> 2010 MS3 - Car Audio & Electronics
 Old 01-04-2018, 05:09 PM   #1
Johnoolo's Avatar
Posts: 20   (View Stats)
Johnoolo has a spectacular aura aboutJohnoolo has a spectacular aura about
Groaned at 3 Times in 1 Post
Default Radio Eletrical problem please help
Was riding on the way to The base for work today. cold out 6 degrees I hit a bump my Bluetooth stopped playing music and now there is an orange line that is displayed on my display instead of what radio station or climate setting. my nav screen no longer shows average fuel economy or out side air temperature. I can click FM am etc [/IMG]
http://i1379.photobucket.com/albums/...psnidxqiqr.jpg
Last edited by Johnoolo; 01-04-2018 at 05:09 PM. Reason: MSF Database - Automerged Doublepost
Johnoolo is offline   Reply With Quote
 Old 01-05-2018, 10:49 AM   #2
Johnoolo's Avatar
Here is an update my Cobb v3 wasn't working either I unplugged it everything came back to normal. the port feels loose coming from the car although I then plugged an ob2 scanner In no problems read codes and operated fine my Cobb v3 turns on just fine from the computer. could my cord be toast?
 Old 01-12-2018, 08:29 AM   #3
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
They're known to go bad sometimes. Try swapping cables temporarily if you can ?
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 01-12-2018, 08:34 AM   #4
Johnoolo's Avatar
Problem solved, I isolated it being a cable and shout out to Cobb for covering my cable under warranty no problems at all thanks for responding.
Eletrical Interference 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 17 10-12-2009 07:46 PM
sirius radio install problem. help!! diepanthony MazdaSpeed 3/6 - Car Audio & Electronics 6 12-27-2008 12:35 PM
Page generated in 0.23948 seconds with 21 queries
