![]() Join Date: Jan 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
(Thread Starter) | Not Ranked : 0 score So I purchased a PAC AOEM-MAZ2 as well. I'm currently trying to follow the instructions that came with the PAC and I'm not really understanding their diagram according to the cables actually provided. I've pictured both below and tried to label things in case it helps. What I want to confirm is whether I have the cables in the right order (supposed to be plug and play) and/or if its totally wrong. By the diagram it looks wrong but based on fitment and harness order, I can't see any other combination really happening. Can anyone confirm here that I'm on the right track before I put power to everything? All the related threads/videos I've found don't actually show what it physically looks like when you add a aftermarket HU and want to keep the original Bose speakers and sub by using the PAC secondary harness. |
Groans: 60
| Not Ranked : 0 score Thats the wrong pac part. You can use the OEM1(NOT AOEM-MAZ2) or you can just solder male rcas to the speaker wires and plug them directly into your new radio.
| The Following User Says Thank You to SSinstaller For This Useful Post: | .Slug (01-13-2017) |
(Thread Starter) | Not Ranked : 0 score Thanks! I actually have to return the unit. It is disabling my climate control and there are dead pexels on the lcd. It also doesnt respond to some app commands or screen touches. They must be still working out the bugs in this thing. It honestly didn't sound THAT bad. I expected worse. |
So, how do I have it connected incorrectly as it doesn't appear to have made any difference hooked up. Still had hissing and amplified volume problems. I wasn't using the RCA's on the opposite end of the OEM1, do those need to be plugged into the RCA outs of the head unit as well? Thanks for any additional assistance. | |
Groans: 60
| Not Ranked : 0 score The OEM1 is just a line output reducer. It takes the high level speaker outputs and converts them to low level outputs the bose amp can use. The part you bought includes the main component of the oem1, but comes with harnesses and is pre wired to provide rca outputs for you to add amps to the oem radio. You could cut it up and make it work, but there is really no need as soldering in $5 worth of rca connectors works just as well if your radio has >2v preouts.
| The Following User Says Thank You to SSinstaller For This Useful Post: | .Slug (01-14-2017) |
(Thread Starter) | Not Ranked : 0 score I found a perfect resource that shows everything, including the aux fix and RCA splice with great pictures on Imgur. (right hand drive though and the previous model stereo, this doesn't change anything because the issues are exactly the same and the solutions are the same). But hopefully it helps someone going down the same road in the future. https://imgur.com/a/U2nD4#d31N9Fe |
| 2013 Bose system with PAC AOEM-MAZ2 | Georgediego | 2010 MS3 - Car Audio & Electronics | 18 | 09-15-2014 06:17 AM |
| To use PAC AOEM-MAZ2 or not | RACER_X | 2010 MS3 - Car Audio & Electronics | 6 | 09-15-2014 06:10 AM |
| MS6 Bose: AOEM-MAZ2 | zer010gic | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 05-28-2014 07:38 PM |
| AOEM-MAZ2 works with 2012 Bose | qweedqwag | 2010 MS3 - Car Audio & Electronics | 8 | 06-11-2013 03:04 PM |
