 Old 07-11-2017, 12:37 PM   #1
_Mazdarati's Avatar
Posts: 90   (View Stats)
_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of_Mazdarati has much to be proud of
Default Fuel Pressure Woes
I have a big issue. My fuel pressure is shit right now. Literally started the car and started driving, all of a sudden it went crazy. Now have a loud mechanical noise by the HPFP area. Pressure during idle is anywhere from 75-275psi... Driving I can't get over 1100psi. I will have misc. knock readings and my trims are well above where they usually are. I HAVE AUTOTECH INTERNALS ALREADY INSTALLED, have had them for well over 30k. I already checked the spill valve, and cleaned it. Already pulled the entire pump, and nothing was visually wrong with it. I'm thinking about putting back in my stock internals and seeing if the issue is the same just for the fuck of it. I'm out of ideas at this point for a fix. Anybody have any ideas or had this issue before? Also checked all connections to the pump as well.
And for some reason this shit won't let me post my datalog. So I'll try and find a way to do that eventually.
Sent from my SM-G955U using Tapatalk
2011 MS3 Tech Package
BNR S4v2
HTP 4" intake
CS injector seals
Grimmspeed 3-port EBCS
Full Race FMIC
CPe Triton catback exhaust
ATP long catless DP
E85
HYPNOTIC TUNED
_Mazdarati is offline   Reply With Quote
 Old 07-15-2017, 06:57 PM   #2
_Mazdarati's Avatar
Follow up to the post, swapped the high pressure relief valve and everything is in working order.
BNR S4v2
HTP 4" intake
CS injector seals
Full Race FMIC
ATP long catless DP
E85
HYPNOTIC TUNED
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
Fuel Pressure woes BMC Gen2 MS3 General Discussion 58 06-03-2017 03:07 PM
Fuel Pump Woes 1r15h 2010 MS3 - Troubleshoot/Diagnostics 99 12-26-2013 03:43 PM
purple drank oil pressure woes Captain KR MazdaSpeed 6 - Engine, Transmission & Driveline 77 11-09-2013 06:39 PM
Fueling woes... Low fuel pressure Aero MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 06-16-2013 10:03 PM
Page generated in 0.24125 seconds with 20 queries
