Like Tree22Likes
 Old 06-29-2016, 01:24 PM   #1
kryskunka's Avatar
Posts: 83   (View Stats)
kryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to all
Default help with internals
I know this is an old thread but i need help immediately. I have a stock 2013 mazdaspeed3 and just put on autotech high pressure fuel pump internals and i have 3 check engine light codes and the turbo is not getting boost at all. Any help would be great
kryskunka is offline   Reply With Quote
 Old 06-29-2016, 01:37 PM   #2
What are the CEL's?
Did you remove the intake to do the internals and forget to hook up the EBCS when putting it all back together?
We nee more information to help you. Help us, help you.
 Old 06-29-2016, 01:47 PM   #3
kryskunka's Avatar
The 3 check engine lights are
P0171
P0192
P0089
Turbo is not getting boost. Went to a local performance shop and they said the engine can detonate at any moment. Got me scared as fuck
And yes I took out the intake and I didn't forget to plug anything back in
Last edited by kryskunka; 06-29-2016 at 01:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-29-2016, 01:48 PM   #4
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
break/ crack the nipple on the little plastic ebcs?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
Gerbilo (06-29-2016), WetzMS3 (06-29-2016)
 Old 06-29-2016, 01:50 PM   #5
OP, do you know where the EBCS is located?
 Old 06-29-2016, 02:00 PM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You forgot to plug something back in.
And you know enough to install the internals yourself, but couldn't google the engine codes to see what they are?
What "performance shop" told you the engine could blow at any moment? Was that just because they weren't getting paid to take a look at it?
Seriously, go back over everything, you most likely forgot to plug something in.
Or you didn't install the internals correctly, that could be it also.
Last edited by g00s3y; 06-29-2016 at 02:00 PM. Reason: MSF Database - Automerged Doublepost
MS3Shadow (06-29-2016), WetzMS3 (06-29-2016)
 Old 06-29-2016, 02:02 PM   #7
kryskunka's Avatar
That's what the local performance shop told me. They said 2 of the 4 cylinders were gunna blow and that I'm an idiot for getting high pressure fuel pump internals on this car because it doesn't need it. My buddy that installed them will look over every thing tommorow. I know one of the codes is p0171 which means too lean I think
 Old 06-29-2016, 02:05 PM   #8
blackms3_71, PapaBruno and 20boxer like this.
The Following 10 Users Say Thank You to WetzMS3 For This Useful Post:
Dralphy (06-29-2016), GAMISTAD (07-23-2016), KiwiFlavor (06-30-2016), mxlplx71 (06-29-2016), sharksinspace (06-29-2016), speed3okie (06-30-2016), SPEEDingTicket (07-01-2016), stockms3 (07-09-2016), Vansquish (06-29-2016), xfeejayx (06-29-2016)
 Old 06-29-2016, 02:09 PM   #9
kryskunka's Avatar
I have CEL p0171 which is system is too lean. I have p0192 which is fuel rail pressure sensor and p0089 which is fuel pressure regulator failure. I don't know if this car is safe to drive at this moment. I'm kind of a noobie sorry for the ignorance
blackms3_71 likes this.
 Old 06-29-2016, 02:10 PM   #10
you shouldn't go to that shop again.
The Following 9 Users Say Thank You to MS3Shadow For This Useful Post:
AwAfrican (06-29-2016), Gerbilo (06-30-2016), InkedInspector (06-30-2016), JakeMS3 (06-29-2016), KiwiFlavor (06-30-2016), mxlplx71 (06-29-2016), sharksinspace (06-29-2016), speed3okie (06-30-2016), stockms3 (07-09-2016)
 Old 06-29-2016, 02:11 PM   #11
It is not safe to drive. You left something unplugged. Either a connector on the injector harness, or the ground on the HPFP body.
 Old 06-29-2016, 02:12 PM   #12
kryskunka's Avatar
But is that the reason the turbo isn't producing any boost? The turbo is spooling a bit but no boost at all its giving me
The Following User Says NO Thank You to kryskunka For This Un-useful Post:
 Old 06-29-2016, 02:14 PM   #13
You probably ALSO left the EBCS either disconnected or missing a vac line, or broken.
InkedInspector (06-30-2016), KiwiFlavor (06-30-2016)
 Old 06-29-2016, 02:15 PM   #14
g00s3y's Avatar
Groans: 438
And first you installed internals, now a buddy installed them. I have a feeling there is more to this story that isn't being told. Did the shop say they weren't needed, or did your buddy say that? If you didn't install them, how do you know everything was put back together?
Internals either installed wrong or a connector that was left unplugged, or both. Tell your buddy to learn how to install parts on a car properly, especially if it isn't his.
Also, how could they tell 2 & 4 were going to blow? Did they open the hood and say "yep, that's fucked up".
"performance shop" lmao
Last edited by g00s3y; 06-29-2016 at 02:15 PM. Reason: MSF Database - Automerged Doublepost
Djohns (06-29-2016), MD1032 (06-30-2016)
 Old 06-29-2016, 02:15 PM   #15
kryskunka's Avatar
Yeah I don't think I'll go to that shop again. Maybe they were just trying to scare me. They told me this car has a glass motor and I can do whatever mods I was on this car without having to put high pressure fuel pump internals. But I told him the first thing you do is high pressure fuel pump internals on this car
 Old 06-29-2016, 02:17 PM   #16
How does this sentence even make sense? Glass motor, but does not need proper fueling?
Djohns (06-29-2016), InkedInspector (06-30-2016), MD1032 (06-30-2016)
 Old 06-29-2016, 02:17 PM   #17
kryskunka's Avatar
My buddy did the install for me. I watched him do it. The performance shop didn't look under the hood. They just looked up the codes and told me all this stuff. My buddy has a speed3 with the internals as well and did them for me today and now all this stuff happened
 Old 06-29-2016, 02:21 PM   #18
g00s3y's Avatar
Groans: 438
Ok, well something isn't connected, so go check under your hood. Or get your buddy back to do it for you.
 Old 06-29-2016, 02:21 PM   #19
kryskunka's Avatar
I think the local performance shop that I went to was just trying to scare me. As of right now my car is going to sit in the garage and my buddy with the speed3 that did the actual install will see to make sure everything is connected
 Old 06-29-2016, 02:25 PM   #20
Who is your buddy? Is he on here?
g00s3y (06-29-2016)
 Old 06-29-2016, 02:26 PM   #21
g00s3y's Avatar
Groans: 438
Because you don't know how to open your hood and check connections?
 Old 06-29-2016, 02:35 PM   #22
kryskunka's Avatar
I opened the hood and checked all the connections I'm pretty sure and everything seemed okay. My buddy with his speed3 I'm not sure if he is on the forums. If anything I will take it to speed performance which is a very good mazdaspeed3 auto shop in my town
 Old 06-29-2016, 02:52 PM   #23
kryskunka's Avatar
I was an idiot to go to some local performance that doesn't know anything about these cars. I should of went to Speed Perf6manc3 in the first place. Serves me right
 Old 06-29-2016, 03:23 PM   #24
kryskunka's Avatar
Btw thanks for all the help from everyone. Yes I do admit I'm a huge noob that doesn't have the biggest knowledge on cars obviously but I'm just trying to learn as well
 Old 06-29-2016, 03:56 PM   #25
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Why were you even TRYING to build boost with three engine codes that are going to 'blow up your glass engine?'
Good idea parking it till your buddy can check it.
-Wetz
QFT
 Old 06-29-2016, 03:59 PM   #26
kryskunka's Avatar
I was just trying to see how the car was running and I noticed I was building no boost what so ever. That stupid performance shop told me this car has a glass motor and easily breaks
The Following User Says Thank You to kryskunka For This Useful Post:
voodoo2crue (06-29-2016)
 Old 06-29-2016, 04:17 PM   #27
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
I don't know what's worse. Reading his stories, or reading the horrific grammar and the lack of punctuation.
The Following 3 Users Say Thank You to Say Chi Sin Lo For This Useful Post:
InkedInspector (06-30-2016), KiwiFlavor (06-30-2016), Vansquish (06-29-2016)
 Old 06-29-2016, 04:21 PM   #28
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Lmfao, I needed this statement today. Thank you
Sent from my SAMSUNG-SM-G890A using Tapatalk
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 06-29-2016, 04:21 PM   #29
kryskunka's Avatar
I apologize
 Old 06-29-2016, 04:57 PM   #30
uh60gunner209's Avatar
Posts: 106   (View Stats)
uh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud ofuh60gunner209 has much to be proud of
Groaned at 8 Times in 3 Posts
There is a youtube video of someone installing the corksport internals and you can look at all the hoses and connectors to get an idea what to look for. And for the record youtube has a video for almost everything.
uh60gunner209 is offline   Reply With Quote
 Old 06-29-2016, 05:00 PM   #31
Djohns's Avatar
Posts: 3,944   (View Stats)
Well shit, if we don't need internals I wasted $320 awhile back. Hell almost everyone on this forum wasted their money. Damn aftermarket propaganda, don't they know our fine china motors can handle any amount of power? Like a rock in a china shop!
2010 black mica speed3
Soon:built motor
The Following 4 Users Say Thank You to Djohns For This Useful Post:
InkedInspector (06-30-2016), KiwiFlavor (06-30-2016), monkey.bones.007 (06-29-2016), Vansquish (06-29-2016)
 Old 06-29-2016, 05:07 PM   #32
I'm still trying to figure out how those codes computed in their minds to read as 2 of the 4 cyl are about to explode... lol I think this shop should stick to selling xl spoilers and lowering springs... leave the engine work to the people who actually know somthing about them.
 Old 06-29-2016, 05:10 PM   #33
Djohns's Avatar
You mean cut OEM springs?
Soon:built motor
 Old 06-29-2016, 05:14 PM   #34
Oh my bad lol yes cut oem springs... lol they probably have a lowering kit that involves only zip ties... lots of zip ties
 Old 06-29-2016, 05:24 PM   #35
kryskunka's Avatar
Yeah thanks. Tommorow me and my buddy will check all the connections again. If nothing is solved. I'll go to speed Perf6man3e which is a very reputable mazdaspeed shop
 Old 06-29-2016, 06:03 PM   #36
PearlySpeed's Avatar
Posts: 122   (View Stats)
PearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud of
Make sure your dash doesn't say zoom-zoom-boom
PearlySpeed is offline   Reply With Quote
 Old 06-29-2016, 07:29 PM   #37
mxlplx71's Avatar
Groans: 128
Where are you, there must be a local Nator that can look at it.
uh60gunner209 likes this.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-29-2016, 07:44 PM   #38
Sounds like he's up near @Voltron;'s way.
brandonf (07-05-2016), KiwiFlavor (06-30-2016), mxlplx71 (06-29-2016), xfeejayx (06-30-2016)
 Old 06-29-2016, 07:59 PM   #39
kryskunka's Avatar
I'm located in central jersey
 Old 06-29-2016, 08:49 PM   #40
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
I wanted to call troll on this so bad, but you've named too many details about the subject to sway me otherwise. Watch the videos and read the how-to threads on here and re-do everything yourself. Your friend has internals yet he fucked up the install on yours? I'm still rolling from the shop that said your cylinders were going to blow without even popping the hood and performing any type of compression check or diagnostic check on your engine.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
The Following 2 Users Say Thank You to JakeMS3 For This Useful Post:
uh60gunner209 (06-29-2016), Vansquish (06-30-2016)
KDM Internals soaringeagle129 Mazdaspeed3/6 General Discussion 6 02-07-2012 02:13 PM
Page generated in 0.54815 seconds with 32 queries
