> 2010 MS3 - Car Audio & Electronics
Like Tree5Likes
 Old 02-25-2012, 01:06 AM   #41
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
Originally Posted by mtran View Post
To sum it all up, Apple dropped the ball, once again. Now I need to figure out how to get my galaxy note to show track info.
Don't all iphones allow you to control through the wheel/hu? You don't need to be jailbroken for your bluetooth audio to work.
Maybe on the IOS 5.0 but I'm back at 4.0 and I needed to jailbreak to use the wheel contols. Pause and play worked when the phone had factory settings.
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 02-25-2012, 09:14 AM   #42
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
Odd that your wheel controls didn't work. I am not jail broken and on the latest update and mine work?
BLK_MS3 is offline   Reply With Quote
 Old 02-25-2012, 09:33 AM   #43
jeromeseo's Avatar
Posts: 2   (View Stats)
jeromeseo is an unknown quantity at this point
Originally Posted by jeopardy98 View Post
Droid Razr works as well. I just installed the isimple gateway though so now I get a direct connection for ipod and sat and I get track info as well.
a
jeromeseo is offline   Reply With Quote
 Old 02-25-2012, 09:36 AM   #44
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Originally Posted by jeromeseo View Post
how about delay? when watching videos like youtube, video and audio sink well?
There is a slight delay but not as bad as the bluetooth. I haven't tried it at all but I'm pretty sure there would be no way to sync video. I'm pretty sure it is only audio.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 02-25-2012, 09:37 AM   #45
jeromeseo's Avatar
h
 Old 02-25-2012, 01:17 PM   #46
Post pwned's Avatar
What IOS are you on?
I know apple made an update after 4.0 that gave the iPhone better capablilaty with Bluetooth connection. Lots of people were complaining about having cheap phones that displayed contacts and track listing.
Or maybe I just got the shitty iPhone or Mazda...
2010 Mica Black
RMM/RSB/SRI+TIP
 Old 02-25-2012, 04:38 PM   #47
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
I'm on 5.0.1, but never had a problem even with an older OS.
 Old 02-26-2012, 02:45 PM   #48
Post pwned's Avatar
Sounds like I got burned.
2010 Mica Black
RMM/RSB/SRI+TIP
 Old 02-28-2012, 12:49 AM   #49
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
I've never had a problem changing tracks with my iPhone, it just doesn't display the info...
tapa talked
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline   Reply With Quote
 Old 02-28-2012, 09:43 PM   #50
hsraffety's Avatar
Posts: 106   (View Stats)
hsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud of
Same here, once paired, my iPhone 4s worked like a charm.
2012 Crystal White Pearl Mazdaspeed3 - Cobb AccessPort // Cobb Short Ram Intake // Cobb Turbo Inlet Pipe // Autotech HPFP // Race Pipe // CP-E Stage 2 xFlex RMM // Hawk HPS Rotors and Pads
hsraffety is offline   Reply With Quote
 Old 02-29-2012, 05:35 AM   #51
ripnbigc's Avatar
Posts: 24   (View Stats)
ripnbigc is a glorious beacon of lightripnbigc is a glorious beacon of lightripnbigc is a glorious beacon of lightripnbigc is a glorious beacon of lightripnbigc is a glorious beacon of light
Wish the song info was on the display though
2012 White Speed, Tinted.
ripnbigc is offline   Reply With Quote
 Old 02-29-2012, 05:56 AM   #52
jeopardy98's Avatar
PAC Gateway will solve your issues of song display.
 Old 04-04-2012, 05:15 PM   #53
dantes5823's Avatar
Posts: 6,576   (View Stats)
Care to elaborate on this?
 Old 04-04-2012, 07:24 PM   #54
manila's Avatar
Posts: 1,767   (View Stats)
^^This
'12 MS3 Black Mica w/ Tech
dantes5823 (04-04-2012)
 Old 04-04-2012, 07:43 PM   #55
Atlanta's Avatar
Posts: 233   (View Stats)
Atlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the world
Groaned at 26 Times in 14 Posts
PAC gateway
<div style="display: none;" id="ame_noshow_post_1333590234_2">
<a href="" title="MazdaSpeed Forums Presents: YouTube" target="_blank">MazdaSpeed Forums Presents: YouTube</a>
</div>
<div style="display: inline;" id="ame_doshow_post_1333590234_2">
<div align="center">
<table class="tborder" cellpadding="6" cellspacing="1" width="640" style="margin:10px 0">
<thead>
<tr>
<td class="tcat" colspan="2" style="text-align:center">
</td>
</tr>
</thead>
<tbody>
<tr>
<td class="panelsurround" align="center">
<object width="640" height="480">
<param name="movie" value="http://www.youtube.com/v/dcdUcZUufbw&start="></param>
<param name="allowFullScreen" value="true"></param>
<embed src="http://www.youtube.com/v/dcdUcZUufbw&start=" type="application/x-shockwave-flash" allowfullscreen="true" width="640" height="480" wmode="transparent"></embed></object>
</td>
</tr>
</tbody>
</table></div>
</div>
Atlanta is offline   Reply With Quote
 Old 04-05-2012, 10:11 AM   #56
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
What he said.
 Old 04-05-2012, 08:45 PM   #57
jeopardy98's Avatar
See my thread. The same company just came out with an interface that will control and display any android device as well.
Alternative option for Sirius and iPod integration
The Following User Says Thank You to jeopardy98 For This Useful Post:
dantes5823 (04-08-2012)
 Old 08-05-2012, 02:03 PM   #58
etonna's Avatar
Posts: 72   (View Stats)
etonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud ofetonna has much to be proud of
ok so I started using my BT audio a few days ago, 2012 non tech Canadian with the bose. 1st day my steering wheels controls worked great song info displayed next morning my steering wheels controls don't work! Phone is a BB9780..... any advice on how to fix?
2012 CWP Mazdaspeed 3, Cobb springs and Koni Yellow's, CP-E HPFP, Cobb TIP & SRI, Cobb AP, Cobb DP, JBR RSB, JBR Moly RMM, 18X8.5 +38 Evo BBS, 245/40/18 Bridgestone RE11A
etonna is offline   Reply With Quote
 Old 09-21-2012, 06:03 AM   #59
ripnbigc's Avatar
I was hoping Iphone IOS 6.0 would fix the lack of song info, but no such luck
 Old 09-24-2012, 06:58 AM   #60
meckman's Avatar
Posts: 11   (View Stats)
meckman is a glorious beacon of lightmeckman is a glorious beacon of lightmeckman is a glorious beacon of lightmeckman is a glorious beacon of lightmeckman is a glorious beacon of lightmeckman is a glorious beacon of light
Anybody know if the iPhone 5 can display the text? I don't get mine until Friday.
Stable:
2012 MS3 (Mods: COBB AP OTS Stage 1 tune; COBB SF; COBB TIP; JBR RMM)
2012 Roush Stage 3 Mustang (Mods: Brenspeed tune, smaller SC pulley, Cobra Jet throttle body, colder plugs, Pedders/Saleen coilovers, Fays 2 Watts linkage, Roush billet LCA, BMR LCA relocation brackets) Dyno: 604 RWHP
meckman is offline   Reply With Quote
 Old 09-24-2012, 09:22 AM   #61
jeopardy98's Avatar
No it won't. Another reason Android wins.
 Old 09-24-2012, 10:18 AM   #62
bozs13's Avatar
Posts: 31   (View Stats)
bozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond reputebozs13 has a reputation beyond repute
Sadly it won't. Another reason I switched to my S3
bozs13 is offline   Reply With Quote
 Old 09-24-2012, 06:14 PM   #63
xtwoonamatchx's Avatar
Posts: 284   (View Stats)
xtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the world
I'm running iOS6 on a 4s. Same thing. I just pick up my phone if I need to see the song name. Everything else seems pretty flawless.
xtwoonamatchx is offline   Reply With Quote
 Old 09-25-2012, 09:47 AM   #64
SpeedViktm's Avatar
Posts: 17   (View Stats)
SpeedViktm is a jewel in the roughSpeedViktm is a jewel in the roughSpeedViktm is a jewel in the rough
FWIW, I have full functionality running PowerAmp on my Galaxy S2. Except no track time, but I don't think that works for anyone...
SpeedViktm is offline   Reply With Quote
 Old 09-25-2012, 03:31 PM   #65
minger's Avatar
Posts: 1,064   (View Stats)
minger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the world
I might give PowerAmp a shot.
I think when I had my moto phones (DX, Bionic) they streamed info fine with the Stock app and possibly Google Play, but Play liked to intermittently pause songs when I hit next.
My Rezound and Nexus did not.
minger is offline   Reply With Quote
 Old 09-25-2012, 04:53 PM   #66
zmarko's Avatar
Posts: 147   (View Stats)
zmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond reputezmarko has a reputation beyond repute
I have the Galaxy S2 (Sprint) and have no problems with Google Play pausing songs when hitting next (thankfully).
-Marko 2012 Speed 3
zmarko is offline   Reply With Quote
 Old 09-25-2012, 10:33 PM   #67
minger's Avatar
It seemed to be a moto issue when using Play when using Blur roms. Worked fine on their stock music app as well as other apps such as WinAmp.
 Old 10-07-2012, 02:27 PM   #68
bvbull200's Avatar
Posts: 452   (View Stats)
bvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the world
S3 users, how are you getting track info to display? I've tried WinAmp, PowerAmp, and the stock player, but can't get anything to display.
I checked the tags and they all seem to be good. Small sample of songs right now (just 4), so if I need to try anything to manipulate those, I'll give it a whirl.
Controls work fine. Unless I'm misreading this and shouldn't be expecting song/artist info.
2010, non-tech if it matters.
bvbull200 is offline   Reply With Quote
 Old 10-07-2012, 03:24 PM   #69
dantes5823's Avatar
Mine shows info... Just on the audio screen I don't get a counter. The information screen shows info.
The Following User Says Thank You to dantes5823 For This Useful Post:
Voltron (10-08-2012)
 Old 10-07-2012, 03:35 PM   #70
bvbull200's Avatar
Any details on your equipment?
Phone, app, how your songs are tagged, etc.
Would love to have it arranged properly before I transfer the bulk of my library.
 Old 10-07-2012, 04:08 PM   #71
Midnitehours's Avatar
Posts: 115   (View Stats)
Midnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the worldMidnitehours is the leader of the world
I've got a 2010 canadian w/tech and the BT text doesn't work.
Phone is SGS3. I know the phone will do AVRCP 1.3, as i've gotten the text in a Ford before.
Any one see a way to update the 2010 pos to make it work?
OEM+ FTW
Midnitehours is offline   Reply With Quote
 Old 10-07-2012, 04:09 PM   #72
minger's Avatar
Resound. Sense Roms no go, with cm9 and Apollo and Google play yes for metadata there.
2011 MS3 - AP, AutoTech Internals, TP, 30% e85. N9thRacing RSB, JBR SSP, HKS SSQV, CPE Intake+TIP, TurboXS TP and UR Catback.
2002 Miata. Racelands, Hard Dog Roll Bar, RPF1s.
Zoom Zoom.
 Old 10-08-2012, 12:29 AM   #73
bozs13's Avatar
2012 with tech package. SGS3 worked fine stock and works great in CM10 too. Info shows up great.
 Old 10-08-2012, 08:14 AM   #74
bvbull200's Avatar
For some of the others that have it working, what year is your car? Tech/Non-Tech?
Trying to figure out the common denominator.
There is a 2010 Tech that it doesn't work in and a 2012 Tech that it does. There is a 2012 Non-Tech that it did work, now it doesn't.
I've probably answered my own question. Are the 2010 folks just screwed?
2010 MazdaSpeed 3 - Non-Tech - Celestial Blue - Cobb AP - KMD internals - JBR 70a Duro RMM - WOLO 417 Horns
2011 Chevrolet Cruze Eco - Ice Blue Metallic / Black - Stock
 Old 11-18-2012, 10:23 PM   #75
chrischil's Avatar
Posts: 230   (View Stats)
chrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the worldchrischil is the leader of the world
I am also bummed the metadata does not show up on the screen Great BT audio playback though! I listen to it more than CD's and Sat Radio.
2012 CWP Mazdaspeed3 w/ Tech Pkg.
Cobb Accessport | Cobb SRI Intake | Cobb Turbo Inlet | ATP Full Downpipe (Catless) | Autotech Internals | JBR 88 Duro RMM | Damond Motorsports Short Shift Plate |
chrischil is offline   Reply With Quote
 Old 11-19-2012, 10:29 AM   #76
minger's Avatar
Non-Tech 2011.
So an overview of my past phones in the past year:
Motorola Bionic: Blur Rom, stock music and Google Music show metadata. AOSP did as well. With Blur Rom, would occasionally have some weird control issues if skipping a track (would skip then pause, so I would need to hit play)
Galaxy Nexus: Yes with Google Music. Assuming same applies with Jelly Bean.
HTC Rezound: Sense Roms no metadata. CM9 / AOKP yes with Apollo or Google Music.
Samsung Galazy S3: AOSP roms yes with Google Music. I believe yes with Touchwiz rom as well.
 Old 11-19-2012, 02:47 PM   #77
jeopardy98's Avatar
This thread is mostly about iPod song data. We know that the Android phones work for the most part.
 Old 11-19-2012, 09:17 PM   #78
bvbull200's Avatar
Shit. I can't get it to display from my GS3. Not sure what I need to be doing differently. I'm generally not interested in a custom ROM at this point.
 Old 11-19-2012, 09:38 PM   #79
jeopardy98's Avatar
If it isn't working through the stock music player try downloading another.
bvbull200 (11-20-2012)
 Old 11-20-2012, 02:08 PM   #80
minger's Avatar
Which music application? Since you're stock...try Apollo or Google Play Music.
The Following User Says Thank You to minger For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f434/bluetooth-audio-display-100325/
Bluetooth calling only displays numbers? (but media album/artist/song tags work) : mazda This thread Refback 12-02-2012 05:54 PM
IPhone bluetooth audio & 2010 MS3 Ironside 2010 MS3 - Car Audio & Electronics 78 04-21-2011 08:06 PM
Bluetooth Audio Receiver Works with my iphone 007ms3 MazdaSpeed 3/6 - Car Audio & Electronics 5 04-21-2011 08:07 AM
VIDEO: Bluetooth gains another use, streaming audio from iPhone Haltech Automotive News 0 04-04-2009 10:50 AM
Jabra BT8040 Bluetooth Headset (Stereo Bluetooth Capable) $49.99 Haltech Hot Deals Section 0 04-08-2008 12:50 PM
Page generated in 0.64575 seconds with 40 queries
