 Old 05-20-2012, 05:06 AM   #1
whitewater's Avatar
Posts: 39   (View Stats)
whitewater has a spectacular aura aboutwhitewater has a spectacular aura about
Default Fuel Pumps - Gen 1 & Gen 2 MS3&MS6
Are there differences between the gen 1 MS3 and MS6 fuel pumps and the gen 2 fuel pumps? Looking to purchase a 2nd one to upgrade and keep my stock pump as a back-up or for future mods.
I searched and did not find any threads with info on this.
Any help or direction is appreciated. Thanks.
2012 VRM Mazdaspeed3 w/ Tech Package - "Gracy"
whitewater is offline   Reply With Quote
 Old 05-20-2012, 06:09 AM   #2
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
You did not search... the pumps are the same but if you are doing any modding at all get an aftermarket pump
http://www.mazdaspeedforum.org/forum/foru...closely-69969/
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 05-20-2012, 06:19 AM   #3
Resident Baus
Groans: 34
you are still neuberton status which is fine but seriously just look around, there are so many freaking resources here. Read this thread first:
http://www.mazdaspeedforum.org/forum/foru...st-read-99499/
Your first few mods should go: datalogger (Cobb AP) -> fuel pump internals (Autotech) -> and theennnnnn an intake. I know those first two are expensive but they will provide you a platform to either be badass with just a bolt-on or two, or go big.
2011 Black Mica MS3
The Following User Says Thank You to duappleganger For This Useful Post:
Rich990 (05-24-2012)
 Old 05-20-2012, 08:07 AM   #4
whitewater's Avatar
Read both of them and must have over looked the fact that the pumps are the same. Planning on getting a new/2nd hand pump and upgrading the internals so I have the fuel pressure to build on for future mods. Datalogging will come after upgraded FP.
Thanks
 Old 05-20-2012, 08:20 AM   #5
Resident Baus
Groans: 34
my bad i misread your original post, oh well. best of luck!
2011 Black Mica MS3
whitewater (05-20-2012)
 Old 05-20-2012, 05:09 PM   #6
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
the pumps are the same, chances are you're never gonna need an EXTRA fuel pump
most failures happen if you do 100% e85 or if install your internals wrong.
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 05-24-2012, 02:43 AM   #7
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
are you ever going to bolt the one with stock internals back on? not likely if you're running one with upgraded internals.
save the money and put it towards the AP.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
The Following User Says Thank You to Rich990 For This Useful Post:
whitewater (05-24-2012)
Prices of fuel pumps?? Why so different mazdaspeed4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 23 03-16-2012 11:59 AM
If Fuel Pumps are necessary, why no TSB? Silver Ecstasy 2010 MS3 - Fuel, Nitrous & Water Injection 52 09-07-2011 07:19 PM
Cp-e or PTP fuel pumps? manelscout4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 99 06-09-2010 05:32 PM
Fake Walbro Fuel Pumps melly mel MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 5 09-01-2009 01:21 PM
AP users w/upgraded fuel pumps... Speedn3
Cobb Access Port/Maps
30 12-08-2008 07:14 PM
Page generated in 0.30769 seconds with 23 queries
