Says NO Thank You to Nazarite For This Un-useful Post: | char181 (01-19-2011) |
![]() | | #52 | ![]() |
Groans: 54
| Not Ranked : 0 score Apparently you don't know my history. I'm one of the people who has presented the issue. I'm just pointing out the valid fact that the engine isn't going to be 'hurt' if the AFR's remain where they are at. As you read in my posts, I constantly datalog my car. Otherwise, I wouldn't say what I have been saying. My AFR's stay where they should be, even when the pressure drops to 1100 PSI. Yes, I am getting a pump; As you may or may not know obtaining a pump is near impossible right now. I would have gotten one over a month ago - But everyone has been out of stock. I am not telling people to not get a pump. I am simply pointing out the fact that engine damage will not occur unless the pump outright locks up, and/or your AFR's reflect an over-lean condition. |
![]() | | #53 | ![]() |
Groans: 214
| Not Ranked : 0 score Your approach does not inspire confidence in what knowledge you have concerning this issue. The pumps have failed on gen1's before. You say the car won't be hurt "if" the afr's stay where they should? No thanks, I'll not go wot again until my hpfp comes in, plain and simple. My car cuts more and more now and I don't want to be like doubleflusher and have to limp around on 742 psi for weeks or months until I get a pump or internals in. char181, I don't see any validity in you groaning Nazarite's post, please explain.
![]() | | #54 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
It seems from the datalogging experience of gen 1 users who did have fuel pump pressure drops that the gen 1 ECU does pull timing and sacrifice boost and other engine operating parameters to focus on maintaining safe AFR's when the pump shits. I don't know if this is the case with gen 2. Datalogging would be necessary to find out if the newer ECU works the same way to maintain safe AFR's.
![]() | | #55 | ![]() |
Groans: 66
| Not Ranked : 0 score Who is this guy? He's randomly showed up to groan 2 of my posts that I've noticed today while posting nothing of his own now. What gives?
![]() | | #56 | ![]() |
| dizzy gt2871 ![]() Join Date: Nov 2010 Location: Savannah, GA
Rep Power: 247 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
| The Following User Says Thank You to bwallace04 For This Useful Post: | Nazarite (01-19-2011) |
![]() | | #57 | ![]() |
Groans: 54
Not everything is so black and white. Last edited by Mchart; 01-19-2011 at 12:03 PM. | |
![]() | | #58 | ![]() |
Groans: 54
In my case, temps below approx. 58 degrees F at WOT is when the the fuel pressure drops. Boost is set to around 19PSI, and the instant the pressure drops boost is dropped to around 17 PSI where it then stays steady until the RPM's get higher and the pump has less issues. So cobb's findings of approx 18 PSI being the 'max' before the pump has issues fits in line with the data i've seen from my own car. | |
![]() | | #59 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
Bottom line IMHO, on a Gen 2 in order to minimize risk from widely varying stock pump capabilities a HPFP should be the first upgrade before anything else is done. A lot of people justify waiting on a pump not only because they might be one of the lucky ones that have a good stock pump but because it isn't a flashy go-fast part and doesn't make cool noises so they feel money is better spent elsewhere much like when people with only an SRI go buy a bling-tastic BOV/BPV. Again some of this is my opinion and conjecture but it comes from my experience as an alphatester and asking questions/learning from Christian. He is welcome to chime in if something I said is completely baseless. It's hard to understand why someone would even remotely risk blowing a motor to save $300-600 when they happily drop that much and more on SRI's, DP's, FMIC, etc.
__________________ www.MOTOIQ.com Beater Titan | |
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | fortressofcomfort (01-23-2012), MSMS3 (01-19-2011) |
![]() | | #60 | ![]() |
Groans: 54
In no way am I suggesting that people should go out and WOT the fucker like normal just because the datalogs haven't shown any AFR issues. | |
| The Following User Says Thank You to Mchart For This Useful Post: | Todd98SE (01-19-2011) |
![]() | | #61 | ![]() |
Groans: 66
| Not Ranked : 0 score If that's true, I wish grandpa would show up and contribute something other than groans. The old dust bag's prolly pissed Medicare isn't hooking it up like it used to.
| The Following User Says Thank You to Nazarite For This Useful Post: | rfinkle2 (01-19-2011) |
![]() | | #62 | ![]() |
| Not Ranked : 0 score on this note... i ordered a pump mid December and was originally quoted a mid- late January delivery. Now, I'm told that there is an additional 2-3 week wait. moral of the story: Get in line somewhere if you plan on upgrading your pump. |
![]() | | #63 | ![]() |
RPM had a few CP-E pumps still in stock when I bought mine 3 weeks ago, did they get cleaned out as well in the great 2011 HPFP shortage!
![]() | | #64 | ![]() |
Groans: 54
![]() | | #65 | ![]() |
| Not Ranked : 0 score With Gen1 cars there was a strong correlation between blown engines and overworked pumps - especially as the temperatures dropped. The Gen1 car adds fuel when it registers a certain amount of knock. This addition of fuel usually causes a drop in the fuel pressure if the pump is at the limit. Lower pressure is bad for several reasons regardless of the commanded injector pulsewidth: 1. Lower pressure means poorer atomization of the fuel and less contribution of that fuel to combustion 2. The fuel pressures combat cylinder pressures in direct injected applications. The drop in pressure becomes even more of a concern than it would in a PI vehicle since the PW has to make up for a lot of headroom as the injected pressures get close to the cylinder pressures. 3. The injection time in DI cars is half of what it is in PI vehicles Overall, ensuring you are maintaining as designed DI fuel pressures is essential and combustion efficiency and safety - especially at WOT and in times of high air density (cold temps) - when the pumps show their weaknesses. |
| The Following 8 Users Say Thank You to Lex For This Useful Post: | Amazon (01-19-2011), atvfreek (01-19-2011), Dredful (01-19-2011), fortressofcomfort (01-23-2012), Meder (01-19-2011), Nataphen (01-20-2011), wolly6973 (01-19-2011), xxdjfate76xx (01-19-2011) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score ^ Excellent explanation. At least the Gen 1 ECU was trying to protect AFR at the expense of other parameters. Indeed, that does and did not guarantee protection from zoom, zoom, boom. But it was better than letting the engine truly lean out. Thanks for the more technically correct detail on what was happening and the possibly hidden risks of relying just on protected AFR's. I think I'll now get on the list for an upgraded pump, even though I've been one of the lucky ones not to see a drop in pressure (so far)!
![]() | | #67 | ![]() |
Groans: 54
![]() | | #68 | ![]() |
Groans: 214
I wasn't having a fit over your post, nor did I ever call it wrong. I merely said it did not give one confidence in your knowledge concerning this issue. I don't think we have quite put our finger on what causes the MS3 to blow, but I'm gong to bet the fuel pump and high loads at low rpm's played a significant roll. I don't know what your mods are, but on mine, even though its not outright "fuel cut", it definitely surges in and out. This is the first winter for most gen2's, and many of them aren't very modded yet. I'm sure next winter we'll see the record become tarnished to a degree.
__________________ | ||
![]() | | #69 | ![]() |
Groans: 54
I think there is maybe 1 thread on here that I know of where someone actually was doing data logs before he blew and it seems to have correlated to low FRP. He was well below even 1100 PSI if I recall though. Not saying it isn't the cause of a bunch of blown engines, but at the same time we don't exactly have much data to support the assumption either way though. I could very well be wrong. As I said though, at least from what i've seen in the blown engine thread.. Most blown engines didn't even happen at WOT. Which would not indicate a drop in fuel pressure. | |
![]() | | #70 | ![]() |
![]() Join Date: Nov 2010 Location: West Lafayette, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
Groans: 70
Groaned at 23 Times in 15 Posts
| Not Ranked : 0 score Called KMD today and got put on the list for internals...
__________________ I drive an old RX-7 because I like breaking down a lot. |
![]() | | #71 | ![]() |
Groans: 214
| Not Ranked : 0 score Many of the guys weren't data logging when they blew, hence the dearth of data surrounding the blown motors. I have already seen low 1000's in fuel pressure with my few mods, count me as concerned. What are your mods?
![]() | | #72 | ![]() |
Groans: 54
| Not Ranked : 0 score As i've said; Nothing but a tune. Above 60 degrees the pump remains above 1600 PSI. Below that and the pump starts to drop in the part of the rev band where max torque is made at which point the ECM drops boost to a level the pump can sustain (around 17PSI) and after around 4500 RPM's the pump shoots back up to 1700 PSI. At this point the boost is set to taper off to around 17-18 PSI anyways though. (From what I can gather) So as it is, i'm loosing some power in colder weather at WOT right now. Which is why i'm not very concerned in regards to my own car. (well, i'd lie to say i'm not worried. I am. That said, if I stay off the throttle I have nothing to worry about.) Please note that i'm not an expert by any means. I'm just relaying what i've seen over the past few months of data logging. Last edited by Mchart; 01-19-2011 at 03:40 PM. |
![]() | | #73 | ![]() |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
| Not Ranked : 0 score lol...genpu fail strikes again.
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! |
![]() | | #74 | ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2009
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
We have been selling and pushing the Innovate motorsports datlogers for YEARS. These are robust as hell, log at a very high sample rate, and are easy as hell to use for the average modder. Most profesional tuning shops have two or three LM-2s they use to log cars while on the dyno. These are the best logers short of a full blown Motec setup! The OT-2 is a downsized unit that does everything the LM-2 does, less the stand alone wideband, and display, and works wirelessly with your laptop, Iphone, Ipad,or Ipod touch. The software that Innovate uses is self graphing, and very addaptive. We have a ton of the OT2's on the shelf right now. Retail price is dirt cheap at 179.95 If you guys without a way to monitor your car want them, drop me a line, I'll give you a great GB on the little suckers | |
![]() | | #75 | ![]() |
![]() Join Date: Jan 2010 Location: Lake Villa, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,503
| Not Ranked : 0 score I was seeing sub 1100 PSI with an SRI, TIH, BPV & a tune. I upgraded the internals and all seems kosher even in the 20 degree weather. Again, no reason to test WOT at this point as it is too cold and there is 1FT of snow on the ground. My pressure would drop the second the ECU would get Knock, thus dumping fuel to compensate. All the logs from the AP show pressure is holding firm above 1500 PSI even in higher RPMs. I am now 1 week with the internals installed and will give updates or can post logs of pre-pump upgrade vs now if anyone is interested.
__________________ Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah 4/15/12 dynojet results: 305whp / 355 tq |
![]() | | #76 | ![]() |
Groans: 70
__________________ I drive an old RX-7 because I like breaking down a lot. | |
![]() | | #77 | ![]() |
Rep Power: 123 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
![]() | | #78 | ![]() |
| Not Ranked : 0 score not when the ecu is targeting a certain boost pressure
![]() | | #79 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score I'm sorry, but I've heard it brought up a couple of times in this thread, what is so bad abou pt going WOT in cold temperatures if you have logs and everything is kosher on them? |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | rfinkle2 (03-16-2011) |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score If your logs are fine, your car should be fine. I think that people are just saying that colder temps are when the pump gets stressed more, i.e. FRP is fine above 60* temps, but colder than that it starts to drop. If your logs are OK, you shouldn't have to worry.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
| The Following User Says Thank You to Nataphen For This Useful Post: | Ckmazdaspeed3 (01-20-2011) |
| Cp-e or PTP fuel pumps? | manelscout4life | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 99 | 06-09-2010 05:32 PM |
| Fake Walbro Fuel Pumps | melly mel | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 5 | 09-01-2009 01:21 PM |
| 2 fuel pumps and a throttle body | straydoginc | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 05-26-2009 10:18 AM |
| AP users w/upgraded fuel pumps... | Speedn3 | Cobb Access Port/Maps | 30 | 12-08-2008 07:14 PM |
