> 2010 MS3 - Car Audio & Electronics
Like Tree3Likes
  • 1 Post By attomica
  • 1 Post By Oni
  • 1 Post By Oni
 Old 12-28-2014, 03:50 PM   #1
attomica's Avatar
Posts: 170   (View Stats)
attomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond repute
Default Another comprehensive car audio upgrade! v. lots of PICS!
As most other discerning listeners, I felt right away that the Bose system in the 2013 MS3 with Tech Package was really only a stand-in until it could be changed out or upgraded. I knew I would be doing just that when I took delivery of the car, but I didn’t know what path I would take. After a while, I decided I wanted to keep the stock head unit and upgrade everything else. This is the thread that confirmed what I had been thinking of was possible:
Aftermarket stereo with stock headunit
When I saw that thread, I started to plan-out my upgrades and acquire the components. I’ve chosen different components, but the path I’ve taken in terms of install and connection is similar or identical to those others from whom I’ve learned through their threads, so a lot of my install process is covered in those threads. I’m making this thread to touch on some specific things I encountered in my process. I’m thankful for the knowledge other MS3 owners have passed on and I want to be as helpful to others who come after me.
These are threads that educated me on other aspects of the sound system upgrade:
Car audio install in progress (pics)
Full Audio Install, Deadening with Pictures
ETERNAL's System Build
These are the components I used:
Head unit signal interface ($127) with Remote Bass Control ($27)
Amp ($499) & Connection Kit ($80)
Front door speakers ($195)
Rear door speakers ($104)
Subwoofer ($330)
I’ve done sound system install and upgrades to pretty much all of my past vehicles, so I wasn’t a complete newb to what’s involved. I did the power tap on one weekend and the sub enclosure in another weekend. Then, I had a four-day holiday weekend where I did the amp, signal interface, and door speaker installs, and then finished the whole process.
This was my install sequence:
1. Power tap from the battery to under the passenger seat for the amp and signal interface
2. Subwoofer enclosure
3. Amp and signal interface connection
4. Front door speakers
5. Rear door speakers
Power Tap
Using the amp connection kit, I ran 4/0 cable from the + battery clamp to a fuse block mounted on the outside/front of the battery box. Then, I ran the cable from the fuse block, across the top of the firewall over to the passenger side, down through the firewall (via the plastic plug-grommet), behind the glove box, and under the passenger seat.
Using a Dremel, I carved a small opening in the top edge for the cable to pass through when the battery box cover is in place.
To hold the cable in its loom across the top of the firewall, I used adhesive mounting pads.
These are great because they allow multiple mounting possibilities and they’re small so they occupy hardly any space. They have adhesive pads and there is a hole through which you can attach them with a screw. I used both methods to ensure the cable won’t fall. I used a total of four of them across the top of the firewall.
The use of firewall plug/grommet passage is covered at length in those other threads, but here is how I handled creating the hole through it.
Using a Dremel with a flat cutting bit, I cleared out the center section of the three “ribs” to make just a flat, circular cavity.
Then, I drilled a centered hole using a Forstner bit.
Through that hole, I installed the compression fitting through which the cable passes into the passenger cabin.
Subwoofer Enclosure
This was something that occupied a lot of my thoughts. I was (and still am) fascinated with King_Arthur’s Stealth Sub (2012 MS3 Stealth Sub Install) and actually attempted to recreate it, but was unsuccessful. The idea of replacing the stock sub with a better one in the same location is great in that it wouldn’t be visible and there would be no loss of trunk space. I may retry this method in the future. I also created a regular box enclosure that would fit against the back of the rear seats, but when it was finished, I didn’t like the way it looked and it prevented the ease of the rear seat fold-down feature. So I came up with another solution.
My employer gets these big rolls of cable on spools with a cardboard center section. They are super dense and rigid 12” diameter cylinders with a .25” wall thickness. I calculated the needed volume for my sub and found that one of these tubes would be perfect.
I got a circle template (which is fucking awesome) for my router and just had to cut three circles from .75” MDF and slide them into the tube. Two layers on the bottom would help balance the weight of the unit and would allow a recess for the terminal cup so the sub wire could run under it and it would still sit flat. The top ring is what the subwoofer drops into and is anchored in place. Everything fit beautifully and was super tight. I used just a little glue and made a spacing template to place finishing nails evenly around the circumference of the tube in each layer.
A detail I added was a routed channel for sub wire passage so the enclosure would sit flat. The terminal cup is not yet installed in these pics, but I bought a circular one and centered it with the receptacles oriented toward the channel so there would be no kinking or twisting of the sub wire. Turned out beautifully!
After assembly, I sprayed the bottom with rubberized truck bed lining. This does a great job of keeping it from sliding around in the back. Then, I found some carpet that is a close match to our stock carpet and covered the tube using 3M spray adhesive. I stapled it down on the inside, around where the sub is so there’d be no lifting and also along the seam on the back where the carpet edges meet. There is already some draw, but the staples are doing their job and the seam is hidden, so all is good. No shown in the pics is the black strap I installed to hold the enclosure in place. It goes through the side panel and is a solid method to keep the sub in place in conjunction with the rubberized bottom area.
Amp (PDX-V9) and Head Unit Signal Interface (LC7i)
In Georgediego’s thread (Aftermarket stereo with stock headunit), he said he was able to fit his amp under the stock amp bracket with the LC7i on top. Unfortunately, the amp I chose did not fit under the stock bracket, so I had to fabricate a solution. I created an aluminum “table” onto which the amp is mounted and then the LC7i is mounted on top of the amp. When assembled, the amp, LC7i and the table become one solid unit that mounts on the same studs the stock amp bracket mounted to under the passenger seat. The LC7i is mounted to a bent piece of aluminum that surrounds the amp, but stands off about .125” all around so air circulation can keep the amp cool.
Front-facing side
Rear-facing side (the cut-out allows continued function of the floor vent)
Bottom
Here it is on place.
I don’t know how much time I spent looking for the stock amp plugs to use to keep the stock plugs on my car, but I couldn’t find anything. So, I cut the plugs off and soldered/heat shrinked each wire so I could jack into the LC7i. I never did find a good solution and I feel this is sort of a hack job, but I did the best I could with the info I could find.
I labeled each extension to keep confusion at bay.
I drilled into the floor right next to the front mounting stud for the amp ground.
Other Stuff
I mounted the remote bass control knob and LED in the center console, next to the shifter.
The tweeter from the front door components are too large to fit in the stock tweeter location. I bought blank trim (sail) panels, thinking I would mount them in there, but I just couldn’t figure a way to do that and still keep the eyeball mount feature it has. So, I installed the blank sail panels and relocated the tweeter into the door panel. The eyeball mount allows positioning of the tweeter to optimize sound direction. I’m very happy with the results.
I didn’t mention anything about the door speakers (except for the tweeters above) because they were so damn easy. I had some panels of high-density styrene standing by to make spacers, but they weren’t needed. Both front and rear door speakers just dropped right in using their included adapters. It was almost like Alpine designed these speakers specifically for the MS3. There’s no window interference, no magnet interference…nothing. I was hugely relieved because that was one of the things I was dreading.
All told, I’m very satisfied with how the install went and how the performance of my sound system has increased. The detail and bass at all volumes is much improved. I have to say, though, the improvement isn’t as dramatic as I thought it might be. I guess I comes down to how important sound quality is to a listener. I can see the stock system being just fine for a lot of people.
A couple other things:
I was never sure about this, but the front center speaker and the two pillar speakers in the cargo area are now non-functioning. They were just fill speakers and there is nothing missing in terms of sound with them cut off.
I took a road trip this Christmas and used the NAV system a lot. I discovered that the volume of the voice guidance has been compromised. It will only go so high, which isn’t high enough. I have to turn the music off and close all windows, basically make it as quiet as possible inside, so I can hear it. I guess there was something with the stock Bose amp that handled that as a separate thing and now it’s gone. I can still use the nav okay, but it was nice, not having to strain to hear it.
trekkie1031 likes this.
attomica is offline   Reply With Quote
The Following 8 Users Say Thank You to attomica For This Useful Post:
Addikted To Boost (12-28-2014), Captainobvious (05-08-2015), Code Monkey (12-28-2014), g00s3y (12-28-2014), littleloogy (12-28-2014), neotide87 (12-28-2014), Pseudonym (12-28-2014), trekkie1031 (01-01-2015)
 Old 12-28-2014, 04:47 PM   #2
shamie's Avatar
Posts: 952   (View Stats)
Why did you choose a thin mount sub if you just dropped it in a foot tall enclosure? Kind of defeats the purpose doesn't it?
 Old 12-28-2014, 05:19 PM   #3
attomica's Avatar
Well, I had purchased the sub with the intent of creating something like the stealth sub I mentioned. That didn't work out, so I had to adapt it to a different set-up.
 Old 12-28-2014, 06:40 PM   #4
shamie's Avatar
What's the volume you ended up with?
 Old 12-28-2014, 07:24 PM   #5
Pseudonym's Avatar
Posts: 1,429   (View Stats)
nice components, the pdx-v9 especially. i was this close to getting one on trade but a helix 5 channel came my way for nearly nothing, brand new. your install is clean as fuck and it looks like youve been at this game for awhile and also have major ADD.
Cobb AP JBR SSP/SSB's
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
Pseudonym is offline   Reply With Quote
 Old 12-28-2014, 07:58 PM   #6
attomica's Avatar
Unfortunately, I don't have a way of measuring that. So far, it's just my perception, but there's no doubt that it packs a much bigger punch.
Yeah, the PDX-V9 is pretty kick-ass. I really like its flexibility and small size and the wire to plug to amp makes connection really easy. Thanks for your compliments! ADD is there, but I just have a light case of it. Just enough to keep shit clean and in order.
 Old 12-28-2014, 08:53 PM   #7
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
You could always get a stealth mount from @JTMS3; for that shallow 10", I'm sure he'd make it work for you.
JTMS3 likes this.
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following User Says Thank You to Oni For This Useful Post:
JTMS3 (01-07-2015)
 Old 12-28-2014, 09:13 PM   #8
attomica's Avatar
Is the stealth mount the enclosure that mounts against the side of the back cargo area?
 Old 12-28-2014, 09:27 PM   #9
Oni
Oni's Avatar
He has done a jack box version that fits where you describe as well as one that sits in the spare tire where the stock bose sub is. I'd look through his thread in this forum and PM him if you need help. Because you mounted your amp the way you did, you have a lot of options.
JTMS3 likes this.
JTMS3 (01-07-2015)
 Old 01-06-2015, 08:08 PM   #10
Sandman978's Avatar
Posts: 1,441   (View Stats)
Sandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the world
This build is clean as fuck. Good job and can't wait to see the stealth mode engaged later down the road lol
2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance
Sandman978 is offline   Reply With Quote
 Old 05-08-2015, 07:45 AM   #11
Captainobvious's Avatar
Posts: 118   (View Stats)
Captainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond reputeCaptainobvious has a reputation beyond repute
Thanks for the mention in the OP about my build thread. I'm glad it was able to help in some way with your build
Nice job on the install. It is very cleanly laid out and executed. Creative usage of the cylinder as well. I wonder how that cardboard will hold up. I'd almost say you might be better off if you soak it with fiberglass resin and put a layer or two of fiberglass chopped mat on the inside walls as well. But if it's working well for you, that's what counts.
-Steve
Captainobvious is offline   Reply With Quote
 Old 05-15-2015, 10:54 AM   #12
attomica's Avatar
-Steve
Thanks, brother! You definitely have taken your MS3 beyond what most others do and I admire your choices. Your thread was quite helpful. Speaking of, it's been a while since you've updated. Are you still modifying with your audio system?
Good point the longevity of the cardboard tube. I never really gave that any thought. It's super dense, but I guess delamination could happen. That's something I may have to keep an eye on. I still want to do the spare tire sub enclosure, so the tube will go at some point anyway.
 Old 05-15-2015, 09:19 PM   #13
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Those pdx series amps are one of the best I have used. Good choice.
The line up:
 Old 05-22-2015, 10:26 AM   #14
Yep, I'm always tweaking and tuning
I'm pulling out and redoing the trunk build to include 4 JL HD amps and to add a pair of the Stereo Integrity 12" SI BM mkIV subs back there in the spare tire well to reinforce the one I have up front hidden inside the dash.
I have a sketch up of the proposed layout. I just need to transfer to wood and start making some saw dust on the router
I'm also playing around with some different midrange speakers at the moment.
 Old 02-24-2019, 07:30 AM   #15
Coltzxli's Avatar
Posts: 45   (View Stats)
Coltzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to beholdColtzxli is a splendid one to behold
This is a really awesome write up, thank you for taking the time so do this. Also, that sub enclosure looks really good, I've made a fiber glass one in the past and it was much harder to achieve a quality carpet finish.
Anyways, to my question, can I just buy Alpine speakers or equivalents to replace the stock Bose ones without using an Amp or LC7i?
Coltzxli is offline   Reply With Quote
 Old 02-25-2019, 07:11 AM   #16
tdement's Avatar
Posts: 103   (View Stats)
tdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud of
Groaned at 27 Times in 10 Posts
Correct me if I'm wrong, but I think you'll want a proper amp rated for your speakers. Running it through the stock interface power won't really unlock the potential of the speakers.
2011 PuSpeed.
CorkSport SRI + TIP // CorkSport HPFP Internals // CorkSport CBE
tdement is offline   Reply With Quote
 Old 02-25-2019, 07:41 AM   #17
Coltzxli's Avatar
This is kind of what I gathered/figured.
If you have a blown speaker you can use an aftermarket replacement of the same Ohm rating and it will sound better, but strictly upgrading the speakers on an otherwise functioning Bose system won't net more than a 5% upgrade.
I'm getting some distortion around volume level 36-40 which because of my exhaust system is needed for highway driving. But I cannot tell where the distortion is coming from
 Old 02-25-2019, 09:10 AM   #18
tdement's Avatar
What does it sound like? Is the sound flattening out or a flapping sound? If so, you could have damaged speakers. Another possibility is you simply don't have enough power for the speakers. If it's stock, I wouldn't be surprised in either case, best way to know is to take a look at the speakers. If they aren't damaged, it's worth looking into an amp with proper power support.
2011 PuSpeed.
 Old 02-25-2019, 09:19 AM   #19
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
damaged speaker or your bass adjustment level is set too high or you have a door panel rattling...Sound deadening may help for the last case...
as mentioned, more powerful speaker is likely to be heavier to move than oem so it may even reduce the output level if you don't replace the factory amp.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-25-2019, 09:22 AM   #20
Coltzxli's Avatar
When I have some more time next week I will look at the speakers for any wear and tear.
I'm not much of an audio-head my best description would be cymbals are muddy and crackly, vocals are not as pronounced and when the song starts to really jam everything sounds like the a headphone jack isn't plugged in all the way if that makes sense (to clarify I stream using bluetooth but this is just a simile)
 Old 02-25-2019, 09:30 AM   #21
tdement's Avatar
I had bad distortion on the speakers in my old car... it turned out the rubber had completely disintegrated. Was very sad/funny to see.
I could also be a wiring issue. I'd get someone who knows what their doing to do some diagnostics for wiring unless you are knowledgeable enough. Don't hurt yourself lol.
2011 PuSpeed.
Last edited by tdement; 02-25-2019 at 09:30 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-05-2019, 10:08 PM   #22
DeBruce's Avatar
Posts: 1   (View Stats)
DeBruce is an unknown quantity at this point
This is a great guide and i am planning on replicating this as much as possible
Does anyone know what the updated as in 2018-19 Alpine speakers are that have the same specs?
DeBruce is offline   Reply With Quote
 Old 08-11-2019, 09:03 PM   #23
attomica's Avatar
Hey guys! I’m glad my install guide is helpful. I’m happy to say I still have and love my Speed and I’m glad I upgraded using the components I used. Every time I drive it I enjoy the sound system. It’s been four years since my initial post, so some components may have changed, but I’m sure there’s something close, if not a direct replacement, that you can use.
2013 CWP w/Tech Package
Performance • Autotech HPFP internals / AP v3 / JBR TIP / JBR Powerpath Intake / JBR RMM / JBR shifter bushings / JBR OCC
Sound System • Audio Control LC7i / Alpine PDX-V9 / Alpine SPR-60C / Alpine SPR-68 / Alpine SWR-T10 • Install thread: http://bit.ly/1o6hf2Z
Audio System Upgrade Salukis10 CX-7 > Car Audio & Electronics 2 01-05-2012 08:52 AM
BMW launches comprehensive review for U.S. ad business Haltech Automotive News 0 03-28-2011 10:10 PM
McLaren announces comprehensive restructuring, management changes Haltech Automotive News 0 04-22-2010 06:10 AM
PRESS RELEASE: GM Announces Comprehensive Plan to Address Dealer Concerns Haltech Automotive News 0 12-03-2009 04:00 PM
Page generated in 0.48813 seconds with 30 queries
