 Old 06-13-2017, 03:15 PM   #1
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Default Meth Injection Hydrolock Prevention Solution
I've always been worried about meth injection because of the stories I have read about a failed controller pumping a tankful of meth into the engine. I ordered a meth kit recently so I started thinking about a failsafe that could prevent this.
Not sure if anyone has already thought of this, but the solution is pretty simple.
If a solenoid is used in conjunction with a check valve with a separate source activating the solenoid, a malfunctioning controller wouldn't be able to cause a hydrolock situation. A hobbs switch can be found for pretty cheap (~$20).
I know it's pretty unlikely for a failure to occur, but I will definitely be doing this for my own peace of mind.
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
 Old 06-13-2017, 04:31 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
Depending on what meth kit you ordered it may a boost activated kit so this would kinda be unnecessary.
2010 black mica speed3
Soon:built motor
 Old 06-13-2017, 04:35 PM   #3
andale927's Avatar
It is a boost activated kit, however this would still be a secondary precaution against activation separate from the controller. Protection from something such as an internal short, or the controller's MAP sensor failing (this could cause the pull-up resistor to go high and activate pump). Again, probably unnecessary, but it makes me feel better lol.
Power:
Handling:
Other:
 Old 06-13-2017, 05:42 PM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Way overthinking this. Throw a relay on the power feed for the pump and tie it into your ignition. Thats what i did and i threw a overide switch inline to my ignition feed.
Saved me once since my HOBBS switch failed in the on position after a pull ...... i reached down and flicked a switch saveing my motor.
MECP
2012 BM
Rfinkle tune in progress
 Old 06-13-2017, 05:53 PM   #5
andale927's Avatar
Originally Posted by 5doorsoffury View Post
Way overthinking this. Throw a relay on the power feed for the pump and tie it into your ignition. Thats what i did and i threw a override switch inline to my ignition feed.
Oh shit, that would be way easier haha. I thought it was like the AEM system where the controller would throw a fault if the pump wasn't connected.
I already ordered all the necessary parts so I'm going to do it anyways. At least it will be automated lol.
Power:
Handling:
Other:
 Old 06-13-2017, 05:57 PM   #6
Groans: 74
The only time the pump wouldnt been seen by the controller is if something went wrong like if the system engaged with the ingnition off aka what you want to prevent so that's good and like me if shit hit the fan and you need to hit a "if all else fails" kill switch.
MECP
2012 BM
andale927 (06-13-2017)
 Old 06-13-2017, 06:05 PM   #7
andale927's Avatar
I do like your idea better. I canceled all my amazon orders, thanks for saving me a few bucks.
Power:
Handling:
Other:
The Following User Says Thank You to andale927 For This Useful Post:
5doorsoffury (06-14-2017)
 Old 06-13-2017, 05:43 PM   #8
nekret's Avatar
Posts: 421   (View Stats)
Seems reasonable to me, only way you would see a hydrolock type situation would be a failure of multiple components provided your tank was at a lower elevation than your injection point.
Drivetrain
Chassis
Rice
 Old 06-13-2017, 05:48 PM   #9
Djohns's Avatar
Meh. Different strokes for different folks I guess.
Soon:built motor
W/M injection solution for to much knock armyman MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 23 09-21-2015 11:07 PM
Meth injection ?'s Boo5ted MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 05-28-2013 01:06 PM
Map wire for meth injection NJSPEED3 MSF KB - Mazdaspeed 3/6 - Fuel 20 09-19-2012 02:07 PM
Mazdaspeed6 Hydrolock prevention with the Corksport FMIC Kit manofhonor24 Mazdaspeed3/6 General Discussion 8 01-07-2012 08:07 PM
Page generated in 0.29034 seconds with 23 queries
