Closed Thread
 Old 08-17-2016, 03:27 PM   #1
Aro
Aro's Avatar
Posts: 20   (View Stats)
Aro is infamous around these parts
Default autotech pressure dropping at decel? 193psi..
hey guys. had my autotech 2.5 years and never installed them until last week. idle is 415/435, wot is 1700+ (I did dip into 1600's once). on decel I know the pressure drops but earlier I had a low of 193.. lowest it's ever went. usually drops to a low of like 220 tops. should I take it apart, clean and inspect and put backk together?
Aro is offline
The Following User Says NO Thank You to Aro For This Un-useful Post:
faeker (08-18-2016)
 Old 08-17-2016, 06:04 PM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You're fine.
g00s3y is offline
anavrinIV (08-18-2016), KiwiFlavor (08-18-2016), WetzMS3 (08-18-2016)
 Old 08-17-2016, 06:12 PM   #3
08cosmic3's Avatar
Posts: 2,920   (View Stats)
If you're idling around 425 and above 1600 at WOT, you are great, no worries.
08cosmic3 is offline
 Old 08-17-2016, 06:38 PM   #4
Aro
Aro's Avatar
I'm just a little worried, because my car hiccups on a cold start. also, I didn't get a long but I did a pull and I came to a stop shortly afterwards. idle was 382 and seemed to keep dropping.. car also seems to hiccup in first Gear, sometimes it feels like it misfires hard at 5kish
Aro is offline
faeker (08-18-2016)
 Old 08-17-2016, 06:49 PM   #5
WillP's Avatar
Posts: 224   (View Stats)
WillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond reputeWillP has a reputation beyond repute
Mine did the same Aro 4 months ago. I cleaned the male and female connection to the pump and made sure the connection was good and clean. I haven't had an issue since. I am running 50/50 E85 so I thought the spill valve may need a clean or the pump but not yet. Your good man but check the connection to make sure its good and clean.
2007 Titanium Gray ll Metallic Mazdaspeed6
#10227
Mods // SURE SRI // COBB TIH // CP-E TMIC w/Robert Roark Cork Gasket // COBB AP V3 // AUTOTECH HPFP // MD SSP // JBR RMM // H&R Springs // 3" Str8 Pipe-Beast Mod //
Freektune OTS+ // ITV22 // Kevdog Tow Plate
WillP is offline
 Old 08-17-2016, 06:56 PM   #6
g00s3y's Avatar
Groans: 438
If you're having issues then you should definitely clean the pump. Even a tiny bit of sticky death/film of it can cause some minor issues, which can turn major if not taken care of.
g00s3y is offline
 Old 08-17-2016, 08:28 PM   #7
Aro
Aro's Avatar
only option I have for fuel here in Canada is basic esso 91. it's not great by any means. I will check and clean those connections just because. thanks!
honestly I think it's just the engine. car has 60,050 km, and mazda just put in a new engine under warranty at 48,000 km. it was misfiring bad in first, until I changed the plugs (ngk iridium one step colder) and fuel pump together. I also frequently have trouble starting the car when it's warm, it cranks and cranks before it catches. but this has been goin on since about 20k which leads me to believe egr is bad.
Aro is offline
 Old 08-17-2016, 11:03 PM   #8
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Was the In-Tank Fuel Pump ever checked and had the filter changed?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
mituc is offline
 Old 08-21-2016, 12:44 PM   #9
Aro
Aro's Avatar
no, not to my knowledge.
Aro is offline
 Old 08-18-2016, 05:41 AM   #10
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
take that shit back to mazda.
You don't need colder plugs, you need stock heat range properly gapped.
Blue Pu.
anavrinIV is offline
The Following 4 Users Say Thank You to anavrinIV For This Useful Post:
Aro (08-21-2016), g00s3y (08-18-2016), Vansquish (08-18-2016), WetzMS3 (08-18-2016)
Closed Thread
fuel pressure dropping to 200psi boatis 2010 MS3 - Troubleshoot/Diagnostics 5 07-13-2016 03:46 PM
Fuel Pressure dropping when slowing. MazdaBoy2.3 2010 MS3 - ECU Computer Tuning 5 10-11-2012 07:17 PM
Fuel Pressure dropping during WOT My FIX crazyp MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 03-26-2012 07:05 PM
Fuel Pressure still dropping shnouz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 03-23-2012 06:39 PM
Low fuel pressure with autotech internals and stock nofear72784 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 38 01-03-2012 07:39 PM
Page generated in 0.30648 seconds with 25 queries
