Like Tree65Likes
 Old 12-09-2014, 10:16 PM   #1
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Default Direct meth injection help
Ok so long story short I almost bought a new car but decided to go all in on my speed 3. Game plan is a pte5858 turbo kit, meth kit and so on. This brings me to my question, where are all of the direct meth injection info! I have only found info on pre tb set ups. My game plan was to pnp my intake mani and running one nozzle on my cold pipe and 4 small ones straight into my intake mani. I know that is rather excessive for a 500whp build but I want to make sure each cylinder gets the same amount of meth. The reason for the pre tb nozzle would be cooling the charge and the direct port nozzles would be for fueling. Is that a good plan or am I being paranoid? Also is it worth a jmf mani over an stock pnp mani to get equal air flow? It looks like the pnp manis have pretty even flow compared to the stock mani so I should be good. I just want to make sure the motor is getting the same air flow and meth across the board.
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
The Following User Says Thank You to blake0521 For This Useful Post:
Swinger13 (12-29-2014)
 Old 12-25-2014, 02:53 AM   #2
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
@tastysi2004; He has it here in VA. He can help you out.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
 Old 12-25-2014, 08:33 AM   #3
tastysi2004's Avatar
Posts: 1,063   (View Stats)
tastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the worldtastysi2004 is the leader of the world
@blake0521;
if you want each cylinder to get the same amount of meth... do not put an extra one prethrottle.
its just going back wards from your original goal.
just make sure you have big enough injectors for the power goals that you are looking for.
i currently have 4 do5 nozzles and a 300psi pump with 2 check valves and a solenoid.
make sure they are quality check valves or else you'll have the vacuum from the engine suck in extra meth, back fire and one of two cylinders needing meth when the lines are empty.
i also got a maf controlled unit so i dont have the risk of cutting the boost line or crimping it when routing it when trying to bring it inside the car(DO).
another thing, big enough tank. while tuning, i probably go through 5 gallons of meth in less than a week. but with daily driving, unless higher than normal boost is concerned... none is used. 2.5 gallons is what i have. i may move to a bigger one but not anytime soon.
quality lines and/or fittings.
if you're going all out, get npt fittings and stainless steel lines.
and junk the push to fittings.. unless they are from expensive companies such as aquamist.
i went to fastenals and got their brass fittings... they've worked like a charm.
most of all, it comes down to your tuning.
i have ryan at purple drank tuning me.
we've been working together for quiet some time now. nothing but quality work and fastest response times than any other tuners that ive had.
hope this helps. if you have any questions... post up. @2.0t03speed;
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
build block, pnp everything, tr825 core, meth and lots of it.
554whp/546wtq @ 30psi.
another build? maybe soon..
b/c race cars need more attention than women.
adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~
#CATBACKEXHAUST
tastysi2004 is offline   Reply With Quote
 Old 12-27-2014, 03:33 PM   #4
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
You can go direct port but really pre tb or using a tb plate works just fine for reaching 500whp.
i've been using pre tb injection on my ms3 for a year now without problem. So have many other people.
Direct port meth is good you just need to use quality fittings. Because every new fitting/connection you make is another spot for a potential leak.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
Nel Mazdaspeed (01-03-2015), Tokay444 (12-29-2014)
 Old 12-27-2014, 03:44 PM   #5
blake0521's Avatar
Built motor is going to happen don't worry!
2.0t03speed likes this.
2010 Mazda Speed3-
Mods:
Next up: tune.
2.0t03speed (12-27-2014)
 Old 12-28-2014, 10:54 AM   #6
Don't forget the failsafe . As you rely on the meth extensively for fueling you definitely want a system that detects a failure or loss of flow.
I've worked with pretty much every kit out there and the two most complete ones are aquamist and coolingmist in terms of reliable failsafes. This is because they don't use the propeller type of flow sensor that is both prone to failure and gets maxed out with a lot of meth flow.
I carry the more affordable CM kit and mate it to a Guardian Angel to drop boost should it detect a failure. The aquamist kit can be setup the same way and they have PWM injection.
You can also consider 6th port once you are in the Aquamist price range.
I personally really don't feel comfortable fueling my engine with a meth kit without a failsafe. Especially a stock block where the margin for error is so small.
blake0521 (12-28-2014)
 Old 12-28-2014, 10:58 AM   #7
blake0521's Avatar
It will be a built block like I said so that will give me some protection. I also was going to do the snow stage 2 kit with there fail safe system. Easier to wore from what I have read when compaired to aquamist. Just trying to figure out what mani I should run. A pnp stock mani and tap it or a jmf one that is pre tapped.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 11:04 AM   #8
why is everyone so afraid of wiring? the aquamist install isn't hard it's just time consuming. use some posi tap connectors like i did and that install is easy.
tastysi2004 likes this.
Mauro_Penguin (12-29-2014)
 Old 12-28-2014, 11:06 AM   #9
blake0521's Avatar
Because I know nothing about wiring that's why hahaha I am not good at the kind of stuff at all. It might be cheaper to go the aquamist route and just dive in head first.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 11:08 AM   #10
literally you get a diagram from aquamist and you get a ecu pin out off msf. find the right wire and tap it. you have to cut the ebcs wire as it intercepts it for the fail safe. Really the install isn't hard you just need to follow the diagram.
 Old 12-28-2014, 11:11 AM   #11
blake0521's Avatar
Why did you not Solder? Posi tap work just as well? You might have sold me on aquamist.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 11:13 AM   #12
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Stuff
The Following User Says NO Thank You to Gr8Speed For This Un-useful Post:
 Old 12-28-2014, 11:15 AM   #13
blake0521's Avatar
Ok so pnp stock mani and tap it then run 4 small jets and on medium pre tb so I can see the bats drop. Think that will be the game plan.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 11:17 AM   #14
Gr8Speed's Avatar
Stuff
 Old 12-28-2014, 07:27 PM   #15
After PNP'ing the stock mani, wall thickness of the runners is too thin to tap.
Theses are a few shots of something we've been collaborating on with a few members of MSF. It's being tested now.
blake0521 (12-28-2014), Gr8Speed (12-28-2014), Mauro_Penguin (12-29-2014), mituc (01-02-2015), Swinger13 (01-24-2015)
The Following 2 Users Say NO Thank You to JBR For This Un-useful Post:
Manny (12-31-2014), Tokay444 (12-29-2014)
 Old 12-29-2014, 06:59 AM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I beg your pardon?
I think it's cool that you're only cleaning 1 valve per cylinder though.
And the meth resistance of your silicone?
If your manifold flows evenly, pre throttle body injection, or even a post throttle body spacer, will yield even meth distribution, and will clean ALL the valves.
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 12-29-2014 at 07:10 AM. Reason: MSF Database - Automerged Doublepost
Deldran (12-29-2014)
The Following User Says NO Thank You to Tokay444 For This Un-useful Post:
Gr8Speed (12-29-2014)
 Old 12-29-2014, 07:35 AM   #17
Gr8Speed's Avatar
I beg your pardon?
Blah
 Old 12-29-2014, 08:12 AM   #18
I beg your pardon?
Did I stutter?
After tapping there is very little meat left for threading. The risk of stripping the soft cast aluminum of the manifold is a very real possibility when attempting to tighten these small fittings. Welding on bungs is asking for trouble. I prefer to avoid problems.
Removing the divider in the spacer and centering the injector will only soak the divider in the head; that would be pointless. Now, if the head has been ported and the divider has been removed, it's a none issue. Cleaning one valve is better than none and if your at this stage it would be safe to assume you have a catch can?
Meth has been sprayed for years in the cold pipe of top mounts using our boost tubes. This method completely soaks the silicone and there have been no issues.
If someone is interested in a preprod unit message me; I'll try and get another run off.
I do not have the time to play games people who only want to tear down the work that goes in to supporting this platform.
/unsubbed
VulgarKyle likes this.
Mauro_Penguin (12-29-2014), Putin 2.3T (12-29-2014), VulgarKyle (12-31-2014)
 Old 12-29-2014, 08:27 AM   #19
Tokay444's Avatar
Groans: 793
Did I stutter?
/unsubbed
After tapping there is little left for threading? Aren't they the same thing? I think you stuttered.
Many MANY people have drilled and tapped ported manifolds with no issue.
I'm all for creating new solutions, but spitting pure bullshit in an attempt to sell such solutions is where I take issue.
Demodded.
The Seals
Deldran (12-29-2014), Dumbguy (10-21-2015), Koke382 (01-02-2015), Micha (12-30-2014)
 Old 12-29-2014, 10:05 AM   #20
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
PM'd.
#Tokayhatesme
2011 Mazdaspeed 3 [Sold]
 Old 12-30-2014, 05:45 PM   #21
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Can we also have injector bungs on the other ports pleeeeeeeeeeeeease?
2013 CWP and Stock
Mauro_Penguin (12-30-2014)
 Old 12-30-2014, 05:49 PM   #22
You mean for a total of 8?
 Old 12-30-2014, 05:54 PM   #23
NCspecV81's Avatar
I mean't fuel injectors on one side and meth on the other. Not sure if that would even work, but if it could I'd wait specifically for that. I wanna run tons of meth and tuns of extra PI.
2013 CWP and Stock
 Old 12-30-2014, 05:58 PM   #24
Tokay444's Avatar
Groans: 793
Your powers of deduction are amazing.
Demodded.
The Seals
 Old 12-28-2014, 11:17 AM   #25
failsafes are meh in my opinion. most of them cant measure anything over 1000ml/mi so if you decide to go with 4 do4 or bigger,.... they'll be useless and bog your car down. pumps arent always as progressive. they can start nice and slow but then the failsafe will trigger... or if you decide to go wot out of no where and it starts fast and gives alot of fuel... failsafe triggers again.
im mainly talking about aem, snow and devils own.
#CATBACKEXHAUST
 Old 12-28-2014, 11:26 AM   #26
The AEM and Snow are like this because of the sensors they use. They are flow limited and failure prone.
This is why I recommend the Coolingmist and Aquamist. I have experience with all of these and these are the best ones, reliable and without false positives.
Even a built block can bake a piston if you run it too lean due to a WMI failure.
 Old 12-28-2014, 12:04 PM   #27
i concur with this.
@2.0t03speed;
his aquamist setup brings everything. but you're also paying a lot.
you get what you pay for.
#CATBACKEXHAUST
 Old 12-28-2014, 11:20 AM   #28
blake0521's Avatar
@Gr8Speed; do you know if meth will hurt the silicon on the jbr fmic piping? That is what I am running right now and I am trying to figure out where to put the pre tb nozzle since the bpv is so close to the tb.
And since I am only going for around 500 I was just going to run do1 nozzles or something small like that. Need to do some research on the correct size nozzles still. Build is in the VERY early stages still. Just trying to see how far I want to go since this will still be my dd.
2010 Mazda Speed3-
Mods:
Next up: tune.
Last edited by blake0521; 12-28-2014 at 11:20 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-28-2014, 11:24 AM   #29
Gr8Speed's Avatar
Stuff
 Old 12-28-2014, 11:24 AM   #30
do1 is too small
#CATBACKEXHAUST
 Old 12-28-2014, 11:34 AM   #31
blake0521's Avatar
Still trying to decide in turbo. The original plan was pte5858 but I am not sure if I would hate having a 500 whp dd car. Might pus out and just get a gtx28 and go for low 400s. That route will for sure be cheaper and easier to commute in. We will see once I get my block built what I decide to do.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 12:35 PM   #32
blake0521's Avatar
The funny part is the snow stage 2 kit with the flow gauge and safe inject is more expensive then the hs-3 system.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-28-2014, 08:19 PM   #33
blake0521's Avatar
Hell ya! Let me know if I can buy a preproduction one off ya @jbarone;
Also @jbarone; can you fmic piping handle pretb injection or will it eat the piping?
2010 Mazda Speed3-
Mods:
Next up: tune.
Last edited by blake0521; 12-28-2014 at 08:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-29-2014, 06:25 AM   #34
It depends on where you tap the runners. Relentless ported, powdercoated, and put in 4 meth nozzles for @tastysi2004; over a year ago. Pushing 30psi through it and haven't had a problem.
Micha (12-30-2014), Tokay444 (12-29-2014)
 Old 12-29-2014, 07:38 AM   #35
Tokay444's Avatar
Groans: 793
Sorry?
Bs? I'm not following.
Demodded.
The Seals
 Old 12-29-2014, 08:23 AM   #36
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
in 2013 i rebuilt my head ran it for a year (2013) without meth then i ran a do3 in each runner of my jmf intake all this last year and the valves were not clean. no large buildups but still black and some stuff on them.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 5 Users Say Thank You to mxlplx71 For This Useful Post:
Gr8Speed (12-29-2014), JBR (12-29-2014), Mauro_Penguin (12-29-2014), Micha (12-30-2014), Tokay444 (12-29-2014)
 Old 12-29-2014, 08:31 AM   #37
While methanol might not "clean" the valves (take away current build up/deposits on the valve stem). It will help prevent any further build up. At least that's what I've seen happen on my own car.
The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post:
Micha (12-30-2014), Nel Mazdaspeed (01-03-2015), Tokay444 (12-29-2014)
 Old 12-29-2014, 08:38 AM   #38
Also i just hit up Javi @ Relentless. I don't know how much material you are taking out, but there is enough left on his ported/flow benched manifolds for meth nozzles.
Tokay444 and tastysi2004 like this.
Mauro_Penguin (12-29-2014), tastysi2004 (12-29-2014), Tokay444 (12-29-2014)
 Old 12-29-2014, 08:40 AM   #39
Tokay444's Avatar
Groans: 793
Wow. Will you look at that.
Demodded.
The Seals
 Old 12-29-2014, 08:42 AM   #40
Matt@HTP's Avatar
Posts: 147   (View Stats)
Whats wrong with welding bungs? I've drilled and tap'd many stock manifolds with no problems. I do prefer nice bungs placed in the right spot. I'll take welded and right.
"Engineered" in an outhouse.
The Following 8 Users Say Thank You to Matt@HTP For This Useful Post:
2.0t03speed (12-29-2014), Deldran (12-29-2014), faeker (01-01-2015), Koke382 (01-02-2015), Mauro_Penguin (12-29-2014), Micha (12-30-2014), sleeperstang1994 (12-29-2014), Tokay444 (12-29-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f433/direct-meth-injection-help-181350/
Show us your intakes!! ? Mazda MPS Owners Club This thread Refback 12-30-2014 05:38 PM
Direct Injection Injectors h.h.sk1nny MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 31 08-15-2018 04:43 PM
Methanol Direct Injection phate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 290 10-01-2014 09:34 PM
Direct Injection Systems mrlilguy157 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 04-07-2014 01:51 PM
The Dangers of Direct Injection CorkSport CorkSport 0 02-20-2013 04:20 PM
direct port meth injection with stock mani? xcoldricex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 06-24-2010 05:24 PM
Page generated in 0.66404 seconds with 32 queries
