![]() Join Date: Jan 2017
(Thread Starter) | Not Ranked : 0 score Yesterday I put a new alternator in my 2012 MS3 sense my old one was going out, I got it in and working drove it home and the battery light was on but then it went away. When I got up this morning I started my car and let her warm up, but once I went to back out of my parking spot my power steering went out, my head lights flickered, my radio wouldn't work, my ac wasn't going. Then like 1 minute later it all started working and all the lights on the dash board went off and it was completely fine. I park the car at work, and go out on lunch and my cars interior turns on, radio works, ac works, all lights work, but it just won't start. It makes a clicking sound like it's trying but it just doesn't actually turn. After looking in the battery, I checked the connectors and they seemed tight, then I check the alternator connectors sense they were a pain yesterday taking out. My connector on the bottom is in good, but I took the tweezers in my car and checked to see if the grounding bolt was tight and it still turned, could that be the issue or could something else went wrong that I'm missing? Do I just need to jump it and tighten the bolt and try to clean off the connectors and stuff? Thank you for the help! Sent from my iPhone using Tapatalk |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score A loose ground would cause that, yes.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Is this real life? Yes, tighten it up numbnuts
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | WetzMS3 (01-13-2017) |
| Alternator Help | SyCoTiCK4rMA | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 11-30-2014 05:24 PM |
| Man buys truck with change, LOTS of change | Haltech | Automotive News | 1 | 08-14-2008 09:15 AM |
