> 2010 MS3 - Car Audio & Electronics
 Old 08-23-2018, 01:18 PM   #1
Cope's Avatar
Posts: 13   (View Stats)
Cope is an unknown quantity at this point
Default No steering controls, no cruise control
Basically all steering wheel controls are inoperable/unresponsive.
Occured after getting a new clutch in my 2013 speed. Is there a particular fuse or wiring harness that powers the steering controls that I cant seem to find?
Any help would be appreciated. I have a 5 hour drive ahead of me and I would love some cruise lol being a bit of a noob, I cant seem to find the info I'm looking for.
Thanks guys.
Cope is offline   Reply With Quote
 Old 08-29-2018, 02:16 PM   #2
Cope's Avatar
I guess it will remain a mystery...
 Old 08-29-2018, 02:27 PM   #3
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Did you unplug anything by the glove box where the module is? or the radio where some of the wires go? Or the column where the wires plug into the clock spring? The controls are resistance based to ground. There is 1 wire that goes to the Bluetooth module above the glove box that attaches to the controls.
If you want a responce to a thread try bumping it by saying BUMP.
MECP
2012 BM
Rfinkle tune in progress
 Old 08-29-2018, 03:50 PM   #4
Solarsurge's Avatar
Posts: 577   (View Stats)
When my battery died completely and I had to push start my car to get it to the store to buy a new battery, my steering was cutting in and out on the way. There is definitely an electrical issue there. There are two grounds on a bracket on the transmission casing which need to be disconnected to pull the transmission for a clutch swap. I'm pretty sure that one of those grounds is the ground for the hydraulic power assisted steering system. They may have forgotten to connect it or it came loose.
 Old 08-29-2018, 10:12 PM   #5
Cope's Avatar
I'm thinking that ground will likely be the issue. Appreciate the insight guys.
 Old 09-24-2018, 08:50 PM   #6
Cope's Avatar
So all the grounds are in tact. I cant seem to locate any loose wires or plugs. Pulled every fuse. Anyone know what wires go into the main harness related to this?
Steering Wheel controls problem chock CX-7 > Car Audio & Electronics 12 06-05-2018 03:16 AM
how to install Double DIN and keep steering wheel controls mlamp89 CX-7 > Car Audio & Electronics 8 06-15-2015 04:33 PM
Steering wheel controls Pseudonym MazdaSpeed 3/6 - Car Audio & Electronics 4 05-31-2013 11:40 PM
Steering wheel controls pinout nmhforlife MazdaSpeed 3/6 - Car Audio & Electronics 1 07-17-2011 11:09 PM
can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? btstarcher MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 06-17-2011 11:06 PM
Page generated in 0.25474 seconds with 22 queries
