![]() Join Date: Feb 2011 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
(Thread Starter) | Not Ranked : 0 score Does anybody also know how to change this line. From looking intothe engine bay, it seem like a painful job swap this piece of shit out. Edit: Found a how to for swapping: how to high pressure fuel line porting But still need part number. Last edited by MPS_Fan; 06-16-2013 at 02:27 PM. |
| The Following User Says Thank You to MPS_Fan For This Useful Post: | atvfreek (06-19-2013) |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score L3K9-13-290A
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
| The Following User Says Thank You to twenty5psi For This Useful Post: | kritz (06-16-2013) |
(Thread Starter) | Not Ranked : 0 score Thanks, wanted to order it in germany, but it costs here 240$, WTF !?!?!?! Ordered at Onlinemazdaparts, for 136$ shipped to germany... |
| Not Ranked : 0 score Not the most fun job, but it's do-able. You'll have to take off part of the intake at least, the line has brackets holding it that you have to undo(you'll see on the new part.) You can sneak it out from underneath the EGR pipe though.
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score Jb weld!!! All kidding aside, glad you didn't go boom! Good luck with install!
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
| The Following User Says NO Thank You to ms3rick For This Un-useful Post: | Hoyoman (06-19-2013) |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Pics of crack. Can see if we can source one here for you if you'd like. Do you have a MK1 or MK2? Also can see if a mate of mine has one floating around in the UK. Let me know.
__________________ Nator is what it does. |
| Not Ranked : 0 score Should have posted a wanted-to-buy, I have a spare lying around, good luck with install.
(Thread Starter) | Not Ranked : 0 score I need it within next few days, because my car is DD. So you would have to ship it via express... That would cost about the same. My car could have start burning, because fuel was spraying directly on my exhaust mani. Its a part that should never fail, because it could end with ZZB. Its all the same with the car manufacturer, using cheap ass China shit everywhere they can. |
| The Following User Says Thank You to MPS_Fan For This Useful Post: | Code Monkey (06-16-2013) |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score Mine cracked at the rail side and I had fuel running on the tranny. Swap isn't too bad, hardest part for me was getting that housing or shielding by the rail off cause I couldn't see the bolts. But I think all I took off was intake up to inlet. Definately doable just take your time.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
(Thread Starter) | Not Ranked : 0 score I attached a picture of the crack. Like you see it cracked directly where it bends. Since I only have 15k miles and never touched this line, it looks like a material fault. I needed only 45mins to remove this part, you don´t have to drain coolant or do another crazy things like in the how to. I only removed TMIC, Battery+Tray, Intake (TIP still inside). Thats all! You just need some good tools and a good feeling, because some bolts are hidden. I hope my new part will arrive tomorrow! |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | Sergeant_M (10-05-2014) |
| Not Ranked : 0 score Did you guys have all the bolts holding it in place and bracing?
(Thread Starter) | Not Ranked : 0 score Yes! I think its cheap galvaniced steel made in china. It cracked directly where its most stressed during bending procedure. The wall thickness of the line is good, but the material is probaly shit... @Lex If onlinemazdaparts shipped the part yesterday like they told, i should rock that bitch tomorrow again. Will send you logs from last revision |
| The Following User Says Thank You to MPS_Fan For This Useful Post: | Lex (06-19-2013) |
| Not Ranked : 0 score This is a major safety hazard. This could easily trigger a recall. I would take it to the dealer and make a case if you have the time since if that line is untouched it can happen on stock cars.
This is a major safety hazard. Especially with the high pressure fuel vapor that was going into the engine bay while the engine was running.
(Thread Starter) | Not Ranked : 0 score The line sprayed fuel directly on my exhaust header. The car could have start burning! |
| Not Ranked : 0 score Post a picture of the line and its location and where it cracked in the engine bay if you can. We can do a warning and people can look it over and take it into dealers if any cracking is seen.
| Not Ranked : 0 score In the picture that is posted above, that is the bend that goes up to the HPFP. Mine cracked at the same bend, but was spraying toward the battery. I'm trying to find the pic of mine and when I find it, I will post it as well.
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score I attached a picture where you can see the whole line. It cracked in direction to the engine. maybe i should send the picture directly to mazda. I was thinking about towing the car to mazda dealer, but didn´t want to pay for towing it to dealer. so decited to fix it by myself. |
![]() | | #20 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score I have had mine crack twice when I owned a MS6, both were near the rail where the 1/4 line goes into the larger end/flange. Definitely not good to happen when you are out of town with no Nator people around in the middle of nowhere.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #21 | ![]() |
![]() Join Date: Feb 2011 Location: Nellis AFB , NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 92 Times in 11 Posts
| Not Ranked : 0 score Just going out on a limb here, but pulling this line out of the way in order remove the CDFP and install FP internals, could cause stress in that region if you bend it down enough no ? Its certainly a possibility.
__________________ --Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned -- |
![]() | | #22 | ![]() |
Did not applied any pressure on line, since it lines up perfectly without force if you do the install correct. I have many years mechanic experience, so it was no install error | |
![]() | | #23 | ![]() |
| Not Ranked : 0 score It's always a possibility. However my internals were in since my car had 5k miles. So it went 30+k miles and almost 3 years. But it doesn't mean it wasn't stressed from the internals install
![]() | | #24 | ![]() |
| Not Ranked : 0 score This is a good reason to be careful during the internals install. I think we will have a hard time finding a car without internals that this has happened to simply because internals are something everyone puts in. The pressure spikes in the line from normal operation do affect it as they create vibrations and resonances. So a weak point can crack at a much later time. The failure here is pretty serious as it can cause a pretty bad fire.
![]() | | #25 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score So are you saying that by installing internals is the risk or by having the internals in and running 1750 psi is putting greater stress on that line?
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() | | #26 | ![]() |
| Not Ranked : 0 score @Tokay444 @SilverDemon Looks like it work hardened and fractured to me, but that is not a area where it should work harden from vibration or heat expansion/contraction. That should be mostly at the ends of the line. It also looks worn in that area, maybe the material was or got too thin and the metal itself failed. This doesnt seem like the normal CDFP hard line failure to me.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | atvfreek (06-19-2013), SilverDemon (06-19-2013) |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score That crack does not look like to me that it was from removing the pump by bending the line out of the way. I would think a crack would develop on the inside or outside of the bend. I am curious, were the bolts that affixes the clamp on the hard line tight?
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
![]() | | #28 | ![]() |
Groans: 91
| Not Ranked : 0 score mine cracked at the round part that connects to the rail with the two bolt holes. where it comes out. never touched that side prior, only the other side to do internals 3 times. cracked just opposite the o ring.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Hard to say at the moment what the root cause is. Maybe not a bad idea to loosen the line a little when maneuvering it to install the HPFP just to avoid any stresses. Was the line rubbing against anything at that point? That area looks scuffed up.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score It looks scufffed because I sanded some material down to check it for bubbles. The line itself was looking perfectly fine when I removed it. |
![]() | | #31 | ![]() |
Groans: 95
| Not Ranked : 0 score I located one for you in the UK Klaus, I sent your contact info to him. His name is Ross. Sent from fastest ko4 Pu!
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got your mail. Thanks!!! |
![]() | | #33 | ![]() |
![]() Join Date: Aug 2012 Location: Auburn, MI
Sent from my iPad using Tapatalk HD
__________________ '12 Velocity Red Mica MS3 Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness [SIGPIC][/SIGPIC] | |
![]() | | #34 | ![]() |
![]() Join Date: Nov 2011 Location: Temecula, CA
Rep Power: 118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
| Not Ranked : 0 score Absolutely this should be a recall. There was a very similar recall (faulty fuel line in the engine compartment) to a batch of 300Z's in the 80's, one of which I bought used - unaware of the recall. Car ended up immolating itself. |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2010 Location: Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 474
| Not Ranked : 0 score Has there been any updates to this? A fix? An aftermarket solution?
__________________ 2010 MS3 Black 395whp/386wtq | Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters |
![]() | | #36 | ![]() |
| Not Ranked : 0 score No.
![]() | | #37 | ![]() |
| Not Ranked : 0 score Seems like this should be the next order of business. I blew mine today, very Frustrated. I'm sure I'll run into this problem again down the road.
| The Following User Says Thank You to Snotrocket For This Useful Post: | Code Monkey (06-20-2014) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I should probably send my cracked line to Mazda.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Snotrocket (06-20-2014) |
![]() | | #39 | ![]() |
![]() Join Date: Oct 2012 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 252
| Not Ranked : 0 score Same thing happened to me last night. Was having trouble finding the leak until it got dark out and I hit it with the flashlight. It's pissing all over the side of the engine. Can anyone provide some guidance on the best place to source this part? |
![]() | | #40 | ![]() |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score Onlinemazdaparts.com
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
| The Following User Says Thank You to Hargarbl For This Useful Post: | Sergeant_M (10-05-2014) |
| Leaking hpfp | dyin hawaiian | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 10 | 02-06-2013 09:00 PM |
