 Old 05-22-2019, 02:20 PM   #1
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
Default High pressure when coasting
As per this datalog, the desired vs actual HPFP shows a huge discrepancy once I let off the throttle. Is this normal?
The thing I see is that the actual psi remains very high after letting off the throttle and coasting. The afr shows 29.xx like it should, and I have no issues with backfiring or anything like that.
I assume the psi should drop immediately when there's zero throttle, yet it takes a blip or two of throttle to calm it down and get to a reasonable 400 psi.
Here's a video of the ap in action. Do you all see this on your speeds? Thanks
https://youtu.be/kwSCWbU99Bc
Sent from my Pixel 3 using Tapatalk
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 05-22-2019, 09:54 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You let off the throttle, ecm cuts the injectors way back, fuel in the rail has nowhere to go, so pressure stays high until some of that fuel is used.
It's normal.
The Following User Says Thank You to SSinstaller For This Useful Post:
Sonofnothing (05-23-2019)
 Old 05-23-2019, 06:27 AM   #3
Thank you
Fuel pressure too high after WOT SlamChop 2010 MS3 - Fuel, Nitrous & Water Injection 12 02-14-2018 12:24 PM
High Boost on wastegate pressure nekret 2010 MS3 - Turbo Induction 28 03-25-2015 10:57 AM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Page generated in 0.23843 seconds with 22 queries
