![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score So here is a new tip for all those who face the problem of blown OEM injector seals and don't want to spend hundreds of dollars on OEM or some reinforced seals, there's a solution: The Toyota diesel injector seals. These seals come for every diesel Toyota engine and are proven to be of good quality. These seals have been tested for more than a year on a number of modified Mazda 2.3 DISI Turbo engines, with different power level (from stock to 400hp) running on awful Russian fuel. None of the seals failed so far. Installation does not require any machining or trimming. They fit perfectly. Now, the price. It is USD 7.8 per kit. USD 1.9 each. P/N: 11177-64010 Enjoy. UPDATE: See the pic attached. There is a comparison of OEM Mazda seals (left) and Toyota diesel seals (right). Mazda seals have rubber-like coating, Toyota seals do look like they are made of brass alloy. Surely they do not look as beefy as CP-E seals, but they are proven to be working on a number of modified cars. Two of them are 370hp and 405hp. Different alloys have different properties and as you know diesel engines have extreme pressure spikes in the cam. Still it would actually be useful to find out the limit of these seals' tolerance on Mazda DISI engines.
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
| The Following 2 Users Say Thank You to paveltol For This Useful Post: | seshomaru7 (04-05-2013), unokevin1 (11-18-2016) |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score your avatar makes me wanna buy the hitman collection on steam
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() Join Date: May 2010 Location: Los Angeles, CA
Rep Power: 195 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Cool man looks like a good solution. What are the symptoms going to be when the seals are starting to go bad?
__________________ 2010 MS3 5% REAR 30% FRONT DDM 5K HID RMM CS TIP/SRI Dizzy Tuned Autotech Internals Swift Springs JBR Rear Sway Stoptech 309's First Turbo Car and I love it! |
(Thread Starter) | Not Ranked : 0 score They either are OK, or get blown. If they are blown, you'll notice the knocking/chattering sound and jerking under boost.
![]() Join Date: Jan 2009 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,896
| Not Ranked : 0 score wow 8 bucks is wellllll under 190. great find lol
__________________ 2006 Mazdaspeed6 GT BCM SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN ![]() |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
| Not Ranked : 0 score im gonna order these next week. its cheap enough to gamble. thanks i love oem style fixes.
__________________ 2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS [SIGPIC][/SIGPIC] formerly pursuit_special |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score Link to others using them and no fail? Sent from my Epic Win Avatar
__________________ 2009 CWP Speed3 |
| Not Ranked : 0 score i noticed their is a washer associated do we need that as well.
![]() Join Date: Dec 2010 Location: Dayton, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,193
| Not Ranked : 0 score So if this is used in Toyota Diesels will it be available at dealers here in the US? Edit: Looked online looks like they are available now what all do we need? I ll order this today so we can get a good look at it before anyone goes and does it.
__________________ 07 MS3 Sport CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon) JBR: RSB Cobb: Accessport Corksport: TMIC CNT: Catted Downpipe |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score I am selling kits of these seals for 100. Good deal bro. Pm for details. |
| Not Ranked : 0 score Nice cost effective soloution just a cursory google search for the part number finds them as low as US1.04 ea
![]() Join Date: Feb 2010 Location: NoVA/ Norfolk
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
Groans: 133
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Incredible find if it actually works! I would like to see links to other people running them as well.
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Haha! CP-E's gettin DICKED on this one! Nice find man!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
| Not Ranked : 0 score fucking awesome I await stateside results.
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
![]() Join Date: May 2011 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score $1.04 each!!!! Fuck yeah!! Great find Paveltol
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. |
| Not Ranked : 0 score I've got these ordered from my local Toyota Dealer. He said 3-4 days so maybe middle of next week or earlier. At that price if they don't work I'm not out much and we can all see them. I'll post pictures up when I get them. He said they came off of an 84 Corolla diesel.
| Not Ranked : 0 score Model Production Date Engine Transmission Trim Body Door Camry 1983.08-1986.07 4cyl 1.8L MTM DLX SED 4D Camry 1983.08-1986.07 4cyl 1.8L ATM DLX SED 4D Camry 1983.08-1986.07 4cyl 2.0L ATM DLX SED 4D Corolla 1983.08-1985.08 4cyl 1.8L MTM STD SED Corolla 1983.08-1985.08 4cyl 1.8L MTM DX LB Corolla 1983.08-1985.08 4cyl 1.8L ATM DX SED I see Lexus referenced quite a bit too
| Not Ranked : 0 score From the illustration I'm looking at it looks just like a rubber o-ring. There is a seat that fits on the injector but I'm not sure if that would fit our application or not. In my eyes the major difference from the stock and the CPe seals are the brass looking sleeves that they include in the kit. I suggested back in the Injector Seal thread that VW 2.0T injector seals might work too. From the pictures I've seen of the CPe seals and the VW seals I have in hand they look the same.
![]() | | #19 | ![]() |
| Not Ranked : 0 score Nice find man
![]() | | #20 | ![]() |
![]() Join Date: Jan 2009 Location: Fort Worth, TX
Rep Power: 794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 771
| Not Ranked : 0 score Excellent! Thanks for sharing! Sent from my Galaxy Nexus using Tapatalk
__________________ Meet a giant fish. Fuck his brains out. |
![]() | | #21 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #22 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score So this is a washer style solution? |
![]() | | #23 | ![]() |
| Not Ranked : 0 score According to the Toyota illustration that I have it just looks like a rubber o-ring but it may be wrong. I had the dealer fax me a copy of it so I could look at it before I received them.
![]() | | #24 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score Subbed
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #25 | ![]() |
| Banned ![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Hmm, interesting. I do see a short lifespan on these seals if they are made of rubber/teflon. VW and Audi use a very similar seal but the injector has a step inside of it for it to seal to seat on. |
![]() | | #26 | ![]() |
| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
| Group buy anyone?
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() | | #27 | ![]() |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score this is seriously amazing if it works!!
__________________ New: 2012 Mazda MX5 Miata True Red |
![]() | | #28 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score They look brass to me
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score I looks like it has a "Seat" that might be brass so do you think they would pair two brass seals/o-rings together? Not sarcasm that's a real question.
![]() | | #30 | ![]() |
![]() Join Date: Jun 2010 Location: Farmington, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,165
| Not Ranked : 0 score subbed
__________________ Huh? |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2010 Location: Cortlandt Manor, New York
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score subbed |
![]() | | #32 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score Yea this is interesting.
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #33 | ![]() |
![]() Join Date: Oct 2009 Location: Gilbert, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
| Not Ranked : 0 score I'm curious to see the outcome of this as well. |
![]() | | #34 | ![]() |
| Banned ![]() Join Date: Nov 2009 Location: Baltimore Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Groaned at 40 Times in 12 Posts
![]() | | #35 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score interesting
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Awesome sauce. I love being cheap.
![]() | | #37 | ![]() |
![]() Join Date: Nov 2010 Location: Miami, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,290
Groans: 43
__________________ [SIGPIC][/SIGPIC] “From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley |
![]() | | #38 | ![]() |
__________________ |
![]() | | #39 | ![]() |
| Not Ranked : 0 score badassness!
![]() | | #40 | ![]() |
![]() Join Date: Jan 2010 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 372
| Not Ranked : 0 score Fuck and I just bought the cpe seals like 2weeks ago..... |
| Injector seals solution. Version A | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 756 | 05-23-2017 10:38 AM |
| Injector seals solution. Version B | paveltol | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 463 | 11-12-2016 09:30 AM |
| CPE or PTP Injector Seals? | Matrix311 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 13 | 11-26-2011 03:12 PM |
