![]() Join Date: Nov 2010 Location: Westminster, CO.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
(Thread Starter) | Not Ranked : 0 score So I finally stocked my car out and took it to the dealer. I get this sound only during a true cold start (usually after its been off for the night or in the cold for a good amount of time.) When I rev it up to about 3000RPM's you can really start to hear it. Otherwise you can only hear it for a few seconds just after you start the car. The dealer said "Hey yeah the problem is with your HPFP. We'll take it out and give you a new one". I didn't even think to consider the HPFP so told them right away that I couldn't be without my car and would need to reschedule a time for it to be serviced. Thank goodness they didn't throw away the old pump with my beautiful autotech internals! Anyways, I have the rattle noise like everybody else does, but how about this sound? I'm assuming it's okay and just another set of noisy internals, especially because of fuel requests during a cold start, but just want to see what all of you think.
__________________ 2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint. 2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint, Social Engineering - Because there is no patch for human stupidity. |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score Interesting...Dont know if you had time to pull the Pump out yet....Maybe you had a shim come out?
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score I heard somewhere, either here or on vdub forums (when I was researching autotech internals) that the autotechs have an issue with chewing up the cam follower...?
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score That isn't an issue on our cars. Our Cam follower is a different material than whats run in in the VW. Its a common upgrade for VW owners. |
(Thread Starter) | Not Ranked : 0 score My main concern is whether or not I should be concerned about this issue. It is only during cold starts and hardly does it unless I give it some gas, which leads me to believe that it is nothing to worry about.
Groans: 82
| Not Ranked : 0 score Well first off, I never rev my engine like that till its warm... And personally I would be concerned about that sound. How's your fuel pressure look in curiosity? Did you make sure everything was CLEAN? And make sure you swap internals before you take it to the dealership! Oh, and take pictures of them/ look for signs of wear.
(Thread Starter) | Not Ranked : 0 score I had a very repututable tuning shop do the work. I will be asking them about This issue though. For the record I don't Rev it before it's warm either but noticed it through simple experimentation after hearing it in the first place ;-) Last time I checked my fuel pressure was fine. Holds like 18xx psi at WOT. I've heard I should see 19xx or even 20xx but I am also at 5800ft elevation...
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score I didnt start getting high 18-19-20 till i was stage 2
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
(Thread Starter) | Not Ranked : 0 score I'm going to do my GT3076R build here and then after my tune I'll see what the situation is. If I'm not going above 19xx I may do something about it.
Groans: 82
| Not Ranked : 0 score I would aty least take the pump apart and look for signs of wear/problems
| The Following User Says Thank You to Fatguy729 For This Useful Post: | DingoDave (05-18-2011) |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score did the shop know what they were doing? or did they just follow the instructions like you could have done easily?
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() Join Date: Jun 2008 Location: Montreal
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score I heard the exactly same sound when I cold started my car yesterday.It's been a week since I installed my KMD v2.1 internals and car seems to hold pressure just fine.
__________________ ||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots|| |
![]() Join Date: Oct 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Doing my build at the shop, after blowing a piston land out, i was warned to upgrade my HPFP. So im doing that now. Luckily the head Mazda (i work at chevy) didnt mind letting me borrow the special tools and his knowledge. He mentioned the fuel pressure relief valve goes bad and makes a knocking type sound. Might be that. I should finish my car tomorrow. Cylinder wall wasn't scratched. So put new pistons and bearings. Just got my autotech FP kit today. Last thing i was waiting for! I'm scared, nervous, excited, happy..... Wish me luck |
| First AP Log. Autotech FP Internals Installed | spoof3r | 2010 MS3 - ECU Computer Tuning | 23 | 07-08-2013 08:11 PM |
| Autotech Internals | PapaSmurf | 2010 MS3 - Fuel, Nitrous & Water Injection | 240 | 07-25-2012 10:59 AM |
| autotech hpfp internals installed | speedms6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 45 | 07-15-2012 06:59 AM |
| Anyone want in on Autotech internals? | OneBAMFpog | 2010 MS3 - Fuel, Nitrous & Water Injection | 545 | 09-30-2011 09:49 AM |
| Anyone interested in Autotech Internals? | OneBAMFpog | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 31 | 06-02-2011 03:50 AM |
