Like Tree22Likes
 Old 06-29-2016, 09:38 PM   #41
kryskunka's Avatar
Posts: 83   (View Stats)
kryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to all
Yeah I'm gunna go over everything tommorow and see how it goes. Hopefully it'll all work out. And yeah I'm an idiot for going to that performance shop. Once the guy told me my engine might blow up at any time, I just left because clearly he didn't know a clue about mazdaspeed or in general even. He bragged he's been doing this 18 years and said I'm doing everything backwards and wrong.
kryskunka is offline   Reply With Quote
 Old 06-29-2016, 10:57 PM   #42
rocknrolla47's Avatar
Posts: 77   (View Stats)
rocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nice
Groaned at 14 Times in 6 Posts
You left something unplugged you got all these codes out of no where. Did you check to see that you removed and re installed the right fuses ? Check the connection by the fuel pump ?
Do you have a fuel monitor device like a gauge or accessport ? Most likely forgot make sure the connector to the fuel pump is properly connected.
Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate-
rocknrolla47 is offline   Reply With Quote
 Old 06-30-2016, 07:12 AM   #43
kryskunka's Avatar
Were checking all the fuses and connections right now
 Old 06-30-2016, 07:35 AM   #44
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Better question is, why even remove any fuses in the first place? If you're that worried about the electrics, disconnect the fucking battery.
Those codes don't make any sense at all to me:
P0171: This is an intake leak. You probably broke something or left something disconnected. I don't know why you even removed the intake.
P0089: Your spill valve is fucked, or not operating properly, or the "cylinder" of the fuel pump internals is installed upside-down. You are not building above in-tank fuel pump pressures.
P0192: This sensor is literally on the other side of the engine and I have no idea WTF is going on here. Maybe a bad fuse.
2007 Mazdaspeed3 GT
InkedInspector (06-30-2016), KiwiFlavor (06-30-2016)
 Old 06-30-2016, 07:54 AM   #45
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Sounds like he's up near @Voltron;'s way.
OP how old are you? He might be able to help.
2012 NASA Spaceship Gray MS3
The Following 5 Users Say Thank You to KiwiFlavor For This Useful Post:
brandonf (07-05-2016), g00s3y (06-30-2016), InkedInspector (06-30-2016), monkey.bones.007 (06-30-2016), WetzMS3 (07-01-2016)
 Old 06-30-2016, 08:38 AM   #46
kryskunka's Avatar
Well we took everything out and found out what happened. I'll post a pic. It basically broke on me
 Old 06-30-2016, 08:39 AM   #47
KiwiFlavor's Avatar
Oh noes...
 Old 06-30-2016, 08:41 AM   #48
kryskunka's Avatar
Yeah it cracked and broke off
 Old 06-30-2016, 08:44 AM   #49
Make sure u don't have any broken pieces in the pump before you put it back , make sure it's completely clean. Never seen internals break like that. Probably had the retaining clip on loose. ?
 Old 06-30-2016, 08:45 AM   #50
kryskunka's Avatar
No it was on tight we made sure. I don't know how this happened. I lost out on a lot of money
 Old 06-30-2016, 08:45 AM   #51
MD1032's Avatar
Groans: 143
When you disassembled it, were the keepers still where they were supposed to be?
edit: It's not that bad. Autotech will warranty them.
blackms3_71 likes this.
2007 Mazdaspeed3 GT
 Old 06-30-2016, 08:46 AM   #52
Call them up and get your money back. Get some corksport internals.
The Following User Says Thank You to rocknrolla47 For This Useful Post:
uh60gunner209 (06-30-2016)
The Following 4 Users Say NO Thank You to rocknrolla47 For This Un-useful Post:
Djohns (06-30-2016), g00s3y (06-30-2016), MD1032 (07-01-2016), Vansquish (06-30-2016)
 Old 06-30-2016, 08:48 AM   #53
KiwiFlavor's Avatar
If you bought them new you might be able to get them warrantied.
Hopefully it's not #inb4installererror .
MD1032 (06-30-2016), speed3okie (06-30-2016)
 Old 06-30-2016, 08:52 AM   #54
kryskunka's Avatar
They were done right. Never seen this happen before
The Following User Says Thank You to kryskunka For This Useful Post:
 Old 06-30-2016, 08:53 AM   #55
Are they used or new ?
 Old 06-30-2016, 08:57 AM   #56
bennyzoom's Avatar
Posts: 20   (View Stats)
bennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of lightbennyzoom is a glorious beacon of light
Were the internals torqued correctly? (35~40 ft/lbs)
bennyzoom is offline   Reply With Quote
 Old 06-30-2016, 08:57 AM   #57
kryskunka's Avatar
They're used. Had 20k miles on then.
The Following User Says NO Thank You to kryskunka For This Un-useful Post:
 Old 06-30-2016, 09:00 AM   #58
KiwiFlavor's Avatar
Ouch man.. damn! That sucks!
 Old 06-30-2016, 09:02 AM   #59
I don't think you can get them warrantied. Why did the guy sell them ? 20k miles on them and he sold them, that right there is a red flag. Unless he was parting out a good used mazdaspeed. Never buy used parts that are important motor components especially when they have to do with fueling.
 Old 06-30-2016, 09:08 AM   #60
kryskunka's Avatar
The guy sold then because he was parting out his mazdaspeed3. I just found out his mazdaspeed3 was a track car and he sold them to me
 Old 06-30-2016, 09:13 AM   #61
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
they were either disassembled or reassembled wrong. Ive never seen anything like that before.
any marks on it around the cracked area?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 3 Users Say Thank You to mxlplx71 For This Useful Post:
KiwiFlavor (06-30-2016), Vansquish (06-30-2016), WetzMS3 (07-01-2016)
 Old 06-30-2016, 09:15 AM   #62
kryskunka's Avatar
Were putting back the stock internals back in. Hopefully everything goes back to normal
No there were absolutely no marks around the cracked area
Last edited by kryskunka; 06-30-2016 at 09:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-30-2016, 09:17 AM   #63
That sucks man now u have to repeat the process. Get some corksport internals , u won't look back. They come with new parts so u don't have to reuse stock components.
The Following User Says NO Thank You to rocknrolla47 For This Un-useful Post:
g00s3y (06-30-2016)
 Old 06-30-2016, 09:21 AM   #64
kryskunka's Avatar
This is what it looked like when we took it out
 Old 06-30-2016, 09:23 AM   #65
kryskunka's Avatar
I put the stock internals back in and now we have the same 3 check engine lights as before
 Old 06-30-2016, 09:24 AM   #66
That doesn't look like auto tech retainers. The autotechs retainers have 2 little clips you put on. That looks like the stock retainer clip.
Clear the codes and wait to see if they come back.
Last edited by rocknrolla47; 06-30-2016 at 09:24 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-30-2016, 09:25 AM   #67
KiwiFlavor's Avatar
Those clips are in there in the picture
mxlplx71 (06-30-2016)
 Old 06-30-2016, 09:28 AM   #68
Police - Grammarhead
Vansquish's Avatar
Did you bother to clear the codes after you reinstalled the stock internals?
 Old 06-30-2016, 09:30 AM   #69
Hmm idk I think that's the stock tap style clip
 Old 06-30-2016, 09:39 AM   #70
kryskunka's Avatar
I'm getting the car taken to the dealership. The car is still under warranty so they'll just give me a whole new pump I guess
 Old 06-30-2016, 09:39 AM   #71
KiwiFlavor's Avatar
I dont recall my stock one having clips..
EDIT: Anyway, OP good luck man. This sucks big donkey balls
monkey.bones.007 (07-01-2016)
 Old 06-30-2016, 09:39 AM   #72
kryskunka's Avatar
Yeah I tried clearing the codes. They kept coming back the same ones.
 Old 06-30-2016, 09:42 AM   #73
Lol my fault I see them now , screen was too dimmed.
 Old 06-30-2016, 09:48 AM   #74
MD1032's Avatar
Groans: 143
The keeper on the top in that photo is not seated all the way. That is probably the source of the failure.
2007 Mazdaspeed3 GT
Djohns (06-30-2016), WetzMS3 (07-01-2016)
 Old 06-30-2016, 10:00 AM   #75
kryskunka's Avatar
Since this car is still under warranty. The dealership should just put in a new fuel pump and the fuel pump sensors. And then I'll just have to buy new high pressure fuel pump internals again sadly ://
I don't think this car is safe to drive though at the moment
Last edited by kryskunka; 06-30-2016 at 10:00 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-30-2016, 10:01 AM   #76
KiwiFlavor's Avatar
What are your mods? If you're stock, you should be OK with the stock fuel pump.
 Old 06-30-2016, 10:01 AM   #77
Well good luck with your car op. Hopefully some easy fixes
 Old 06-30-2016, 10:09 AM   #78
kryskunka's Avatar
The car is bone stock still. But the same thing keeps happening. It's idling badly, turbo is not getting boost, barely any acceleration what so ever. Barely any power feels like
 Old 06-30-2016, 10:10 AM   #79
How does the fuel pump sound is it ticking normally ?
 Old 06-30-2016, 10:18 AM   #80
KiwiFlavor's Avatar
Install your stocker back on. Also you said you still have a warranty, bring it back to the dealership.
KDM Internals soaringeagle129 Mazdaspeed3/6 General Discussion 6 02-07-2012 02:13 PM
Page generated in 0.53286 seconds with 27 queries
