> 2010 MS3 - Car Audio & Electronics
  • 1 Post By ShutterMS3
 Old 01-14-2018, 10:12 AM   #1
ShutterMS3's Avatar
Posts: 3   (View Stats)
ShutterMS3 will become famous soon enough
Default Best In-dash Headunit
I'm looking for the best quality headunit for my 2010 MS3. I looked on the Search function but pretty much all of the threads were about member's installs. I just purchased this car four days ago and it's awesome! However, the stock stereo leaves a little to be desired.
I found the eonon, which looks REALLY awesome. However in another thread a member was saying he had issues with fitting the unit. I'll take any advice/suggestions, thanks!
ShutterMS3 is offline   Reply With Quote
 Old 01-14-2018, 10:52 AM   #2
aackthpt's Avatar
Posts: 1,450   (View Stats)
I replaced it with a single board computer playing "Back in Black" on loop, a 10 kilowatt stereo amplifier, and a single analog knob that goes to 11.
2013 'speed3, silver
Stage Bro
 Old 01-14-2018, 11:37 AM   #3
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
You question makes no sense. "Besy quality head unit for my ms3" based on that i would say get a oem radio.......
Or maby i have no clue about car audio and i bought this awesome cheap pos ebay radio that works great for me. I highly recommend it. The seller said it was the best radio.
Go to a car audio shop and find the most expensive radio there and you have found the best one. Its like saying hey guys whats the best color to paint my fingernails or hey who makes the best cock rings for a Alaskan cock...
MECP
2012 BM
Rfinkle tune in progress
ShutterMS3 (01-14-2018)
 Old 01-14-2018, 06:02 PM   #4
ShutterMS3's Avatar
I mean sure, because a forum where we discuss Audio specific to our cars is a terrible place to ask what headunit others have used on their cars. I wasn't saying hey where can I waste the most money on a headunit.
I appreciate the douchebag answer though, you were incredibly helpful. Will for sure take your advice.
A lot of aftermarket radio's don't have a flush fit, and also sometimes don't retain use of steering wheel controls. Which is why I was asking the question, I'm in the market for something that will have a great fit and also retains the steering wheel control.
tdsharp5 likes this.
 Old 01-14-2018, 07:00 PM   #5
Groans: 74
Neutral  :  -1 score
Np im happy to be a douchbag. This cars dashboard is the same as a mazda 3 na so maby you should go to mazda247.com you will fit in np and get all the info you are looking for.
Leme know how the new radio sounds on that high end bose system you have!!!
MECP
2012 BM
The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post:
g00s3y (01-15-2018), JSmith (01-17-2018)
 Old 01-15-2018, 02:04 PM   #6
Shwaykid's Avatar
Posts: 646   (View Stats)
Nexus 7 tablet works pretty good. Slight modifications needed...
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
The Following 2 Users Say Thank You to Shwaykid For This Useful Post:
aackthpt (01-15-2018), ShutterMS3 (01-18-2018)
 Old 01-15-2018, 08:58 PM   #7
Kellerspeed3's Avatar
Posts: 2,518   (View Stats)
Kellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the worldKellerspeed3 is the leader of the world
Groans: 50
Groaned at 37 Times in 21 Posts
I got the Eonon, retains steering wheel controls, touch screen, optional rear camera, I thinks it’s the best bang for your buck, much like the speed3.
2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa.
Kellerspeed3 is offline   Reply With Quote
 Old 01-16-2018, 02:09 PM   #8
gotovato's Avatar
Posts: 206   (View Stats)
gotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to behold
the eonon radios are good for a plug and play solution but based on what ive seen they are not the highest end quality. if you want something a little better look at a kenwood excelon series, or a higher end pioneer or apline. the model to look at will depend entirely on the features you would like ie. android auto or apple car play. with an aftermarket radio like this you will need a dash mount kit, and wiring harness, and a steering wheel control module. Cost starts to add up quick haha so really depends how good of a headunit you want. if you want "decent" cheap and cheerful go with the eonon
2011 ms3 Cobb AP, Forge bypass valve, HPFP internals, Cobb downpipe, Custom fmic w/mishimoto core, Cobb RMM, Cobb EBC, KW coilovers, whiteline RSB, stop tech fluid, stop tech SS brake lines, hawk HP+ pads, ACT 6 puck clutch, ATP 3071r, HTP 3.5" intake, Damond catch can, TunedbyNishan
gotovato is offline   Reply With Quote
 Old 01-17-2018, 09:18 AM   #9
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
the best direct fit unit is from eonon. Currently they make the best for the gen1s as well, but a big con is that they don't make them with a silver face like Caska did, this being the reason why I didn't get one so far, so I still have the good old winCE Caska.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-17-2018, 10:34 AM   #10
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
EONON sucks imo.
My plan is get a good headunit that supports AndroidAuto and Apple carplay. Headunit is $400, module to preserve steering controls about $70, and install stuff about $40.
A bit expensive but worth it for me.
 Old 01-17-2018, 12:16 PM   #11
mituc's Avatar
Groans: 111
Do you have a link to some on-line store that sells such an unit? I'd like one too, actually I'm hoping they have something in silver trim.
 Old 01-17-2018, 12:41 PM   #12
gotovato's Avatar
you can check out https://www.sonicelectronix.com/ to browse some decent headunits that support apple car play or android auto. after a quick search it seems as if the only mounting kits available are black
 Old 01-17-2018, 03:48 PM   #13
stockms3's Avatar
Groans: 74
https://www.crutchfield.com/p_158XAV...tp=20217&avf=Y
Also, you can go to crutchfield, enter your car and view headunits, then filter using "Android Auto".
Hmm maybe I can find a paint code for the interior plastic and spray a few kits in the summer.
Last edited by stockms3; 01-17-2018 at 03:48 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to stockms3 For This Useful Post:
Kellerspeed3 (01-20-2018)
 Old 01-18-2018, 07:36 AM   #14
gotovato's Avatar
definitely an option if you want it matching
 Old 01-18-2018, 09:57 AM   #15
ShutterMS3's Avatar
http://youtu.be/pQiuOb5tRks
Dude I really dig this, that's awesome!
The Following User Says Thank You to ShutterMS3 For This Useful Post:
Shwaykid (01-18-2018)
 Old 01-18-2018, 10:59 AM   #16
Shwaykid's Avatar
Thanks man. Took a lot of research and planning, but really happy with the result. Still need to wire in the backup cam though.
2008 Mazdaspeed3 GT
Headunit where remote display at the top of the dash works?? Speed3Speed MazdaSpeed 3/6 - Car Audio & Electronics 18 03-06-2012 08:37 PM
Page generated in 0.35791 seconds with 27 queries
