> 2010 MS3 - Car Audio & Electronics
 Old 07-19-2013, 09:30 PM   #1
iammike's Avatar
Posts: 1,415   (View Stats)
Default In Cabin Illumination Fuse
Just making sure I'm not crazy. Is there no fuse in the in cabin fuse block that only fires when you turn on the headlights? I really don't want to have to tear the battery back out to run another wire up to the engine bay.
FYI, this is for the illumination wire on the Defi gauges so that they dim when you turn on your lights.
Mike
 Old 07-19-2013, 10:12 PM   #2
chuckms6's Avatar
Posts: 1,618   (View Stats)
Cig lighter light bulb wire
Sent from my SAMSUNG-SGH-I727
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 07-19-2013, 10:14 PM   #3
iammike's Avatar
Unfortunately, I believe my 2012 never even had an option for ash tray or anything so nothing lights up down there when I turn on the lights. No ring around the "cig lighter" nor any light in the spot an ash tray would be..but instead on mine is a cubby and a no smoking sticker. lol
Mike
 Old 07-20-2013, 09:26 AM   #4
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
http://www.mazdaspeedforum.org/forum/foru...iagram-133289/
You should be able to pick up a trigger either at the back of HU or coming out of the column stalk switch....
 Old 07-20-2013, 09:30 AM   #5
iammike's Avatar
I'll be sure to check this out when I get home. Thanks!
Mike
 Old 07-20-2013, 11:31 AM   #6
iammike's Avatar
Ok, looking at the wiring diagram, with my limited understanding of electronics, I think I might have found a signaling wire that goes right by the in cabin fuse block but would love for someone to take a look and check out my idea first.
On page 250 we see a diagram which includes the LED indirect lighting for the power window switch area in the drivers door. C29 which I believe means Connector 29.
Page 251 we see that C29 is in the area that the in cabin fuse block would be sitting.
The attached images are the parts of particular interest to me...but I'm not sure how to read it in a way to identify the correct wire color to tap.
File Type: png Screen Shot 2013-07-20 at 12.27.16 PM.png (31.8 KB, 8 views)
File Type: png Screen Shot 2013-07-20 at 12.28.21 PM.png (24.8 KB, 6 views)
Mike
 Old 07-20-2013, 03:48 PM   #7
iammike's Avatar
Thanks a ton, this is what got me in the right direction.
I ended up tapping the light green wire going to the DSC switch and all is working great for the boost gauge lighting now.
Mike
The Following User Says Thank You to iammike For This Useful Post:
CosmicArkie (07-21-2013)
 Old 07-21-2013, 11:29 AM   #8
hamfisted's Avatar
Posts: 92   (View Stats)
hamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant future
The glove box light is tied to the headlights as well. Might be an easier spot to tap inside the cabin.
hamfisted is offline   Reply With Quote
 Old 07-21-2013, 01:43 PM   #9
iammike's Avatar
For a Gen 1 maybe, since they have to run their wires to the glovebox area anyway...but for Gen 2, the DSC button and wiring is just a couple of inches away from the fuse block with nothing in the way.
Mike
Illumination wire? Please help Honorary Title MazdaSpeed 3/6 - Car Audio & Electronics 9 05-19-2013 12:35 AM
Light Mine Pro is naval warfare-inspired underhood illumination Haltech Automotive News 1 01-02-2012 09:10 AM
What is the "P Outlet" (15A) fuse in the engine bay fuse box TWOptSL0W MazdaSpeed 3/6 - Car Audio & Electronics 18 10-23-2011 11:07 AM
Prosport Gage Illumination Stan-O MazdaSpeed 3/6 - Car Audio & Electronics 22 08-01-2010 07:34 PM
Stuck Rim on Jeep, Proper Tire Rotation, Honda Cabin Air Filter, Power Windows Fuse, How To Grease Zipper on Jeep Top: M Haltech Automotive News 0 04-17-2009 09:50 AM
Page generated in 0.31703 seconds with 24 queries
