![]() Join Date: Nov 2012 Location: Winder, GA
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
__________________ 2013 Mazdaspeed 3 GTX3071r turbo, Freektuned- APv2, HTP 3" intake, Cobb BPV, Street Unit TMIC, CP-E DP, Ultimate Racing Exhaust, CP-E rear mount, JBR passenger/trans mounts, Autotech FP internals, Grimmspeed EBCS, H&R Springs, Akebono Euro pads, TSW Nurburgring Wheels on Nitto NT555 225/40/18 tires, Nokya hyper yellow fog lights, WC Lathewerks custom titanium shift knob |
![]() Join Date: Jul 2015 Location: Southern Maryland
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Are you planning on upgrading the door speakers?
__________________ Daily 2011 Speed3: ALL STOCK The Project 1995 LS swap Camaro: CAMONLY |
(Thread Starter) | Not Ranked : 0 score Maybe down the road. The highs are decent, but they can't keep up with all of that bass. If I do, I will upgrade the Bose amp too.
| Not Ranked : 0 score I was thinking the same thing once I put my sub in but after a few months it sounded blah just really bass heavy. I was going to upgrade the amp but I am doing the doors first. Probably some jbl components of infinity since they match the ohm of the factory speakers.
(Thread Starter) | Not Ranked : 0 score I am not sure what highs I want to go with. I used to like Boston Acoustics, Focal, and MB Quart in my previous stereos back in the 90's. I'm not sure what's decent anymore. Here's a link to my review of this sub box on Crutchfield. (Same user name) Rockford Fosgate P3-1X12 Punch P3 ported enclosure with 12" sub at Crutchfield.com
__________________ 2013 Mazdaspeed 3 GTX3071r turbo, Freektuned- APv2, HTP 3" intake, Cobb BPV, Street Unit TMIC, CP-E DP, Ultimate Racing Exhaust, CP-E rear mount, JBR passenger/trans mounts, Autotech FP internals, Grimmspeed EBCS, H&R Springs, Akebono Euro pads, TSW Nurburgring Wheels on Nitto NT555 225/40/18 tires, Nokya hyper yellow fog lights, WC Lathewerks custom titanium shift knob Last edited by Evo2speed3; 05-25-2016 at 06:43 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score there was another speed owner who wrote a review on the sub. sounds like its pretty good. im surprised you said it was better than the sundown sub. i have always wanted to go with a more competition sub just so i can see what its all about but i dont have the means of making a custom box for them.
![]() Join Date: Aug 2016
| Not Ranked : 0 score I know its been a few months since you did the install but where did you run the power wire through? I most likely missed the thread where someone talks about this but i have a DC audio sub that I am dying to install all ready and haven't really found a clear answer. |
![]() Join Date: Aug 2013 Location: West Columbia, South Carolina
Rep Power: 0 ![]() Thanks: 16
| Not Ranked : 0 score Behind the glove box, in the firewall, there is a plastic or rubber cap a couple of inches wide. Im assuming this was for the steering column in the left side drive models. Pop it out, drill a hole, grommet if you want, and run wire down pass. Side door molding. There is a writeup on here with pictures somewhere |
| Not Ranked : 0 score No prob. Listen to this guy about the PAC AOEM2 loc. Its the only way to go, I tried multiple options before i got that and was never happy with the output. Bose or not, use that PAC AOEM2 loc. |
![]() Join Date: Nov 2016
| Not Ranked : 0 score it sounds so great to upgrade a sub and amp, I'd like to add it to my car too, hope it works perfectly. |
![]() Join Date: Jul 2013 Location: Saint Louis
Rep Power: 0 ![]() ![]() Thanks: 5
| Not Ranked : 0 score It looks like there are only 4 outputs on the loc, what do you do if you want to run an amp on the door speakers and a sub? |
| Not Ranked : 0 score You use one set of outputs for the sub amp and the other pair of outputs for the speaker amp. It tells you on the loc which output is for front and rear. |
| No volume from OE Bose system | mertz | 2010 MS3 - Car Audio & Electronics | 15 | 05-18-2014 11:40 PM |
| Add EQ to factory Bose System? | my2k13speed3 | 2010 MS3 - Car Audio & Electronics | 12 | 12-27-2013 06:28 PM |
| Active Sub added to BOSE System | KRheeder | 2010 MS3 - Car Audio & Electronics | 6 | 04-19-2013 07:49 AM |
| BOSE SYSTEM QUESTION | BROXN | 2010 MS3 - Car Audio & Electronics | 16 | 02-27-2011 11:45 AM |
| Better Bose system! | _Toxic_ | 2010 MS3 - Car Audio & Electronics | 2 | 03-23-2010 11:24 AM |
