  • 1 Post By ProChargedLS2
 Old 11-15-2019, 01:21 AM   #15
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Yeah, nothing seems wrong there. If it happened in a single moment I could get a better idea of what happened, but since it gradually got worse I'm at a loss for ideas here. The hprv is somewhat new. Swapped it out this spring, and it doesn't appear to be stuck open or shut.
Is there any chance that maybe a seal or a cylinder ring broke? Even if that was the case I feel like it'd have taken effect much faster than this did
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
Fuel Tank Swap. Help JFord 2010 MS3 - Fuel, Nitrous & Water Injection 0 05-05-2017 11:30 AM
Click click click from driveline robacks MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-14-2015 01:57 PM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 08:44 PM
Page generated in 0.35544 seconds with 25 queries
