  • 1 Post By ProChargedLS2
 Old 10-26-2019, 11:09 PM   #1
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Default Fuel nozzle didn't click off, over filled tank
I was filling up at my regular point I always do, which takes about 13 gallons give or take .2
I wasn't watching the pump, was focused on the guy acting like a fool in the gas station. I felt like it was taking way too long so I glanced up at the pump to see how slow it was going, only to see it put in 16 gallons. Fuck... a little top off won't end the world but 3 gallons dude? Fuck me.
It ran fine at first and I was hoping I dodged the bullet, but after 5 miles it started running really lean and flaring up and stuttering if I didn't get it up to 1600 manually. Went in the store, came out and tried it again but my idle afr goes from 18-24 so I shut that sucker down before something broke because it was running so bad.
Am I gonna need an entirely new charcoal canister? Or should I bother trying to siphon some fuel out from the tank and driving it back home so I can drain the canister. Really don't want to tow it.
Ms3stock likes this.
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
Fuel Tank Swap. Help JFord 2010 MS3 - Fuel, Nitrous & Water Injection 0 05-05-2017 11:30 AM
Click click click from driveline robacks MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-14-2015 01:57 PM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 08:44 PM
Page generated in 0.35080 seconds with 24 queries
