 Old 06-19-2014, 06:00 PM   #1
BooSTed_Hatch's Avatar
Posts: 169   (View Stats)
BooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond repute
Default Tapping into Boost source for Meth install
So I'm going to be attempting my DO Stg2 DVC 30 Meth install tomorrow. Looks pretty straight forward and found a ton of good install threads...
Only thing I can't find or see that I'm a little confused on is :Where to tap into the boost/vacuum source? with the boost tubing from the controller. From what I've seen people have not tapped into the boost/vacuum line that goes from the BPV to manifold, so then where?
And the boost lines that come with this kit are ridiculously small!!
Thanks in advance for any help!
2013 CWP MS3 w/Tech Pkg
Performance Mods
Cobb AP V3 ~ JBR 3" WP Intake + Turbo inlet ~ JBR IC Boost tubes ~ AT hpfp Internals ~ ETS TMIC ~ CS Catless DP ~ CS Race pipe ~ CS Catback ~ CP-E Stg2 RMM ~
NGK Iridium IX's (1 step colder) ~ Turbosmart 50/50 ~ KSport Pro Coilovers
[SIGPIC][/SIGPIC]on 93
307whp 339lbft
Exterior mods: ESM 004s - Hankook Ventus V12 Evo2 225/40/18 - Gloss Black Vinyl Roof - Gloss Black emblems - 15% tint - Rear Wiper delete - OEM window visors
On Order: GT2871r, Freektune 3.5" Intake, Bosch 3.5 Bar Map sensor, Cobb EBCS
BooSTed_Hatch is offline   Reply With Quote
 Old 06-19-2014, 06:08 PM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
I taped the bpv
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 06-19-2014, 06:14 PM   #3
I taped the bpv
So you DID tap the boost/vacuum line from BPV? Can you take a quick pic?
Thanks dude.
Tapped bpv line to vacuum block for meth controller and boost gauge.
Yeah??? Okay, that's what I was thinking but every install thread I saw they didnt. (although they didn't reference that part anyway so they might have)
Performance Mods
307whp 339lbft
Last edited by BooSTed_Hatch; 06-19-2014 at 06:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-19-2014, 06:11 PM   #4
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
 Old 06-19-2014, 07:01 PM   #5
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
I'll be tapping the bov line, seems easy enough. Did you use the positaps for the controller wires? Or did you get some add a fuses?
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
The Following User Says Thank You to justinsane87 For This Useful Post:
BooSTed_Hatch (06-19-2014)
 Old 06-19-2014, 07:09 PM   #6
I'm doing the install tomorrow. I was planning to use the postitaps, but I will be getting a few last minute things from O'Reillys in the morning and I might get the Cooper Bussman ATM fuse Tap
+1 for BPV line
That seems to be the consensus and honestly that's what was most logical to me. Thats where I always tapped for boost gauges on previous cars so..
Performance Mods
307whp 339lbft
Last edited by BooSTed_Hatch; 06-19-2014 at 07:09 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to BooSTed_Hatch For This Useful Post:
justinsane87 (06-19-2014)
 Old 06-24-2014, 03:54 PM   #7
You get it installed? What did you use for fuses?
 Old 06-25-2014, 11:00 AM   #8
Nope not installed. I attempted it last weekend, but realized it was more than I can chew (without the right tools). I did most of all of my setup now install wise, but I borrowed somebody's shop that had a lift and tools, so It made it easy.
I will get it installed at some point..... More thinking about BT right now though.
Performance Mods
307whp 339lbft
 Old 06-19-2014, 07:06 PM   #9
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
+1 for BPV line
 Old 06-24-2014, 05:54 PM   #10
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i have my bpv line tapped for DVC3, and Mechanical boost gauge, and Ignition amplifier =)
i also used the add a circuit bus tap where the thing has two fuses in it the original and the added fuse for the extra circuit works good on my devils own pump
justinsane87 (06-24-2014)
 Old 06-24-2014, 06:50 PM   #11
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
Look here:My Devil's Own meth/water injection setup
There should be a pic of how I tapped it in.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
 Old 01-28-2017, 02:03 PM   #12
VA2010MS3's Avatar
Posts: 22   (View Stats)
VA2010MS3 has a little shameless behaviour in the past
Got this same kit but they didnt supply enough line to reach my bov...can I T it into the grimmspeed 3rd port? Says it connects to high pressure boost source
Thanks
VA2010MS3 is offline   Reply With Quote
 Old 01-28-2017, 05:52 PM   #13
sheston's Avatar
Posts: 1,847   (View Stats)
Any boost source will work. Tapping in there may actually record a higher boost level, being before the intercooler and all. But you should be able to set the Meth to come on and compensate for the pressure drop
best boost control source to use reconbygod12 Mazdaspeed3/6 General Discussion 16 09-04-2018 02:11 PM
Cheaper Meth Source BigRedSpecial MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 01-19-2014 11:42 PM
Boost reference source paulwalll MazdaSpeed 3/6 - Turbo Induction 14 04-01-2013 01:29 PM
Potential source or Meth tanks Chimmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 03-29-2012 07:33 PM
K04 Boost Source or Quick Tap in Hot Pipe bewsted MazdaSpeed 3/6 - Turbo Induction 0 03-20-2012 10:36 AM
Page generated in 0.33739 seconds with 29 queries
