 Old 07-15-2016, 07:33 PM   #1
Revolv0's Avatar
Posts: 104   (View Stats)
Revolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud of
Default Mix and match. AEM pump with DO controller
Hello all,
I currently own a 2.5 bar Devils Own controller I picked up used. I would like to buy a used pump, and wanted to know if I have to stick with a DO pump, or will the controller correctly work with an AEM. I am looking to add meth after my tune as an additional safety measure for my aggressive driving. I don't want to overlook a technical detail that will be a waste of money.
Thanks!
Revolv0 is offline   Reply With Quote
 Old 07-16-2016, 12:01 PM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
I have a AEM pump that Ive used with various controllers over the years - Snow cooling mist, etc. Assuming you have the same generic AEM pump as me (which you probably do), it should be fine. The pump only has 2 wires if I remember correctly.
The Following User Says Thank You to speed23 For This Useful Post:
Revolv0 (07-17-2016)
 Old 07-16-2016, 04:22 PM   #3
Revolv0's Avatar
I was going to bid on this pump. Is this what you have ?
Aem Electronics Water Methanol Injection Pump 30 3015 | eBay
 Old 07-17-2016, 04:18 PM   #4
speed23's Avatar
According to the schematic at the link below as long as the pump you buy has a positive and negative wire connections coming out of the pump(and they all do cause thats how they work), it will work with your controller.
Progressive Stage 2 Ver 2b Directions - DevilsOwn Injection
 Old 07-17-2016, 05:51 PM   #5
Revolv0's Avatar
Thanks speed23, I feel more confident purchasing the AEM pump now. Hopefully I can get it for 60 bucks shipped.
Add-a-fuse for a MW controller and pump. thatsmrgimp2u MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 08-06-2011 03:00 AM
Is it ok to mix and match brands? Postulio4joo MazdaSpeed 3 - Engine, Transmission & Driveline 3 02-09-2010 08:38 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
New Releases - Official Sony DualShock 3 Controller and Nyko Controller (PS3) w/ RUMBLE $44.99 Haltech Hot Deals Section 0 04-04-2008 07:31 PM
Page generated in 0.26211 seconds with 21 queries
