Like Tree4Likes
  • 1 Post By SpeedRebirth
  • 1 Post By atvfreek
  • 2 Post By SpeedRebirth
 Old 06-19-2013, 06:41 AM   #1
david001wj's Avatar
Posts: 57   (View Stats)
david001wj is a splendid one to beholddavid001wj is a splendid one to beholddavid001wj is a splendid one to beholddavid001wj is a splendid one to beholddavid001wj is a splendid one to beholddavid001wj is a splendid one to behold
Default in tank meth??
Hi! I have heard a couple people talk about in tank meth.
My question is as I couldn't find anything anywhere on here or the WWW. I'm curently running WMI would there be any advantage for me to run in tank as well and how much would be needed?
please chime in @atvfreek; @rfinkle2;
Sorry if this as already been discuse in earlyer threads but like I said couldn't find anything.
2010 MS3 stock K04
COBB SRI, TIP,AP self tuned 21psi taper to 19, 20° @redline NGK 1 step colder plugs,
AT internals and Cp-e catted downpipe, Magnaflow CBE, AEM WMI 50/50 mix, Shitty Shell 91 oct 1.5 gal in tank meth.
david001wj is offline   Reply With Quote
 Old 06-19-2013, 06:44 AM   #2
obijack's Avatar
Posts: 1,830   (View Stats)
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 06-19-2013, 06:46 AM   #3
IIRC, Atvfreek ran a gallon of in tank meth for a short while, and I think my buddy Slowhatch has been doing the same.
A very important thing to remember is no h20 mix can ever be added to the tank, so 100% meth or nothing.
There is going to be debate as to the effect the meth will have on the fuel sock, the fuel lines and the fueling system in general, but so far, high alcohol content fueling (up to a 50/50 mix of ethanol) has had very little detrimental effects on our car.
david001wj (06-19-2013)
 Old 06-19-2013, 06:49 AM   #4
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
No more than 10% in tank meth or your rubber seals will expand. Phate has done testing on this
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
david001wj (06-19-2013), rfinkle2 (06-19-2013)
 Old 06-19-2013, 06:50 AM   #5
atvfreek's Avatar
Posts: 7,787   (View Stats)
I have run it in tank and just 1 gallon will increase the octane. However you already run WMI. If you are looking for better knock resistance, I would just go to a slightly larger nozzle. In tank meth to me is a PITA, it's messy, and time consuming to sit at the pump with a gas can. It also gets expensive quick.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
david001wj (06-19-2013), rfinkle2 (06-19-2013), speedboost (04-05-2015)
 Old 06-19-2013, 06:52 AM   #6
Groans: 33
Read this: Methanol Direct Injection
rfinkle2 and obijack like this.
Mazdaspeed6 -06
290 AWHP / K04
The Following 4 Users Say Thank You to SpeedRebirth For This Useful Post:
atvfreek (06-19-2013), david001wj (06-19-2013), obijack (06-19-2013), rfinkle2 (06-19-2013)
 Old 06-19-2013, 06:56 AM   #7
@atvfreek; I know you are a busy man, but if one day, you have the chance, it would be great if you could create a parts list and a quick diagram of your meth kit.
You have had so much success with yours, I'm forever trying to explain how you pieced the kit together LOL (no longer a stage 1 kit available through DO).
If you send me a pm of what you are running, I'll get the links together.
atvfreek (06-19-2013), TiGraySpeed6 (06-22-2013)
 Old 06-19-2013, 07:16 AM   #8
david001wj's Avatar
Thanks for the quick reply! I was hoping that the Meth. in tank would have the same effect as E85. What I'm trying to say here is that it seems like E85 tune cars make crazy TQ/HP on stock turbo.
Thanks! I was thinking that it wouldn't make much sence for me. But figured I would ask anyways.
Thanks for the link I had read it a little while back. Thanks to @phate; for the great research.
2010 MS3 stock K04
The Following 2 Users Say Thank You to david001wj For This Useful Post:
phate (06-19-2013), rfinkle2 (06-19-2013)
Meth Tank Interest HTP HTP (Hi-Tuned Performance) 393 01-15-2016 09:08 PM
best way to seal 100% meth tank?? seanmiller09 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 08-04-2010 08:17 PM
Meth Tank Question superskaterxes MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 01-11-2009 09:05 AM
Page generated in 0.30268 seconds with 24 queries
