> 2010 MS3 - Car Audio & Electronics
 Old 11-29-2018, 12:16 AM   #1
ONiX's Avatar
Posts: 3   (View Stats)
ONiX is an unknown quantity at this point
Default Speakers Work For A Few Seconds, Then Turn Off?
Hello. Today I installed a set of Rockford Fosgate speakers in the two front doors. I wired them up correctly with the adapters and everything worked fine for the following 2 hours I was driving around. After I turned off the car , i came back only to find the speakers didnt turn on. I found out that when I start the car, the speakers work for about 2 or 3 seconds, then stop working. Does anyone know the possible issue? I have a stock head unit and the speakers are 55 watts each. Rear speakers are still stock. Thanks!
ONiX is offline   Reply With Quote
 Old 11-29-2018, 07:11 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Speakers watts doesn't mean anything but have you checked speaker impedance (ohms) ?
If you got lower resistance value it can load the unit and make it fall in protect or blow up.
Just a lower impedance would take some time to make it fall in protect so i would check again the wiring you made to make sure the wires aren't touching toghether or any of them touch the car chassis....head unit internal amp isn't isolated from chassis ground....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Speakers won't work Chrisap29 2010 MS3 - Car Audio & Electronics 6 01-22-2017 05:20 PM
Turn up your speakers for this Shelby-powered Sunbeam Tiger and friends Haltech Automotive News 0 06-18-2014 06:40 PM
Driver's turn signal - flashes on alarm but doesn't work with turn signal? xcoldricex MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-23-2014 08:50 PM
08 Mazdaspeed 3 did not turn on after work gt5 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 01-07-2010 05:38 PM
Page generated in 0.23274 seconds with 21 queries
