![]() Join Date: Jul 2017 Location: Houston
(Thread Starter) | Not Ranked : 0 score I have Corksport HPFP internals, and obviously I have an Accessport for tuning (I was already running a 21 PSI tune when my K04 hot side oil seals blew out). Is that really all I need? And can I expect that amount of power with E85 and the S4? I've seen 350WHP on 93, so I'm assuming E85 will open a lot of doors. |
![]() Join Date: Apr 2016 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score I seriously hope you're not talking about going full E85 with absolutely no supporting mods other than a turbo. Am I reading that right? |
CS HPFP, JBR 3.5" intake, 3" catless DP and 3" straight pipe, C-PE TMIC, CS 3.5 bar MAP sensor, Grimmspeed 3-port EBCS, GFB TMS Respons BPV set at 50/50. Fully bolted with the S4 turbo. I'm wondering what else I need, I heard about the 'black death' thing with the HPFP so I'm figuring if E30 or (maybe) 50/50 would be a better idea and if there's anything else I can add in to make the car more ethanol friendly, as I read I can still reach MBT with the mix and the effects are less present. | |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Tires. I wouldn't be worried about how much WHP you gain since ETH brings on the torque. You can get close to 400 lb of torque on a stock turbo with a e85 mix and blow your rods faster then a virgin busts a nut from a hookers bj while shes tripping on ecstasy. Have a toon that brings the power on easy in the first 2 gears and don't boost like a fuck nut in 5th+ If done right e85 will increase the life of the motor if done wrong you will blow the motor and get built and go faster. I run a eth mix and always have my meth kit ready that i can turn on when i need it incase i have to switch to a 93 toon on a long trip. If you go with a 1:2 mix of e85:93 you will get close to MBT and stave off "Black Death" anything more like 50/50 you will need to clean the pump or occasionally run a tank or 2 of 93 to keep the pump ok. I will take this moment to ask.... what are your goals with this car?
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
It is still my daily though, so I would like to keep the power well within the limits of the stock block to increase longevity. If running ethanol gets me too close to the limit then I will stick with plain old 93. But I'd like to make enough power, like I mentioned before, to fly past Mustangs. I know it's more than possible with the S4, as I was already pretty damn close with my K04. The only reason I am going big turbo is because my K04 blew up and the S4 is the same cost as a new K04 from Mazda. I will be working with Purple Drank for my tune, I keep hearing great things about them and I like how they keep the low end torque down to spare the connecting rods. | |
