(Thread Starter) | Not Ranked : 0 score Just giving all you gen2 boys a heads up... I am ordering and installing http: http://www.autotech.com/prod_engine_fuelinj.htm Im hoping to give us another option to the HPFP shortage. Should have them delivered and installed by the 19th of this month. I did alot of research on vdub forums since KMD is made for vdubs and so are autotechs, same set up just different companies and a little more expensive but i just want a damn fuel pump so i can install my downpipe and actually use the AP to its full advantage. Many threads I moused through all pointed to Autotech > KMD, so well see how it goes ![]() Also i called autotech and they said there internals are good up to 200 bar of pressure which equals out to 2900psi (I laughed to), but after reading some threads people have said that they see a steady 133bar, which is 19XX psi, which is excellent if you ask me. ************************************************** ******************************** Alrighty!!! Auto-Tech Internals installed, logs are 3rd gear pull and 4th gear pull. Enjoy! As of now im only running Stage1+SF+TIH 93 Octane BT, for some reason the link on cobbs site for +CDHP is broken, so hopefully they will fix it monday so i can run that map and post some more logs with the higher boost map. ************************************************** ******************************** Thanks to BeeZa for hooking be up with the Stage1+SF+TIH+CDHP 93 Octane BT map, last two logs are with this map, Target 19psi, hold 17psi to redline. Shit feels like a whole different car now, ap rocks! logs are obviously labeled with the map they were logged on.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost Last edited by PapaSmurf; 02-19-2011 at 04:25 PM. |
| The Following 22 Users Say Thank You to PapaSmurf For This Useful Post: | BradX (02-10-2011), Broxer (03-14-2011), DingoDave (03-21-2011), fishin53 (02-10-2011), forcedinduktion (02-23-2011), fywdyl (02-22-2011), JS + MS3 (02-27-2011), NoTraction (03-08-2011), PunjabiPlaya (02-10-2011), rghispanic88 (03-03-2011), Seaton (02-10-2011), Spd3 (04-27-2011), Speed3eak (02-10-2011), speedms6 (02-23-2011), SpeedSixxx (03-01-2011), spoolin00 (02-23-2011), Teethkikr (02-21-2011), thepatient77 (02-19-2011), triphop631 (03-03-2011), wolly6973 (02-10-2011), xxdjfate76xx (02-19-2011) |
![]() Join Date: Dec 2009 Location: Sydney,Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 146
| Not Ranked : 0 score Good work! Keep us updated. |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score subbed, good luck with the new dp...I too am waiting on KMD internals so I can install my DP...
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
![]() Join Date: Nov 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 237
| Not Ranked : 0 score I'm very curious to see how they work. Hopefully it works out good.
__________________ [SIGPIC][/SIGPIC] |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score curious about these and AWE. I'm probably gonna end up getting a cp-e anyway, but I would like to see the results nonetheless. |
(Thread Starter) | Not Ranked : 0 score There the same exact type of internals as KMD, so I dunno why people would think they wouldnt work.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| WOT @1k RPM! ![]() Join Date: Jul 2009 Location: SoCal
Rep Power: 7299 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,432
Groaned at 50 Times in 33 Posts
| Not Ranked : 0 score PTP where the same too.
__________________ MazdaSPEED3 2009 - Mica Black http://www.mazdaspeedforum.org/forum/forum/f8/setting-avatar-new-users-other-noobs-43712/ http://www.mazdaspeedforum.org/forum/forum/f8/uploading-adding-images-your-post-43704/ No BB URL code = sux |
(Thread Starter) | Not Ranked : 0 score PTP is a scrub ass company. Auto-tech is known in the vw world and from what i have read hasent had any failures. There is no way you can compare PTP products to any company.
![]() Join Date: Feb 2011 Location: Shawnee, OK
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I just talked to a guy at auto tech and he didn't know if these would work for the gen 2. And I was trying to make sure that they will fit our pump. Thanks guys |
![]() Join Date: Nov 2010 Location: NoVA
Rep Power: 226 ![]() Thanks: 108
| Not Ranked : 0 score You need to read some of the other threads on HPFP options, because we've been through this at least a dozen times.
__________________ 2011 STi | Stage 2 [SOLD] 2010 Black Mica | CS SRI + TIP | JBR SSP | TRZ RMM | OCC | DDM 6000k 35w | |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score we have the same pump as vdubs, they will fit
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score i hope they seize. wait, did i type that out loud? |
| The Following User Says Thank You to phillyb For This Useful Post: | AZSPEED3 (02-25-2011) |
| They are good internals and they are also local to us if you didnt know. I know KMD made a change to the piston design and rod. The rod on the new version is longer, so this is why i decided to wait it out and give em a whirl.
| The Following User Says Thank You to Haltech For This Useful Post: | TulsaVR93FD (03-08-2011) |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score I though they were changing their coating, or is that the change that became v2.1.
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score Well ill be looking into either new internals or the cpe pump here soon...My ptp pump which has held up 1600-1800 @wot for the past year now, has decided to drop down to 900 psi from 5000-5700rpm, so im getting some cut and no wot for me at this time. Im really looking for feedback for the awe tuning internals, since their spose to be a pretty dam good company for the vdub/audi boys. But like Haltech said, maybe ill wait for kmd, just want the best internals for my money, And do not want to wait tooo long.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following User Says Thank You to superskaterxes For This Useful Post: | jracer (03-02-2011) |
| Not Ranked : 0 score Oh the Cp-e pump is and has been the gold standard for us speeders. Well aware of that...lifetime warranty is very nice. Gerry said it will prabaly be 3-4 weeks atleast before pumps come in, we shall see.
(Thread Starter) | Not Ranked : 0 score Op updated. Side note, for some reason i cant download Stage1+SF+TIH+CDHP 93 Octane BT map off cobbs site, seems like the link is broken, if anyone has it and can share it with me ill be happy! as stated below im only running Stage1+SF+TIH 93 Octane BT, but i do have my auto tech internals installed! ![]() Enjoy!
![]() | | #19 | ![]() |
Groans: 82
| Not Ranked : 0 score Datalogs look great - I see you're touching 19xx psi for a while there too. I'm really tempted by these - how much did the shop you went to charge for the installation? |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score To much, but I didn't care cause I just wanted this done. lol about to go log the map I'm suppose to be running and I'll post those logs also
| The Following User Says Thank You to PapaSmurf For This Useful Post: | Speed3eak (02-19-2011) |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score op updated again with Stage1+SF+TIH+CDFP 93 Octane BT datalogs.
![]() | | #22 | ![]() |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score Logs look good! Seeing yours will hit 2000psi as well. Good internals! Hopefully these continue perform! |
![]() | | #23 | ![]() |
![]() Join Date: Sep 2009 Location: Stamford, CT
Rep Power: 152 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 57
| Not Ranked : 0 score where did you order these from? and they were stocked? also, I have an MS6, the pump is the same for both right |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
__________________ Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies... | |
![]() | | #25 | ![]() |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score Just keep everyone updated. With the cpe hate that is going on now everyone will be looking for diffrent options.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() Join Date: May 2009 Location: Kingston MA
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 258
| Not Ranked : 0 score subbing for more info...
__________________ 2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint |
![]() | | #28 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score mine come in tomorrow and hopefully if i can get a fellow mwmber to help we will install saturday. i am a gen one running stage 2+sf and supporting mods. good to see good news blue |
![]() | | #29 | ![]() |
![]() Join Date: Dec 2010 Location: Bloomington, Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 156
| Not Ranked : 0 score nice to see there is another fairly priced set of internals. Thank you for doing this and posting your results.
__________________ Daily - 2007 True Red Mazdaspeed3 GT. Jack Stand Race Car - 1991 Aquamarine Pearl MR2. |
![]() | | #30 | ![]() |
Groans: 266
| Not Ranked : 0 score ordered
![]() | | #31 | ![]() |
Groans: 91
| Not Ranked : 0 score crap snow storm sat and no help sunday might be doing next week if weather doesnt "brighten" up. |
![]() | | #32 | ![]() |
![]() Join Date: Jun 2010 Location: Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 474
| Not Ranked : 0 score ordered..... See how long it takes to get to canada... hopefully they still have stock..
__________________ 2010 MS3 Black 395whp/386wtq | Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters |
![]() | | #33 | ![]() |
Groans: 266
| Not Ranked : 0 score I just got my tracking number and it say they will be here tomorrow....I think its them, nothing else I ordered could weigh only .9 pounds. Perfect timing cause my ap is getting here tomorrow.
![]() | | #34 | ![]() |
| Not Ranked : 0 score How long did it take to get a tracking number after you ordered?
![]() | | #35 | ![]() |
Groans: 266
| Not Ranked : 0 score I ordered it last night, I didn't get an email from them saying it shipped It is a package that weighs .9 pounds...only other thing I ordered was a shark fin and AP. Both I think weigh more than .9 pounds Edit: Nevermind just saw the sender was autotech.
![]() | | #36 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Can you post pics of the internals? How does the button lock onto the piston? Good job OP! |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score I didnt take pics of them out of the case. But it honestly is exactly the same as KMD.
![]() | | #38 | ![]() |
Groans: 266
| Not Ranked : 0 score They are just like the KMD, But here is a picture from autotech website
![]() | | #39 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score reminds me of the carpie dime internals that failed on me, with the different, goffy ass, valve spring clips, split the retainer in half!! luckily it didn't trash my pump housing... hope the retainer is harder than a hore's heart!!!
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #40 | ![]() |
Groans: 266
| Not Ranked : 0 score well our only 2 choices other than cp-e both have this design
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f433/autotech-internals-72084/ | ||||
| Internals for Fuel Pump - Page 2 | This thread | Refback | 10-27-2011 08:33 PM | |
| 2010 ms3 cobb acessport & fuelpump internals??? | This thread | Refback | 03-02-2011 09:06 AM | |
| Internals for Fuel Pump | This thread | Refback | 02-25-2011 07:32 AM | |
| kmd internals | spec2k5 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 41 | 01-04-2011 09:09 AM |
| Internals | 9900rpm | 2010 MS3 - Engine, Transmission & Driveline | 11 | 09-29-2009 02:00 PM |
| KMD V2 Internals | wakeboarddude | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 7 | 07-10-2009 05:15 PM |
