> 2010 MS3 - Car Audio & Electronics
 Old 01-02-2017, 12:40 PM   #1
iptydafool's Avatar
Posts: 49   (View Stats)
iptydafool will become famous soon enoughiptydafool will become famous soon enough
Default Boost Gauge Illumination Question
Spent a couple days trying to find a previous post similar, maybe my wording is wrong.
Nonetheless, I recently installed a ProSport boost gauge on my Pu and everything works. Tapped 12v accessory into CIGAR fuse and then the wire, which would normally goto headlight or tail, into the green wire on the BCM harness (it was easier to get to and it only got power when the headlights were switched on).
Here's the issue:
During the day the gauge color will change when I hit the headlights on but at night it stays one color.
Does having the tech package play a roll in this?
iptydafool is offline   Reply With Quote
 Old 02-23-2017, 10:48 AM   #2
iptydafool's Avatar
Found out the auto on headlight feature interferes with how I have it wired. As long as I manually turn the headlights on and not use the auto on the gauges work as normal. Will eventually go back to the wiring diagrams to find another wire to tap.
BOOST gauge question 2con Mazdaspeed3/6 General Discussion 6 07-28-2013 09:55 PM
3Port & Boost Gauge Question Badinfluence MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 04-20-2013 03:48 PM
Boost Gauge wiring question KeysMS3 MazdaSpeed 3/6 - Car Audio & Electronics 2 03-03-2010 08:15 PM
Vent pod boost gauge install question uoftguy MazdaSpeed 3/6 - Car Audio & Electronics 1 05-10-2009 07:59 AM
New metro gray speed 3 - boost gauge/timer question pmarcian Mazdaspeed3/6 General Discussion 20 07-21-2008 08:13 AM
Page generated in 0.22465 seconds with 20 queries
